Old 4th July 2008, 23:57   #1
reveal_da_zeal's Avatar
Question Suggest add on for M-800
Need Components and an amp, already have JBL ovals in rear. suggest which ones can fulfill my need for a pleasing sound as most of the time i am out driving, no show off just pure music. You can term it the corporate way. Budget : around 9-14k at max 20k..
also kindly suggest if there is need for any extra stuff like damping and others. Don't want to miss any part.
reveal_da_zeal is offline   Reply With Quote
Old 5th July 2008, 01:39   #2
rohan_fonseca's Avatar
Budget please. And whatever it may be, The ICE gurus will blow it way
rohan_fonseca is offline   Reply With Quote
Old 5th July 2008, 10:19   #3
rider60's Avatar
Thanked: 47 Times
http://www.team-bhp.com/forum/sound-...p-my-m800.html
check out this thread should give you a good idea, about what to get for the car, well wouldnt recommend the sony amp like in the set up above you can instead get a better one, as you have the budget and in that budget you can go for damping too!
say the split is 4-6K for the components!, say around 7-10K for the amp, 2K for rcas ans wiring ans 2K for damping! there goes the 20K!
EDIT: say if you manage to buy the components for like 4.5K, the amp for around 7K, a good rca set will cost like not less than 3K, and the rest can be used for damping and labor! happy icing!
rider60 is offline   Reply With Quote
Old 5th July 2008, 14:37   #4
Red face
Thanks for the concern Rider. I also am actually seeking for an install that do not include Sony in any form..
1. So according to you I should go for Damping too, done.
2. Then for the components please shortlist some names i think infinity and Bull fit in best and as per reviews should i go for Bull?
3. Then comes amp. Is Kenwood fine with 2 JBL Gto936e and the specified Bull Components?
Thanks that you take time out to Help.
Disclosure: this would be a DIY.
Old 5th July 2008, 14:40   #5
Wink
sorry for if the post was a bit messy. budget there in third line looks like :-
Old 5th July 2008, 16:16   #6
manikjeet's Avatar
Thanked: 110 Times
i would suggest bull comp. 4.5k kenwood amp. 8401 5.5k-6k
it totals to 10k and rest 3k for wiring and another 3k for the damping
its 16k and 1k up or down
ps spacer rings will cost 1-2k i think
manikjeet is offline   Reply With Quote
Old 5th July 2008, 22:08   #7
Lightbulb Thanks
Thanks, suggestion taken... anywhere i can get the install???
Old 5th July 2008, 22:08   #8
mnhegde's Avatar
@reveal : Check out some 3 to 4 types of components , and see which you are comfortable with. Comps like JBL, AD, Polk , Bull , Infinity are good.
@Manikjeet : spacers cost less than 1k.
mnhegde is offline   Reply With Quote
Old 6th July 2008, 00:12   #9
rider60's Avatar
Thanked: 47 Times
well the amp is fine, for components you can check out the ones suggested, i liked the jbl a lot so went with them in my swift and accent!, for amp you can also try out the jbl GT5 series, or the kenwood ones and may be a few others, gurus a little help about the brands in this price range?
and by the way each spacer ring made of mdf cost me approx 150 bucks so i am expecting this install to need around 4-6 spacers, its that price for mdf the ply wood ones are cheaper say around 50 -100 bucks a piece!
and all the best with the DIY, i suggest you have some one with experience by your side, just in case you are new to ICE installs!
Old 7th July 2008, 08:53   #10
nickoo's Avatar
bro, check out the compos for yourself a particular set may suit my taste but wont suit yours. There are various brands like JBL, polk, boston, bull, rainbow, mtx, blau to name a few. Go to a decent installer and request him to let you audition a few that fall in your budget and Kenwood 8401 is a decent amp!!
nickoo is offline   Reply With Quote
Old 8th July 2008, 22:36   #11
noidaboy's Avatar
Thanked: 260 Times
I second this advice its 100% vfm, i have the same setup in my 800 and im really happy with it, you might even want to save on damping as 800's door hardly rattles
noidaboy is offline   Reply With Quote
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
can i add a 1.6 corsa dash to my 1.4? spdemon Modifications & Accessories 3 7th September 2005 11:25
Help me out on the add-ons for Petra shyamsk Modifications & Accessories 15 17th August 2005 10:48
Baleno add-on blues- problems of a nomadic existence Puffdamgcdragon Modifications & Accessories 10 30th July 2005 02:55
