Old 14th May 2010, 15:45   #106
I have a mono under front left and a 4 channel under front right. Will post pix later.
How did you manage to put an amp under the front right, there's a seat beat alarm system located there. Did you remove it?? Pics pls!!
Devil on Wheels is offline   Reply With Quote
Old 14th May 2010, 23:10   #107
muneemmk's Avatar
Thanked: 17 Times
The MiX amp kits costs hardly 1,100rs. Real fakes they are.The MTX Sealed Subwoofer Enclosure prices have came down drastically,now it costs just 10,000rs MRP.
muneemmk is offline   Reply With Quote
Old 1st June 2010, 08:58   #108
jkdas's Avatar
Thanked: 1,389 Times
I thought of having a budget install
Now I have to upgrade coz I find the 608c pretty shrill at high volume. As of today the following are my options ( which I can afford ).
1) DLS C6A
2) Focal Access 165 A1
My issue is
A) I cant audition anything ( I cant find time to travel around & I cant find people who has this at my place)
B) Budget is sadly fixed !
C) My Pioneer 4 channel will stay and will have to power whatever I buy ( 50x4 @ 4 ohm OR 60x4 @ 2ohm).
Taking these into consideration, what can you suggest? I don't hear heavy metal at all and love most other genres. Will be great if unbreak my heard/lady in red/ar rehman/MJ stuff sounds great at high volume.
Old 1st June 2010, 11:44   #109
smsrini's Avatar
Thanked: 256 Times
I'm sure you've already played around with the crossover settings ?
I was told that the GTO 508/608 C play sharper by default, but if you want more natural / warmer sound, you should keep the crossover at -6dB or something... How correct is this ?
How much of this shrill-ness will damping be able to negate ?
smsrini is online now   Reply With Quote
Old 1st June 2010, 13:16   #110
jkdas's Avatar
The crossover has only setting and I am already using it ( -3db ?)
And its bright ( not shrill) coz of the tweeter.
Old 1st June 2010, 14:47   #111
thelord's Avatar
@jkdas
The DLS C6A is a good set for the price. There might not be a noticeable change in the mid-bass but the T20 silk-dome tweeters are smooth. Also, they come with separate cross-over network for the mid-bass and tweeter, so they are bi-amp ready.
Should gel perfectly with the Pioneer providing 50W as the C6A are rated at 60-65W I think.
thelord is offline   Reply With Quote
Old 1st June 2010, 20:56   #112
jkdas's Avatar
Originally Posted by thelord View Post
@jkdas
Thanks buddy. Isnt the tweeter a bit smaller than 608c's ( ie,less than an inch) and hence wont it need some extra effort to fit in default location ?
Old 2nd June 2010, 12:23   #113
thelord's Avatar
That's correct. Though, am quite sure the difference shouldn't be much of a problem for an experienced installer.
Old 8th June 2010, 20:44   #114
jkdas's Avatar
Someone had enabled DEFEAT !
Enjoy music after a long time today.
Old 9th June 2010, 10:07   #115
jkdas's Avatar
Got my the upgrade stuff today morn; hand delivered !
Now, confused how I will power it as it comes with separate crossover for tweeters and woofer!
Old 9th June 2010, 10:26   #116
thelord's Avatar
Congrats jkdas! Another one smitten by the DLS sound.
Is this the C6A set?
If you got spare channels on the amp, then bi-amping is the best way to go.
Otherwise, you can just bi-wire the set. i.e. connect the output from the amp to the mid-bass cross over input and connect it with the tweeter cross over input using normal speaker wire.
Old 10th June 2010, 16:03   #117
jkdas's Avatar
Yes, its the C6A.
Spare channel? I have a 4 channel amp, use all for these and run rear from HU?
Old 10th June 2010, 19:47   #118
jkdas's Avatar
Default Performance C6A - 2-way system 6,5 inches
More pix of the Performance C6A - 2-way system 6,5 inches
It's specs
Woofer size 16,5 cm (6,5")
Tweeter T20, 20 mm (0,8") silk dome tweeter
Power handling capacity 60 W RMS / 90 W max
Impedance 4 ohm
Frequency range 50 - 20.000 Hz
Sensitivity 93 dB (1W/1m)
Outer diameter of woofer 165 mm (6,5")
Magnet size 80 mm (3,15")
Mounting depth 63 mm (2,48")
Crossover Cable filter with slope LP: 6 dB, HP: 12 dB
Crossover point (Hz) 5000 Hz
Old 10th June 2010, 20:12   #119
bhp_maniac's Avatar
Thanked: 90 Times
Post deleted by the Team-BHP Support : Please do NOT post one-liners that add little or no informational value to the thread. We need your co-operation to maintain the overall quality of this forum.
Please read our rules before proceeding any further.
bhp_maniac is offline   Reply With Quote
Old 12th June 2010, 01:23   #120
thelord's Avatar
Exactly! That'll give you a lot more control over the tweeter.
I think the rears should run sufficiently fine through the HU.
Yes, its the C6A.
ICE' ing the White Beast- Scorpio VLX 8 Seater prithvi_seln In-Car Entertainment 38 21st October 2010 10:52
My Verna Beast ICE'd sajands In-Car Entertainment 18 2nd September 2008 19:30
Getz Crdi VFM ICE : Beast meets the BULL naman In-Car Entertainment 47 1st September 2008 23:44
Chennai to vizag (1928 kms) on my new Beast! (EDIT: Beast=Fiesta 1.6 zxi Petrol) gopal.putrevu Travelogues 19 18th April 2008 13:35
ICE'ing the Autopsyche MIVEC Beast... gunbir In-Car Entertainment 68 8th January 2008 23:05
