Old 16th November 2008, 11:34   #61
sathee46's Avatar
@maunishpatel is the option to switch off the Subwoofer working? do you find any difference in SQ after using the Y-adapter
sathee46 is online now   Reply With Quote
Old 19th November 2008, 11:29   #62
maunishpatel's Avatar
yes my system allows me to switch on and off the subs.
the Y adepter has split the one sub rca from the HU to two so it has defenately made a difference.
maunishpatel is offline   Reply With Quote
Old 29th November 2008, 11:42   #63
gigy's Avatar
Thanked: 41 Times
Has anyone bought protection film for the touch screen of 700 or 800 series, if so how much they cost and from where?
Old 29th November 2008, 21:48   #64
drvhplyevraftr's Avatar
Thanked: 16 Times
Guys,
Anyone had a chance to compare the JVC 800/814 with Pioneer AVH-4050?. Those are having similar specs and priced in the same range. I want some opinion on which
has better Sound Quality.
Thank you.
drvhplyevraftr is offline   Reply With Quote
Old 3rd December 2008, 11:01   #65
Thanked: 16 Times
Guys,
I know there are lot of satisfied owners of JVC AVX 800/814. I would like your inputs on few things so that I can decide on which one (800 or 814) to go for.
I currently have a SONY MEX-R1 DVD player and it has trouble playing DVDs. It pauses for a few seconds or skips once in every 2 - 3 minutes and is very annoying. Does the JVC have this problem as well?.
Also I will be using the 800 or 814 to play songs from USB pen drive/portable Hard disk and IPOD. Does it take long time for the JVC to read and start playing songs from USB/IPOD?. Between the two (800/814) which takes lesser time to read?
Also I am not really worried about the detactable face plate (available in 814) and I read from the forums that 800 has lot more tuning options and am more inclined towards the 800. The last I heard two weeks in Hyderabad is that both are available at almost the same price. So any particular reason you think I should go for the 814 and not the 800.
Also if you have any inputs on the enhancements made to 814 (interms of better screen or responsiveness to the touch screen or better seek times etc) when compared to 800, please let me know.
Thank you.
Old 3rd December 2008, 14:28   #66
dinu2506's Avatar
Thanked: 351 Times
Originally Posted by drvhplyevraftr View Post
Guys,
Thank you.
I have been using the AVX800 for few months now.
- I have not faced any problem with skipping of DVDs
- I use a 40GB USB HDD with my AVX800. It has around 16GB of music stored. The initial read takes around 30 seconds which I have got used to. Once it loads up it takes no time to scan through folders, select songs etc. If you can live with the initial 30 seconds delay, its a breeze. I presume AVX814 also will take the same time. I have tried in the AVX44 and it takes the same time
- For Ipods you need to buy the Ipod adapter in order to get the iPOD options
- Tuning options, yes, the main thing which is missing in 814 and available in 800 is time alignment which can help create the soundstage where you want. I think it is a gross omission in the 814.
- I have not personally used the 814, so cannot comment on its pluses. If available for the same price, I would anyday go for the 800. The detachable face plate is a good thing, especially when you give the car for servicing etc, but I guess I can live with not having it.
dinu2506 is online now   Reply With Quote
Old 3rd December 2008, 14:40   #67
Thanked: 16 Times
Thank you dinu2506 for your reply. How do you find the SQ of the AVX?. My primary requirement is SQ all the bling factor is only secondary. Did you get a chance to compare the AVX 800 with any other similar priced, similar featured HUs?.
Thank you.
Old 3rd December 2008, 15:05   #68
gigy's Avatar
Thanked: 41 Times
DINU2506, are you using any protective film over the screen, did you try to source them or see them in market.
Old 3rd December 2008, 15:26   #69
noidaboy's Avatar
Thanked: 260 Times
Thank you.
Note from mod, do not recommend brands you deal in
noidaboy is offline   Reply With Quote
Old 3rd December 2008, 16:04   #70
Screwdriva's Avatar
Thanked: 378 Times
Default iphone
Does anyone have a way to make the iphone work with the AVX series? I have an AVX 44 Single DIN and while I can charge the iphone through the USB cable, I can't access any music from it. This is quite saddening and I am desperate to find a solution to access my music from iphone.
Appreciate any advice you have
Screwdriva is offline   Reply With Quote
Old 3rd December 2008, 17:14   #71
dinu2506's Avatar
Thanked: 351 Times
Thank you.
For the features offered, other brands were beyond my budget. I don't have first hand experience with other brands, but I have found the SQ pretty good, no complaints.
I'm not using any protective film, tried initially, but it was difficult to get a 7" one. I did not want to use any cheap ones. I have a steering remote as well, so I hardly use the touch screen except rarely for some tuning options.
Old 3rd December 2008, 18:03   #72
iceman91's Avatar
Thanked: 22 Times
40gb hdd !!!
That is surprising cos the head unit reads only pendrives AFAIK.
I connected my 200gb hdd and it did not read it. The manual also says only pendrives!!!
iceman91 is offline   Reply With Quote
Old 3rd December 2008, 18:10   #73
sathee46's Avatar
Originally Posted by iceman91 View Post
40gb hdd !!!
Though i prefer to use my pendrive, It can read my seagate 160GB External HDD with ease, but for the intial reading time it takes close to a minute.
Old 3rd December 2008, 18:20   #74
iceman91's Avatar
Thanked: 22 Times
wow!!! need to look up on that and try it again.
thank you
Old 3rd December 2008, 19:02   #75
dinu2506's Avatar
Thanked: 351 Times
40gb hdd !!!
The only restriction is that the HDD should be formatted FAT32, so the max capacity can be 32 GB. If it is formatted NTFS, it will not read. I have been using this HDD for months now without a problem.
JVC AVX 44 : iPhone Compatibility? Screwdriva In-Car Entertainment 6 29th June 2009 12:31
JVC AVX-44 Ice'D my Safari VX akhilesh51 In-Car Entertainment 13 27th May 2009 11:48
My landcruiser new JVC-AvX-814 shippy In-Car Entertainment 3 17th January 2009 18:47
New HU JVC AVX-44 Installed, Can I add a alpine 701 processor? Piyush_Vroom In-Car Entertainment 9 16th January 2009 22:57
Jvc Avx 800 Firmware Update dockap In-Car Entertainment 2 12th November 2008 19:45
