Old 13th June 2014, 17:10   #76
DerAlte's Avatar
Thanked: 2,879 Times
Default re: ICE upgrade : Tata Indica Vista
Originally Posted by man_of_steel View Post
But this new wire was used for wiring between the speaker - crossover and the tweeter in its new position.
All that comes in the box - not possible for that to go missing since there is a designated place for everything in the box. Could be missing, but only if the vendor you bought from had opened the box and forgot to pack it back, or has given you a used or display piece. Can happen, but difficult to believe.
The wire supplied is always more than one would actually require in the usual locations. In your case, the original wire would connect to the XO input, and the wires in the box would be used from XO output to midbass and tweeter.
Next time, please open the box and check the contents before taking it to an installer.
DerAlte is offline   (1) Thanks Reply With Quote
Old 13th June 2014, 17:18   #77
man_of_steel's Avatar
Thanked: 1,090 Times
It was a purchase from SnapDeal have to be more careful next time! :(
And as you said. I think the vendor might have taken it out for someone else just like how the installer took wire from one box and gave me!
[EDIT]
Wait.... Just went through your post again. I think I saw the guy directly connecting the stock speaker wire to the midbass. and then 2 wires were tapped from this 2 wires to the XO-s and from there to the tweeter. Did he just screw everything up???
man_of_steel is offline   Reply With Quote
Old 3rd May 2015, 02:00   #78
Thanked: 13 Times
Red face Vista D90 Audio Upgrade
I am planning to upgrade the audio experience in my Vista D90 ZX+. It has a blaupunkt New York HU which came as stock(pic attached) - has got BT, Navigation, etc - so I don't plan to touch it.
Currently my thought is to change the speakers, add an amp (is it needed?) and maybe a sub woofer (again - is this needed?).
The stock speakers on all 4 doors seem really bad. To start off, I plan to change them into something good and powerful. The size of the cut is 5.4", so I am restricted to find only speakers of that size (don't plan to alter anything).
Front Speakers:
[Shortlisted] HERTZ CAR COMPONENT SPEAKER DSK 130.3 - Peak W 120 Continuous W 60
[Other Option] Blaupunkt Car 5.4" Inches 2-Way Component Round Speakers-CX 130 - Rated Power : 53 WattsPeak Power : 240 Watts
Back Speakers:
[Shortlisted] Hertz ECX 130.5 Speakers - 150 Watts Peak/50 Watts
[Other Option] Hertz DCX 130.3 (DCX130.3) - W peak: 80 / W continuous: 40
[Other Option] Polk Db521 - Continuous 45 watts Peak 135 watts
Please suggest if my shortlisted ones are fine or I should check something else?
Once I am done with the above, I plan to get an amp. Below are some options I am thinking.
[Shortlisted] Sony - Xplod - XM-N1004 - 4 Channel Bridgeable Amplifier - 1000 W
[Other Option] JBL - GX-A644SI - 4 Channel Power Amplifier -1000 W
[Other Option] Blaupunkt Car 600 Watts 4 Channel Amplifier-EMA 455 - 600W
[Other Option] Blaupunkt Car 840 Watts 4 Channel Amplifier-GTA 470 SF - 840 W
[Other Option] SONY CAR AMPLIFIER XM-GS400 - 675W
Finally, the sub-woofer. I don't want to compromise the boot space - hence confused between an enclosed model and a tube model.
[Other Option] Sony - XS-NW12022E In Car Subwoofer Box
[Shortlisted] Rockford Fosgate Car Bass Tube RF-1400T
Overall, the entire shortlisted setup comes to abou 13k. I will need to spend on getting this fixed & wiring, etc - not sure how much that would come upto. Btw, the accessories above are all planned to be purchased online - so not very sure if all will work together well.
Please give your valuable suggestions.
ICE upgrade : Tata Indica Vista-dsc_1988_js.jpg
jasonblr is offline   (1) Thanks Reply With Quote
Old 11th May 2015, 23:17   #79
Thanked: 13 Times
Any advice folks for the above components I have mentioned?
Almost thinking of ordering now but would like to have your valuable suggestions before that.
jasonblr is offline   Reply With Quote
Old 12th May 2015, 16:45   #80
DerAlte's Avatar
Originally Posted by jasonblr View Post
Any advice folks for the above components I have mentioned? ...
Have you auditioned the speakers before short-listing?
* Hertz can be painfully bright (shrill) for some
* Blaupunkt is neutral sounding
* Don't buy a bass tube. Get an Infinity 1260W or a JBL sub and mount it in a sealed box. Infinity, Polk, etc. also have a pre-built subwoofer in sealed boxes, though they cost more than buying the sub and getting it mounted in a local box
* Don't buy a Sony amp. A JBL, Blaupunkt, Infinity, Kenwood, even a Pioneer, would be far better
Old 13th May 2015, 09:44   #81
Thanked: 13 Times
Talking re: ICE upgrade : Tata Indica Vista
Below is the Audio Stack I picked up finally for a great price.
Sony - Xplod - XM-N1004 - 4 Channel Bridgeable Amplifier - 1000W
Hertz ECX 130.5 Co-axial Speakers - 150W
Hertz ESK 130.5 Component Speaker - 225W
SONY CAR SUB WOOFER XS-NW12002 - 1200W
ICE upgrade : Tata Indica Vista-img_20150512_172013-1.jpg
Sony - Xplod - XM-N1004 - 4 Channel Bridgeable Amplifier [Price Paid: Rs. 3635 ]
70W x 4 RMS at 4 Ohms1
85W x 4 RMS power at 2 Ohms
70W x 2 + 175W x 1 RMS at 4 Ohms
[Price Paid for both component & co-axial speakers together Rs. 7605 | But the stock was late 2013 - speaker's don't expire I think ]
Hertz ESK 130.5 (ESK130.5) 5.25" 2-Way Energy Series Component Speaker System
ESK-130.5 - Hertz 5.25" 450W Peak 2-Way Component Speaker System
Power Handling Peak: 450 watts per pair / 225 watts each | RMS: 150 watts per pair / 75 watts each
Frequency Response 70Hz 23kHz
Woofer Voice Coil 1"
Woofer Magnet Size 3.15 x 1.26 x 0.5
Hertz Audio ECX 130.5 (ECX130.5) 5-1/4" 2-Way Energy Series Coaxial Speakers
ECX-130.5 - Hertz 5" 2-Way 50W RMS Coaxial Speakers
Power Handling Peak: 150 Watts | Continuous: 50 Watts
Woofer Magnet: High density flux ferrite
Water-repellent treated paper cone, butyl rubber surround
Mounting Depth: 1.96"
Sony - XS-NW12002 - 30cm In Car Subwoofer (1800 Watts) [Price Paid: Rs. 2075 ]
Peak Power 1800W
Rated Input Power 300W
Subwoofer Box (Cone)
Frequency Response: 32Hz-1000Hz
Impedance: 4 ohms
Planning to get it installed at Sachin's, Bengaluru.
I have picked the Sony after reading a lot of online reviews - except for the heading issue the price - value was good. But would love to know why not the Sony.
Old 13th May 2015, 15:40   #82
DerAlte's Avatar
... would love to know why not the Sony.
Congratulations!
Don't want to rain on your party. Enjoy good music - hope you don't get to know the "why not" anytime soon.
DerAlte is offline   (3) Thanks Reply With Quote
Old 28th May 2015, 13:05   #83
I have personally used the Infinity Kappa 120.9 W sub-woofer in a 1 cb.ft sealed box. It is one of the best SQ sub-woofer for the price range in which it is available.
Last edited by ampere : 28th May 2015 at 13:09. Reason: Formatted post. Also removed entire quote
santhosharulvan is offline   Reply With Quote
Old 28th May 2015, 14:13   #84
Just realised you have already purchased the Sony subwoofer. Enjoy your ICE
Old 17th September 2015, 22:31   #85
narayan's Avatar
Thanked: 1,356 Times
Guys what is the max speaker size the Vista can take ? Have bought a Bolt and I guess the slots are of same size. Will 6.5" fit ?
narayan is offline   Reply With Quote
Tata Indica xeta versus Tata Vista SAFIRE 65 rohantn Hatchbacks 17 16th November 2011 01:53
Help Required Indica Vista Safire or Indica Vista TDI Logical Hatchbacks 63 30th October 2011 08:57
First official pics: Indica Vista EV CVT, LHD Vista Interior for Euro markets sidindica The Indian Car Scene 30 5th June 2010 21:03
Indica Vista Official Brochure! EDIT: Vista Now Launched sidindica The Indian Car Scene 233 24th August 2008 18:49
