Old 29th July 2008, 00:10   #31
nitrous's Avatar
Thanked: 285 Times
JBL GT5 A604 4-ch amp costs 5k in gray.
About as VFM as quality amps can get.
Old 23rd October 2008, 15:31   #32
tsk1979's Avatar
Thanked: 16,420 Times
Finally in november, ICE for the safari will be upgraded.
the budget is 4.5K all inclusive.
So no new HU, no new speakers.
I am seeing clipping with my 9870 even at mid volume, and experts suggest an AMP will do that trick.
So I am wondering, which 4 ch amp with bill and warranty I can find for this money?
No brand preferred, Anything will do, just want some decent sound, need not be out of the world
4.5K limit to budget is very very strict, should include everything.
So please let me know which all amps are sold for this price?
Old 23rd October 2008, 15:35   #33
greenhorn's Avatar
Thanked: 1,516 Times
I still doubt if the HU is the problem. I'd blame the speakers and the way they are installed. get some GT5 or sort of speakers, and make sure the gaps around the install location are sealed(they made aa good difference to my indica) . amping the OE speakers, I doubt if they will help a lot.
Old 23rd October 2008, 15:43   #34
Technocrat's Avatar
Thanked: 2,589 Times
Since you are not bothered about brand & are strict about budget, I would say get any(Sony?) 2 channel amp, this should be in your budget with cables.
Sony 2 channel amp
MRP - 3590
If you want all four speakers to be amped you can use one channel for two speakers you will loose L-R balance control though.
EDIT- the 9870 has just one pre-out so you would need line converter too
Old 23rd October 2008, 16:02   #35
tsk1979's Avatar
Is there some 4ch thingy available for 1K more?
As for speaker vs HU, I suspect sound will improve a lot if I have an amp. the speakers are not being driven to their max yet, its the HU which seems to be the culprit
Old 23rd October 2008, 16:06   #36
Technocrat's Avatar
Probably in Gray but not with B&W
Besides do remember with an amp you will need RCA & power cables as well as a fuse too & also the line converters which will add to the cost.
Old 23rd October 2008, 16:11   #37
greenhorn's Avatar
you mentioned clipping. My 9870 drives the Dieci 6x9's and comps quite well, the indica body panels start rattling first before i reach the part where the HU clips(actually I've never pumped up the volume that far - 18 is as far as i go usually, and beyond 22 is unbearable). that's why i felt the Speakers needed an upgrade.
I wonder what jkdas has to say about this
Old 23rd October 2008, 16:25   #38
tsk1979's Avatar
So you have the same HU greenhorn!
In that case looks like there is a problem with stock speakers.
Can you try playing "Shadow of the Day" by linkin park and see if your HU can do it?
Old 23rd October 2008, 17:58   #39
greenhorn's Avatar
tell me your HU settings, especially the EQ
I run
Bass +4/100 hz
treble -2/10khz
loudness off
balance0
Fader F1
Old 23rd October 2008, 18:00   #40
Thanked: 2,469 Times
If you are talking about the stock speakers, you are wrong, the HU is basic and OK.
The speakers cant even handle a transistor under full volume
Dont waste money on the HU, go in for a nice set of Components and speakers with a 4 ch amp.
Old 23rd October 2008, 18:04   #41
Technocrat's Avatar
Bass +4 lol thats why your panels vibrate
Old 23rd October 2008, 18:08   #42
greenhorn's Avatar
In the indica, the speakers are mounted directly on the plastic door panels, as opposed to other cars where they are mounted on the door itself. Thats the reason for the infernal rattling. even at lower volumes, they add their signature to bassy male vocals .
And i dont have a sub, something has to compensate
Old 23rd October 2008, 19:38   #43
smsrini's Avatar
Thanked: 272 Times
Safari speakers are mounted on a rubber ring attached to the door panel. This acts as a damping material to isolate the speaker from the metal.
smsrini is offline   Reply With Quote
Old 23rd October 2008, 20:46   #44
jkdas's Avatar
Thanked: 1,436 Times
I doubt if you have a bad wiring. I play it at 19-20 when i want to hear it loud. Bass at 1 or 2.
Buy a 4 channel amp which can power all the speakers with just one preamp in.
What you need is really a sub.
Old 23rd October 2008, 20:57   #45
tsk1979's Avatar
I have midrange issues too, not just the bass.
Right now I can either do
1. HU upgrade - Completely useless from audio quality point of view, though a DVD unit will give me more songs. To get more songs I bought a 99rs sun VISOR 10 CD holder, so I can have 10mp3 cds in easy access
2. Component upgrade - I don't think stock speakers are that bad
3. Amp - This is what I feel will fix things. Moreover I don't afford speaker upgrade, so this is the only way to go.
So an amp for 4.5K 4ch with bill and warranty. Does it exist? If so which brand? Any brand will do as long as I can demo it and see the sound in safari.
Any minimum age requirement for kids in the Kabini Safari? musafir_blr Route / Travel Queries 3 26th May 2016 16:41
Minimum km running required for diesel cars sumitdongerkery Technical Stuff 30 19th April 2015 20:30
Minimum driving age: Is 18 too long a wait? Rtech The Indian Car Scene 138 12th April 2013 16:36
Minimum Petrol / diesel in tank kARTIK IYER Technical Stuff 27 17th May 2008 16:20
brand new corolla for 7.5 lakhs !! (Minimum order = 10 cars) narayan Sedans 42 13th May 2007 23:09
