Old 11th September 2008, 14:18   #31
abhibh's Avatar
Thanked: 34 Times
Originally Posted by nitin.dangayach View Post
Well instead of having a separate enclosure, do we have some option of the company fitted sealed enclosure with sub ? I guess the company fitted stuff will be far more efficient.
Also what about the cables and all ? What all will I need ?
Nitin its better to get custom made box according to specs. Almost all the JBL subs require 1cubic feet box around 29 ltrs Sealed box. You can get one easily.
Regarding cables you will need:
- Power cable x 1
- RCA x 2 (if you are going for 4 ch amp and wanna connect 1 set speakers too)
- 3 - 4 foot of speaker cable for connecting sub to amp.
You can use L&T or Finolex cable as power cable. It will cost around Rs 500 at max for 4 gauge. RCA even desi boss one works good if you dont wanna spend too much money on wiring. Any speaker cable costing rs 10 per feet will do for connecting sub to amp.
Total wiring will cost around ~1k
Don't go for DESI ALPINE AMP if you wanna spend money 1 time. The Blau amp suggested by chirag is very good considering its costing 4.8k with B/W but it might just be too big for an Alto, not sure though (it looks big).
So current cost breakup
Amp - 4.5 -5K
Sub - 2.5k - 2.8K
Wiring - ~1K
Install - Rs 500 - 1000
Whooping 1.8K above budget. Welcome to ICE section
Originally Posted by low_bass_makker View Post
It is for 8.5k approx, Also the sub is 200 watts rms. One can get better options in 8.5k
AFAIK higher RMS values doesn't always means better sub.
Old 11th September 2008, 16:12   #32
mohang_j's Avatar
Thanked: 18 Times
Guys trust me, I m totally confused. I cant cross the budget. If the SW itself is 7-8K, and cables demand at least 2K, my budget will get exhausted in these two itself. I need an AMP as well
nitin
You can go for GTA4 amp, recently i brought it (2nd hand). I had JBL CS60.2 driving my CS1204 SUB. It is sounding better with GTA 4 now.
Cost was 2200Rs for CS1204, 3000Rs for JBL CS60.2, DIY mdf box around 500Rs, Power wire (used Teflon coated wire rated 60A 5mtr) 50Rs/mtr,If you can try for MX RCA 300Rs or EFX 500-600Rs, In line blade fuse+holder 100Rs, speaker wire 75Rs/mtr 12gauge MX.hope this helps.
mohang_j is offline   Reply With Quote
Old 11th September 2008, 17:34   #33
Awaiting Email Confirmation
Thanks for the exhaustive reply Abhib.
* The pics you psoted are not showing up. Perhaps some issue with the TBHP.
Mohang_J, even I am thinking on that lines. I should look out in the classified section more often :P
nitin.dangayach is offline   Reply With Quote
Old 11th September 2008, 17:37   #34
BTW I have Dynamat Door Kit lying with me. Since I am not using any speakers in the doors (the polk 4 inchers are in the dash / stock location). I am planning to sell that for 4K and can increase the budget.
Is it advisable??
Old 11th September 2008, 17:58   #35
Bass&Trouble's Avatar
Thanked: 71 Times
Is it advisable??
Excellent idea.
Old 11th September 2008, 18:00   #36
i know its fake delhi made stuff but its not bad at this reasonable price.
harry2223 is offline   Reply With Quote
Old 12th September 2008, 08:55   #37
panky12345's Avatar
Thanked: 150 Times
Please!!!! They're NOT delhi made fake stuff, they are imported from China. Delhi has its own pride of "genuine" Ahuja speakers!
Old 12th September 2008, 09:29   #38
Thanked: 21 Times
Nope. They are in fact made in the NCR.
Old 12th September 2008, 10:01   #39
panky12345's Avatar
Thanked: 150 Times
WOW! Thats a news gunbir! Where?
I sincerely hope our dear LBM is not behind this!
Old 12th September 2008, 10:58   #40
Thanked: 294 Times
Hmm I am not behind it but few of the machine we manufacture are used in making them.
Old 12th September 2008, 15:46   #41
Wake up guys. The thread is going astray.
Anyway, from my research, I found that its not a good idea to buy a "chalu" amplifier and a sub, for just the sake of it.
I have changed my plan. I am now planning to go only for an amplifier for the nonce. Hoping that the current setup will sound better. I'll add an amp later.
Now in the same budget (8K), I need a 4 channel amplifier + wiring.
The wiring should be like if at anytime i get a sub, i should be able to hook it in directly, without going to an installer. So assume that I am addind everything including a 4channel amp, wiring and a sub, just that the sub has been put out of the boot for a while :P
Any choices now ?
Also since two channels of the sub will be bridged for the sub, will it be better to amplify the fronts or the rears, from the rest of the 2 channels ?
The fronts are 4 inchers but I have heard people saying that they sound lot better when fed properly.
The rears are also grt speakers but then I think that when I'll buy a sub, the rear fill will automatically be taken care of.
ANybody have a different opinion / suggestions ?
Old 12th September 2008, 16:03   #42
chiragh_bir's Avatar
Thanked: 70 Times
then you pick blaupunt amp + scosche wiring !!
chiragh_bir is offline   Reply With Quote
Old 12th September 2008, 16:09   #43
Prices ? Availability
Old 13th September 2008, 15:58   #44
abhibh's Avatar
Thanked: 34 Times
Nice to see that you have done research and not buying DESI amp.
Again u have 3 options for amp.
1. Blau MKII
2. JBL A604
3. Kenwood 8401
Choose the one that fits your budget. All of them sound similar.
As for wiring if you don't wanna spend too much on the wiring kit like 4 - 5K for schosche, then Get L&T, Finolex 4 gauge power cable from local electrical shop and buy thimbles.
RCA x 2 (if you want to power both front and rear speakers with amp), SPK cable, Sub cable, fuse from scosche.
Cost will be around 7-7.5K for all the stuff.
Any choices now ?
Old 13th September 2008, 18:34   #45
panky12345's Avatar
Thanked: 150 Times
avoid kenwood 8401 Please!!!!
Which Subwoofer and Amplifier ramie2400 In-Car Entertainment 88 18th February 2018 11:48
Need help deciding on a JVC Subwoofer and Amplifier ghpk In-Car Entertainment 31 25th April 2012 03:51
Difference between a Monobloc and 2 Channel Amplifier for the Subwoofer? frankmehta In-Car Entertainment 52 21st November 2011 17:23
Help in selecting Amplifier and Subwoofer for my Wagon-R ravi@64bhp In-Car Entertainment 37 28th June 2008 20:40
Blaupunkt Subwoofer and Kenwood Amplifier for sale general_neo Shifting gears 7 25th December 2005 13:32
