Old 25th June 2008, 18:20   #91
BHAGWAN's Avatar
Thanked: 13 Times
Cool Some more - before the install is completed !!
Some snaps of the woffer 'A' being installed on the inside of the 'Baffle'
Swift - Diesel - ICE - Steg + MB Quart [Q Line] + Illusion [Carbon].-mounted.jpg
Swift - Diesel - ICE - Steg + MB Quart [Q Line] + Illusion [Carbon].-inside-.jpg
Swift - Diesel - ICE - Steg + MB Quart [Q Line] + Illusion [Carbon].-p1090183.jpg
Swift - Diesel - ICE - Steg + MB Quart [Q Line] + Illusion [Carbon].-p1090181.jpg
BHAGWAN is offline   Reply With Quote
Old 25th June 2008, 18:25   #92
nishantgandhi's Avatar
Thanked: 151 Times
Even if you say 'very very small' for the enclosure, it seems quite heavy from the pics. Could you give the details of the material used in constructing the enclosure?
Also, this is the first time I am seeing Noise Kill damping inside the enclosure. Is this a standard practice in making boxes?
nishantgandhi is offline   Reply With Quote
Old 25th June 2008, 18:33   #93
BHAGWAN's Avatar
Thanked: 13 Times
Red face This is a small & light sub !!!
Hi !
By my standard; this is a very very light sub.
There is No Box in Box construction.
There is no double wall.
There is no Concrete.
There is no Ceramic Lining.
Besides it is a .65 cft box [i.d.]
That is God Damn small. But that is what I need for 2 woffers from Illuson Audio - ND 12 if they are in an isobarik sealed enclosure.
Now, I still have 50 % of my boot space for a small swimming bag to fit !!! Just kiddin.
The material in this case is just MDF or HDF board.
No elaborate material was used.
Old 25th June 2008, 18:49   #94
BHAGWAN's Avatar
Thanked: 13 Times
Just put the box on the scale;
18.32 kgs without carpet.
That is still to be done.
The Sub should be complete by tom. Will be installed by then. I hope.....
Old 25th June 2008, 18:55   #95
BHAGWAN's Avatar
Thanked: 13 Times
Talking Cost !! Hence no one will use it !!
Sir,
No one puts noise kill / damping on the doors & the boot, where it is needed the most.
The question of puting it in the sub enclosure does not arrise.
I like to use it. Have been doing it for many many years now.
I also fill the box - more often than not. But not in this case.
Old 25th June 2008, 21:21   #96
Awaiting Email Confirmation
Hey Bhagwan !
What is the total Damage ?
nitin.dangayach is offline   Reply With Quote
Old 25th June 2008, 21:26   #97
BHAGWAN's Avatar
Thanked: 13 Times
My Noise Kill - Deadning material account got closed. I used and installed 168 sq. ft. of Noise Kill in the Swift. This was for all 4 doors + boot + sub enclosure + A & B pillars etc.
Old 25th June 2008, 21:30   #98
Thanked: 83 Times
Why did you leave out the roof of the swift? Any reasons or was it not required? Wont that ring? I am asking but I must admit that ICE means solidified water to me!
SumitB is offline   Reply With Quote
Old 25th June 2008, 21:43   #99
ramie2400's Avatar
Thanked: 58 Times
Mr.B the installations are looking very nice congrats on the efforts you have put in very neat installs
Old 26th June 2008, 08:26   #100
BHAGWAN's Avatar
Thanked: 13 Times
Arrow
The roof of the car does not ring / sing.
If, I did find the roof of the car to be resonating, trust me, I would have put the noise kill there too. However, it is not in direct contact with any speaker / woffer. Hence, if it vibrates, it is minimal & cannot be heard. Therefore no noise kill on it....
Thank you sir....
You are from Mumbai, do drop by for a listen.
The install should be complete this evening.
Just have the sub to be installed & rear tweeter position fixed and installed.
Some covers & carpets have to be sorted.
The car will be back on the road by tom. 1 full week went in.
I seem to be satistied with the out come. I do hope the sub enclosure performs well. That is the only variable, I am scared of.........
God has been kind, I am sure all will go smoothly....
cheers:
Old 26th June 2008, 10:39   #101
BHAGWAN's Avatar
Thanked: 13 Times
Wink Weight of the sub !!
Snaps of the sub on the weighing scale :-
Swift - Diesel - ICE - Steg + MB Quart [Q Line] + Illusion [Carbon].-weight.jpg
Swift - Diesel - ICE - Steg + MB Quart [Q Line] + Illusion [Carbon].-p1090187.jpg
Old 26th June 2008, 11:16   #102
arpandiv's Avatar
Thanked: 27 Times
hi 'b' what type of connector is that which is being used for the sub?
arpandiv is offline   Reply With Quote
Old 26th June 2008, 11:19   #103
Thanked: 294 Times
That will come close to 30-35 kgs.
Old 26th June 2008, 11:26   #104
ramie2400's Avatar
Thanked: 58 Times
Thank you sir....
cheers:
I will PM you and make a plan's to come down and audition your setup its looking very tempting,good installs take alot of time and patience,after all hardwork pays off,I am sure it will be sounding much more than you expected Mr.B,Will you be carpetting the Sub box or using paint..cheers
Ramie
Old 26th June 2008, 11:31   #105
ibcool's Avatar
Thanked: 7 Times
it looks like a 9 pin connector
mostly used in audio connections, makes it easy to detach the sub and take out if required and as far as i know the 9 pin usage leads to better SQ
ibcool is offline   Reply With Quote
My Carbon Steel Grey VW Polo 1.5 TDI (Comfort Line) kishore1984 Test-Drives & Initial Ownership Reports 10 2nd October 2016 22:10
ICE from The MB Quart Skoda blueraven316 In-Car Entertainment 21 21st September 2008 06:50
Skoda Superb ICE: Steg/ Illusion Audio/ Alpine Bass&Trouble In-Car Entertainment 56 13th August 2008 15:19
Skoda RS ICE - Re-Done: Carbon + Steg + Ground Zero + Stinger + Optima BHAGWAN In-Car Entertainment 142 4th June 2008 14:53
4-channel Soundstream Amp For Sale & MB Quart Q-Line 6.5" Component System QSD216 Bass&Trouble Shifting gears 7 19th March 2008 09:27
