Old 29th August 2008, 12:25   #16
CaliforniaKnight's Avatar
Thanked: 46 Times
If you cannot audition a car with Polyglass woofers take a trip down to a good audio store that carries a brand called JM Lab and audtion some of JM Lab's speakers.
Hi Navin,
The Focal that I am planning to install is indeed the FOCAL JM LAB speakers.
Did hear them and sounds great.
check the link Focal
CaliforniaKnight is offline   Reply With Quote
Old 30th August 2008, 10:54   #17
BHAGWAN's Avatar
Thanked: 13 Times
Default perfect suggestion !
Originally Posted by low_bass_makker View Post
Nice combo, But I would go for a sub rather than rear speakers
I would second this suggestion.
Buy 'better' front components;
Go up on the Amplifier 'series'
Buy a Sub with a good Mono Amp
This will be a great set up.
BHAGWAN is offline   Reply With Quote
Old 30th August 2008, 22:52   #18
Thanked: 46 Times
I hope you all get the message...
The accord stock stero is ok till volume 10, when you 'push' it to say volume 17- 18,its like they sound flat.I just want a bit more thump with the new setup and I am not looking for earth shattering bass.Just clear sound the correct blend of midrange, treble and bass.
Old 31st August 2008, 09:00   #19
BHAGWAN's Avatar
Thanked: 13 Times
Arrow RCA Pre outs ??
Originally Posted by CaliforniaKnight View Post
I
Does your H.A. [Honda Accord] have RCA pre outs from the H.U. ?
How do you plan to attach a Power Amplifier to it ?
Old 31st August 2008, 23:44   #20
Thanked: 46 Times
I guess they are installing Audio Control DQL - 8 for the same.
Isnt there any other possibility though?
Old 1st September 2008, 02:43   #21
Thanked: 21 Times
Audison LRx has built in high level inputs, you don't need a Line Output Converter like the DQL8. The only reason you will need the DQL is if the installer wants to EQ the system.
Old 1st September 2008, 08:49   #22
BHAGWAN's Avatar
Thanked: 13 Times
correct - perfect 'gunbir' !
Old 18th September 2008, 19:50   #23
Thanked: 46 Times
An Off topic question here..
I have received a headunit (only) from Dodge;this is the MYGIG REZ series.Any possibility to connect this unit to another car, I mean not a dodge, chrysler or jeep brand??I will upload the picture of the same shortly so that you can see the front and rear of the unit to help suggest a reply.
Thanks.
Old 21st October 2008, 23:56   #24
Thanked: 46 Times
Got the Lrx 4.5 today and i am waiting for the focals now.This should be arriving in 5 days hopefully.
What do you all suggest about a powered subwoofer, Or is one powered via a mono block better?
Old 22nd October 2008, 00:44   #25
iraghava's Avatar
Thanked: 156 Times
I would go in for a good woofer powered via a mono block in a sealed box any day. Especially considering that the rest of your equipment is pretty good.
Old 22nd October 2008, 10:42   #26
Thanked: 294 Times
Bhaiya Ji in ICE land. Good to see you here.
As Ishan suggested get a good sub rather than a powered one.
Old 22nd October 2008, 10:56   #27
navin's Avatar
Thanked: 4,286 Times
haha I see the tyrewalla lost his way. still it is good advice.
Ishanji, have you ever done a study on which tyre produces the least road noise? Intuition tells me nylon belted radials would be less noisy than steel belted radials.
navin is online now   Reply With Quote
Old 22nd October 2008, 16:46   #28
iraghava's Avatar
Thanked: 156 Times
You really want me to answer that here??
Anyway, the construction does play a part in the tyre noise but I think what plays a more significant part is the tread design since the majority of the noise produced is by the impact of the tread meeting the road surface. And I think with the introduction of Silica, the latest gen steel belted radials have the edge over nylon tyres. Not to mention better resistance to punctures.
Old 22nd October 2008, 22:25   #29
navin's Avatar
Sure road noise changes the way a system is tuned and might also affect the degree/type of damping required.
We at TBHP intend to cover every aspect of car audio.
A few days ago a audio enthusiast (who shall remain un-named) mentioned (within my ear shot and not knowing that I was a TBHP member) that "TBHP is the bleeding edge of Indian car audio". Gunbir, Sam, B&T, LBM, Raven and all of you take a bow!
Old 22nd October 2008, 22:41   #30
Thanked: 46 Times
He he. One among the last questions.Which is the best locaton to fix the Lrx 4.5? the guy advices its better underneth the front passenger seat.But i am a bit worried if it will eat up the rear foot rest area.Tried to fabricate to either side of the boot but then I cant take the tool kit fixed on both sides.
Punto ICE - Focal Access 165 A3 + Focal Solid 4 AMP Crimson In-Car Entertainment 90 5th September 2017 21:04
SnapDeal now selling car audio (JBL, Auditor, Infinity, Focal etc.) Enigmatic In-Car Entertainment 13 21st May 2014 10:51
Focal speakers vikram18 In-Car Entertainment 29 10th January 2014 10:17
Alpine 9855+Focal 165KPS.. Need some help on the Amps skyliner In-Car Entertainment 14 13th May 2007 00:03
