Old 5th September 2008, 12:54   #16
navin's Avatar
Thanked: 4,351 Times
Originally Posted by nitrous View Post
You came to the wrong part of town,pal.
chill nitrous, give the man a fair hearing.
Old 15th September 2008, 10:49   #17
undead's Avatar
Thanked: 168 Times
I enquired the prices of two amps.
JBL GT5 604 - Rs.5500 ( without B&W )
Blaupunkt GT4 - Rs.6000 (without B&W)
Is it ok ?? He says the wires will cost around Rs.1600 .
undead is offline   Reply With Quote
Old 15th September 2008, 11:00   #18
Thanked: 44 Times
Originally Posted by chiragh_bir View Post
JBL amps tends to overheat and cause trouble, many guys have faced this problem .
Not me.
Have used a JBL CS 60.4, 4-channel for over a year. On one trip to Hampi from Goa it was used for about 12 hours every day, accounting for stops, for 6 days - never even hiccuped.
Mounting position is important, there should be no obstruction to airflow to cool the amp, and of course, proper and tight wiring.
filcord is offline   Reply With Quote
Old 15th September 2008, 14:01   #19
razor4077's Avatar
Thanked: 259 Times
I've used a JBL GTO 75.4 for 1.5 years. No overheating problems whatsoever (touchwood).
razor4077 is offline   Reply With Quote
Old 17th March 2010, 22:36   #20
undead's Avatar
Thanked: 168 Times
Default Ice Upgrade For My Getz
Hi guys ,
I have a Sony CDX 470 US ( With USB and Aux) Head Unit , in my Getz CRDi . I want to install FRONT SPEAKERS only . Kindly Suggest me a good quality front speaker that will go good with his headunit. Coaxial or Component ?
NO Rear speakers. NO Sub . NO amps.
Old 18th March 2010, 01:05   #21
ramie2400's Avatar
Thanked: 58 Times
Instead of investing for front speakers i would reccomend you can go in for basic 2-way components,getz can accomodate 6.5"inch comps in the front door added with MDF spacer rings,this will anyday sound better than installing coaxials.There are several brands available which will be compactable with the Sony 470US..
Ramie
Old 18th March 2010, 01:12   #22
blueraven316's Avatar
Get some good component speakers within a 6k budget, and then get rid of that player, Sony is just not the types for any good sound quality.
blueraven316 is offline   Reply With Quote
Old 18th March 2010, 10:16   #23
undead's Avatar
Thanked: 168 Times
Thanks guys.
One doubt. If i install components , then i have to install Amps , right? Because , the HU power will not be enough to drive the powerful component speakers.
Old 18th March 2010, 16:13   #24
DerAlte's Avatar
Thanked: 2,880 Times
Not at all. Amps will definitely give a better experience, however the HU amp can decently drive components for moderate listening.
Old 19th March 2010, 10:05   #25
undead's Avatar
Thanked: 168 Times
Will i get a decent quality sound ,(not looking for a great bass effect stuff ) IF i install JBL GT5-S265 in all the four doors ? I dont want the parcel tray as i often fold the rear seats to carry some big stuffs .
My Sony HU gives out 52Wx4 Power .
This speaker has the following specifications :
Size 165mm
Nominal Impedance 4 Ohms
Power Handling, Peak 200W
Power Handling, RMS 45W
Sensitivity (2.83V/1m) 93dB
Frequency Response 55Hz – 20kHz
Mounting Depth 56mm
Please advice . Or shall i go for JBL GT5-S205 ? I am under some 5000 to 5500 budjet.
Old 20th March 2010, 09:25   #26
Thanked: 21 Times
Hi ,
I too have a getz Crdi. I am running JBL's component speakers in the front powered by a amplifier.
It's not because of the loudness that the amp is required, but for the "depth" of sound. The sound quality is truly amazing. You could even fix an used amp which costs about ~ INR 1500 along with the components.
Good Luck.
mjkaushal is offline   Reply With Quote
Old 20th March 2010, 12:31   #27
ariendj's Avatar
Thanked: 83 Times
dont want to steal the show away the but just a doubt.
im in a similar fix and have three components in mind,
Illusion electra 6.1 or JBL 608c or polk 6501??
which will be best and at what price!!
ariendj is offline   Reply With Quote
Old 1st April 2010, 19:25   #28
undead's Avatar
Thanked: 168 Times
Well . I bought the JBL GT5-S265 for my rear doors .
Rs. 2500 WITH WARRANTY .
Winters are here : Getz CRDi getz some iCe! aZa In-Car Entertainment 68 22nd December 2010 00:23
Getz ICE upgrade - Alpine HU, IDQ sub and Eclipse mono PatienceWins In-Car Entertainment 29 23rd August 2008 20:59
Suggestions for ICE upgrade - Getz PatienceWins In-Car Entertainment 43 15th July 2008 16:56
Getz prime 1.3 is overpriced than previous getz ( old one )? hrishig The Indian Car Scene 3 30th April 2007 10:29
Getz New Launch + Getz vs Swift.. scorp 1 Hatchbacks 18 23rd August 2006 11:34
