Old 25th June 2008, 14:36   #1
simply_sunny001's Avatar
Thanked: 15 Times
Default URGENT HELP NEEDED : HU creating problems
Hi All
i'm having a strange problem with my HU since last 2 days.
The HU is Kenwood KDC-MP5028
Amazon.com: Kenwood KDC-MP5028 CD/MP3 Receiver: Electronics
PROBLEM
its getting attenuated every 10 seconds.the frequency is increasing now.
it is automatically doing ATT on and then ATT off every 5 seconds.
First i thought that the clipping etc is loose and its happening in potholes,checked everything
but its not the reason,its happening every now and then even when car is stationary.
Please help me guys,has anyone else ever faced such problem ?
Thanks in advance
simply_sunny001 is offline   Reply With Quote
Old 25th June 2008, 15:09   #2
mohang_j's Avatar
Thanked: 18 Times
Originally Posted by simply_sunny001 View Post
Hi All
Try disconnecting speakers one by one / run HU without connecting speakers.
mohang_j is offline   Reply With Quote
Old 25th June 2008, 16:23   #3
Thanked: 21 Times
Newer Kenwood HUs have a protection circuit. If your speaker cables would be shorting, it would show PROTECT on the screen and shut down. That doesn't seem to be the case here.
There is a cell mute cable at the back of your HU. This is normally provided so you can connect it to an aftermarket handsfree kit, so when you get an incoming call your system automatically attenuates. In you case (I assume you don't have such a kit) this cable should not be connected to anything.
Check this cable. My guess is its touching ground or such, causing it to trigger attenuation.
Old 25th June 2008, 16:41   #4
Thanked: 15 Times
thanks a lot Gunbir
the HU has this cable and i will check it (looks very likely)
Urgent help needed. please help-Santro Xing not starting iron.head Technical Stuff 3 12th May 2012 08:27
Help Help Urgent Help!!! abhibh In-Car Entertainment 12 11th April 2006 12:15
Urgent Help needed for choosing H.U and Basstube! Puffdamgcdragon In-Car Entertainment 7 11th October 2005 13:09
Fast decision your help needed urgent Montoya Sedans 72 17th May 2005 01:36
