Old 21st August 2008, 11:35   #16
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by kedarwalke View Post
Gurus plz help me if it is advisable to go in for just one 15" DVC?coz m loosing on the space and also m nt getting the desired effect!!!
What is the model number of the subs? And I cant find the 901 amp either.
If the sub is a dual 4-ohm voice coil type, then a GTO monoblock like the 600.1 will drive it very very well. This much bass is usually enough for those that are not abbreviated as L.B.M.
Old 21st August 2008, 15:08   #17
kedarwalke's Avatar
Thanked: 460 Times
The amp is GTO 601.1 and the sub is a GTO1502D.
What is L.B.M?
I just need a good punch with the subwoofer so if i connect just one 15"sub to the GTo601.1...will i get a good punch??
thanks guys...
kedarwalke is offline   Reply With Quote
Old 21st August 2008, 17:27   #18
Thanked: 71 Times
What is L.B.M?
thanks guys...
Hmm. So your original installer was correct in giving you two of these 15s with the 601.1. To get the most out of a single 1502D, get a good monoblock capable of driving about 500+ Wrms @ 1 ohms (your current amp will not work at 1 ohms.) and you should be fine. Another option would be to use a powerful 2-channel amp that can put out 500+ Wrms @ 4 ohms. This could prove a little difficult to find and perhaps more expensive too.
L.B.M. (short for low_bass_makker) is a generic term on this forum to describe a creature that is dissatisfied with any amount of bass. Often spotted in North India with a silver Swift, and with food laid out on the rear seat.
Maybe this would shed some light. http://www.team-bhp.com/forum/sound-...tml#post656719
Old 21st August 2008, 18:23   #19
kedarwalke's Avatar
Thanked: 460 Times
Lol freedabaadwaale LBM...funny...i will try the output with a single sub and decide accordingly....also if some1 tell me where do i get the projector lamps for my accord?
Old 21st August 2008, 19:36   #20
Thanked: 71 Times
Be careful while hooking up the sub. If the coils are in parallel, you will fry the amp.
Old 26th August 2008, 22:43   #21
kedarwalke's Avatar
Thanked: 460 Times
Default Subs
Thanks everybody for your help and support.I have been crusing and enjoying music with 2 subs so I have made up my mind to keep 2 subs.
Thanks once again T-bhpians!!!
Old 28th August 2008, 10:40   #22
dinu2506's Avatar
Thanked: 349 Times
Does putting a grill on the woofer affect the sound quality?
I don't think it matters. Make sure it is fastened well and does not vibrate.
dinu2506 is offline   Reply With Quote
Old 1st September 2008, 14:40   #23
kedarwalke's Avatar
Thanked: 460 Times
Default troubleshooting
When I am listening to songs on my sony dvd player,evrything is fine but suddenly when i flash the dipper or on the fog lights the system shuts completely and restarts.It doesnt shut everytime i flash the dipper but ocassionaly.I called up the installer he says that the problem is with the battery.can you guys plase confirm,coz I do get the low battery indicator at times on the odometer.
Please help
Installing a single-din player into a double-din slot rattimehra In-Car Entertainment 21 29th April 2016 21:09
Double Din DVD HU Thread: JVC KW-AVX800 \ Alpine IVA-W200 \ Pioneer AVH-P6850 vittalnrv In-Car Entertainment 95 14th April 2015 20:06
double din player for optra viralraj In-Car Entertainment 1 30th May 2006 19:24
Info about Using 1 din slot to use a 2 din HU shalini_g In-Car Entertainment 30 10th March 2006 21:47
