Old 25th August 2008, 17:06   #16
nitrous's Avatar
Thanked: 285 Times
If the amp is too powerful, 125hz for a 4" speaker.
Else 100hz should do.
Old 25th August 2008, 17:44   #17
Thanked: 41 Times
Originally Posted by abhibh View Post
Well then you need to HPF the speakers at 80hz or 100hz in the case of 4" coax.
Its better to get 6.5" compos rather than 4" IMHO.
will 6.5" will work better than 4" in HPF ?
i think they both will be same as there is not bass from the speakers. its just the vocal and treble comming form the compos.
monty9991 is offline   Reply With Quote
Old 25th August 2008, 22:48   #18
navin's Avatar
Thanked: 4,346 Times
For a 4" speaker set the HPF to about 125Hz/12db for a 6.5" speaker you can get an octave lower (63Hz/12db).
Even under these circumstaces you might find the 4" "giving up" before the 6.5" does.
Old 26th August 2008, 13:39   #19
Thanked: 41 Times
thats ture about 4" giving up if compared to 6.5", i really dont want to cut the doors. or i can use the rings to install on top of the stock location but will look ugly and pagli.
is there any way of holding the 6.5" under the dash some where, while facing to wards the passenger or up like the stock position?
Old 26th August 2008, 18:07   #20
abhibh's Avatar
Thanked: 34 Times
One option without cutting doors is
http://www.team-bhp.com/forum/vbpgim...6&d=1209301555
Dhar's Alto
2005 Alto Lxi - Dhar's's Photo Gallery - Team-BHP
Old 26th August 2008, 19:03   #21
Thanked: 41 Times
nice option for not cutting doors, but not my choice. lets see what i can find more about it.
Sound from the Front Component Speakers not Satisfactory OHCVtec In-Car Entertainment 4 17th December 2010 11:24
Front Component Speakers for AVEO 1.4..need advice s3va In-Car Entertainment 2 6th October 2009 15:16
4-channel Soundstream Amp For Sale & MB Quart Q-Line 6.5" Component System QSD216 Bass&Trouble Shifting gears 7 19th March 2008 09:27
Component System for Esteem Flintstones In-Car Entertainment 7 5th February 2008 13:13
Component System for NHC srasania In-Car Entertainment 22 4th July 2005 10:30
