Old 28th July 2008, 15:49   #16
Technocrat's Avatar
Thanked: 2,589 Times
@shuvc: One of my friends had the first gen safari & even with a basic system it sounded quite well & to my amusement I saw that he had put 6X9s at front as well as at back
edit: I know ICE gurus will kill me for even mentioning this
Old 28th July 2008, 16:06   #17
tsk1979's Avatar
Thanked: 16,422 Times
Shuvc and techno, on this thread both of you have given me the best solution, which I must demo myself, since it appears to be the best setup for me
Old 28th July 2008, 16:10   #18
Thanked: 294 Times
Door ka mother sister ho jaye ga.
It is a good thing but the door and the door panel will not be able to handle the load and the sound output from the 6x9`s
Old 28th July 2008, 16:10   #19
Technocrat's Avatar
yeah if it works you can even damp the doors with remaining moolah
Old 28th July 2008, 16:11   #20
Bass&Trouble's Avatar
Thanked: 71 Times
Tsk: Knowing you, I am very tempted to say that you are completely, "6x9-in-the-front-door" material.
Old 28th July 2008, 16:12   #21
Technocrat's Avatar
Why not I have heard of 6x9s installed on boot door & they sound well.
So if he damps the panel & door me thinks it should sound fine.
Biggest challenge will be to be able to place the 6x9s in the doors
Old 28th July 2008, 16:18   #22
tsk1979's Avatar
B&T has listened to the setup I enjoyed. He knows
6x9 will be difficult, so I will require circular speakers of 3 way type.
Please suggest some options and budget in them
I guess JBL 8 series will have some, and so will Bull/Rainbow and Illusion.
Now it comes to budget.
Old 28th July 2008, 16:30   #23
shuvc's Avatar
Thanked: 287 Times
3-way , 2-way should not be a criteria IMO. Speaker size should be. But 6"/6.5" round fronts (2 or 3 way) may not satisfy your mid-bass needs - without an amp ie. Hence, go to an installer and be adamant about 6x9 fronts. Ask him how he'll install.
Damping the doors is a must. It would go a long way in giving you that 'body' to the sound; reducing the 'hollowness'.
JBL 937s will probably be among the most VFM and at the same time suit your needs.
Old 28th July 2008, 16:46   #24
simply_sunny001's Avatar
Thanked: 15 Times
Guys
How much damping should be enough for Safari's 2 front doors.
Here i'm talking about damping both innermost + inner layer.
thanks
simply_sunny001 is offline   Reply With Quote
Old 28th July 2008, 16:54   #25
Thanked: 294 Times
Originally Posted by simply_sunny001 View Post
Guys
thanks
About 2 sq meter (21.4 sq foot) would be enough.
Old 28th July 2008, 17:06   #26
jkdas's Avatar
Thanked: 1,436 Times
6x9's , 3 ways!!!
Get the 7 series, you should get it for a good price as 8 is out.
Either way, you will have to damp, wont cost much if you use NoiseKill right?
Now, can someone quote how much if Noisekill is used and how much for its competition.
Old 28th July 2008, 17:27   #27
Thanked: 294 Times
Same quantity but if one is not satisfied then one can double the figure
Old 28th July 2008, 17:56   #28
Thanked: 15 Times
Paaji,he probably meant the cost.
Old 28th July 2008, 18:04   #29
Thanked: 294 Times
That would be Rs 150 per square feet. As mentioned everywhere in the forum.
Old 29th July 2008, 00:01   #30
iraghava's Avatar
Thanked: 156 Times
Tanveer - I would live with the stock ICE & buffer up the budget slightly before going for any upgrades & yes step-by-step is the best method, you'll appreciate every upgrade more.
But basic config remains the same, a decent 4-ch amp (at least 7k unless you can find something good second hand), a set of good speakers up front & a 12" sub.
Anyone can say anything but I can tell you from my listening experience that if you're looking for well-rounded sound, you need the sub to fill in the lower frequencies. No matter how good speakers you might buy, they'll never fill in the lower frequencies like a sub will.
Any minimum age requirement for kids in the Kabini Safari? musafir_blr Route / Travel Queries 3 26th May 2016 16:41
Minimum km running required for diesel cars sumitdongerkery Technical Stuff 30 19th April 2015 20:30
Minimum driving age: Is 18 too long a wait? Rtech The Indian Car Scene 138 12th April 2013 16:36
Minimum Petrol / diesel in tank kARTIK IYER Technical Stuff 27 17th May 2008 16:20
brand new corolla for 7.5 lakhs !! (Minimum order = 10 cars) narayan Sedans 42 13th May 2007 23:09
