Old 4th September 2008, 10:58   #16
manojgautham's Avatar
Thanked: 11 Times
Originally Posted by blueraven316 View Post
That Infinity sub is a single 4 Ohm and its churning only 175 RMS from the mono so this effectively has made as powerful as an average 2 Channel amp.
What you need (if you retain the amp) is to get a pair of Dual coil 4 Ohm subs all connected in parallel. OR a single dual 2 Ohm DVC subwoofer connected in parallel to get the peak output from this amp.
I initially thought you had a JBL GTO301.1 amp.
What do you suggest Satya? I might be coming towards Indiranagar today. Will meet you around 1:30pm if possible.
manojgautham is offline   Reply With Quote
Old 5th September 2008, 10:04   #17
Ajaybiz's Avatar
Thanked: 148 Times
Satya those DVC infinities are available in Bangalore?
Ajaybiz is offline   Reply With Quote
Not happy with thump effect need help viraj_s85 In-Car Entertainment 29 20th March 2010 03:27
Ford Fiesta - Thump sound on braking calvinkrishy Technical Stuff 6 21st July 2009 22:50
More thump from AVL engine alpha1 Motorbikes 11 4th November 2008 12:13
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
