Old 6th July 2009, 23:35   #226
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by low_bass_makker View Post
... Try the fiber glass in the current location you would see a difference of day and night. ...
Bhai McLBM, this needs some more illustration to understand, sir.
Old 7th July 2009, 14:41   #227
Bass&Trouble's Avatar
Thanked: 71 Times
LMAO!
I think he means to say Ashok should make fiberglass tweeter pods attached to the same point on the A-pillar to aim the tweets a bit more towards the cabin. Could be wrong. I'm not sure what McLBM () latest tweeter mount is.
Old 7th July 2009, 15:10   #228
jkdas's Avatar
Thanked: 1,436 Times
OT; isnt it time to upgrade? The HU for a change.
Old 7th July 2009, 16:01   #229
PatienceWins's Avatar
Thanked: 285 Times
Thanks for the pictures. It looks nice!!
PatienceWins is offline   Reply With Quote
Old 7th July 2009, 20:19   #230
hydrashok's Avatar
Originally Posted by karankapoor View Post
...What is on the wall where the boot lids closes looks like a neon to me, If yes then post some more pics with it.
Thanks, KK! Yep, that is a neon strip. Here's a pic. The light is actually quite a bit brighter, but I could not get the pic to come out that well. I'm pretty much dumb around cameras
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine,  Image Dynamics, TRU Tech-bootnight.jpg
Originally Posted by Flying Bong View Post
Very nice
What crossover point, slope and tweeter levels are you using?
Thanks, FB! Can't hold a candle to your setup, though!
The speakers are crossed over at 80hz, 12db/octave. The tweeters are attenuated to -7dB in the XO.
Hydra you might be very happy with the tweeter location you are having but you are missing a lot. Try the fiber glass in the current location you would see a difference of day and night. Since I also used to have them in the same location but now changed. And I am loving it.
I guess I will try out an FG pod sooner or later and I do know it will most likely sound better that way. This is just a "best compromise of all factors" for the time being. Do post some pics of the way you've installed the tweeters in pods.
Originally Posted by akbaree View Post
I believe there's a wooden plate on which you have fitted the amplifiers. How has the wooden plate fixed to car's body?
Thanks, akbaree! My installer has a few custom-bent clamp-like things that he uses to screw the boards that way. One end of the clamp gets screwed onto the body, and the board is screwed onto the other end of the clamp.
Not really! But yes, I am generally happy with everything except the HU. When I upgrade the HU I'll probably get something more serious (which will cost quite a bit more) and I'll need to brace my pockets for that. Recession, marriage and all that, heh heh.
Thank you!
Old 7th July 2009, 20:23   #231
frankmehta's Avatar
Thanked: 2,334 Times
hi anupji! the ONLY thing left, is to listen to this setup. looks yummy and I AM DEAD SURE it sounds even better than it looks! cheers..
PS: Neons are cool, especially when they are lighting some solid Tru Steel amplifiers ;-)
frankmehta is online now   Reply With Quote
Old 7th July 2009, 20:28   #232
greenhorn's Avatar
Thanked: 1,519 Times
i never thought I'd see the day when there would be bling installed in hydra's ride
Old 7th July 2009, 20:39   #233
JayD's Avatar
Thanked: 2,008 Times
Originally Posted by frankmehta View Post
hi anupji!
Who on earth is Anup, and what is he doing in Ashok's ICE thread??
Oh, then i guess you've missed hisSPL setup too. It really was something. right Ahsok???
* runs for cover *
Old 7th July 2009, 20:41   #234
frankmehta's Avatar
hehehe.. let 'ashok' come and clear that one out ;-)
Old 7th July 2009, 22:42   #235
DerAlte's Avatar
Neither did I. But, things change after marryage, right? One stops living for self-satisfaction only!
Originally Posted by JayD View Post
Who on earth is Anup, and what is he doing in Ashok's ICE thread??... * runs for cover *
Ah so ka? Oh no, here we go again!
Old 8th July 2009, 09:49   #236
hydrashok's Avatar
Thanks, Frank
@greehnorn, hey, a little bling never hurt anyone
* runs for cover *
You better! You can run, but you can't hide. *reaching for the baseball bat*
You stole the words from my mouth!
Old 8th July 2009, 12:01   #237
Flying Bong's Avatar
@hydra - trust me, you have some fabulous equipment thats very well installed, what would be nice is a HU upgrade (P80 or Nak CD700) especially the latter since you are going with a passive front stage...
I was interested in knowing the crossover point for the tweeter. While using XS in my car I had found 3.5-4Khz optimal, if I remember correctly.
Flying Bong is offline   Reply With Quote
Old 9th July 2009, 10:28   #238
hydrashok's Avatar
^^ Thanks again, FB! The next upgrade would definitely be a HU upgrade.
The Tweeter's filter is set at 3.9kHz in the XO (probably the same as yours -- the setting just below it is 3.5kHz). Getting the settings right in the XO is definitely a long-drawn-out exercise
Old 13th July 2009, 15:18   #239
iraghava's Avatar
Thanked: 156 Times
Hey ASHOK nice to see you going over to the bling side!
*starts Gabbar to run away*
Old 26th July 2009, 11:54   #240
maxbhp's Avatar
Thanked: 65 Times
Amazing work Anup . Nice to see the spirit still alive even after being Mrs-ised . I am curious about one thing though . Shouldn't the tweeter be facing the person for better sound reproduction (by using pods) or is it better that it faces the glass. I can understand that poor quality tweeters produce lots of hissing and pissing sounds and hence its better to have its face towards the glass but since your components has good/true sound reproduction capability , shouldn't the tweeters be facing inwards towards each seat ?
maxbhp is offline   Reply With Quote
Guru's take on Tru Tech 4.65 kiran1103 In-Car Entertainment 6 7th May 2010 18:12
A Swift Shift: Hydra's Hatch II hydrashok Test-Drives & Initial Ownership Reports 140 26th May 2008 11:19
My Alpine + Audison + Image Dynamics Setup cancerm In-Car Entertainment 67 4th January 2008 16:05
GOT ME A Image Dynamics IDQ 10 inch!!!! sk456 In-Car Entertainment 26 25th July 2006 14:40
My New Image Dynamics IDQ 12.v2 Pics Tool In-Car Entertainment 58 20th June 2006 13:43
