Old 25th August 2008, 12:54   #16
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by Screwdriva View Post
Phase 2:
Sub : Something that fits under the First aid storage area, probably an 8" sub
Amp: Not sure of which amp to get but it will probably power the rear components and the sub. Any recommendations?
Congrats on the upgrade. Which series Boston comps are these?
If you are not already using an amp, use a small amplified bass tube, or get some customization done to install a small 8" sub on the side of the trunk with a 2-channel amplifier.
Old 25th August 2008, 13:35   #17
nitrous's Avatar
Thanked: 285 Times
Originally Posted by screw
Front Speakers: Boston 5.25" coaxials
Rear Speakers: Illusion Audio 4.1 Components
Hope this is a mixup and its the other way around.
Old 26th August 2008, 00:47   #18
Screwdriva's Avatar
Thanked: 377 Times
Default Nope
You read correctly. Didn't want to drill any holes in the front, so no composite tweeter.
The coax's work great though. Much more audible in the front vs. the Illusions (have to fade the rears a bit for it to sound balanced) with reasonable crisp sound.
I bet the 4 channel amp + Sub will change the nature of the sound completely
Screwdriva is offline   Reply With Quote
Old 26th August 2008, 10:09   #19
navin's Avatar
Thanked: 4,286 Times
What about a 5/6 ch amp and a sub. This way all speakers will be driven by an proper amp.
Old 26th August 2008, 23:21   #20
Screwdriva's Avatar
Thanked: 377 Times
Sure, but the fronts are reaaaally loud right now. Still, worth a second look.
For now, the Amp we've targetted is the JBL 604 JBL Car & Marine Audio
Old 27th August 2008, 10:18   #21
navin's Avatar
add this when able
Alloys for W124 Mercedes Benz Machdar Tyre & Alloy wheel Section 24 3rd January 2017 19:42
My E220, W124 Benz, in Bangalore - long term review achtung Long-Term Ownership Reviews 77 11th May 2016 16:39
W124 Mercedes benz E220 ignition coil msaudf Technical Stuff 2 18th May 2009 20:43
My Ride NEEDs some Help Jatt Tyre & Alloy wheel Section 3 5th June 2006 00:51
