Old 12th September 2008, 16:37   #16
FeelTheBass's Avatar
Thanked: 12 Times
Congrats Nishant. One thing i must say, i really liked the equipment you
chose. I'm sure it sounds sweet now. Enjoy the music bro.
~~ Feel The Bass ~~
FeelTheBass is offline   Reply With Quote
Old 26th December 2008, 15:36   #17
nishantgandhi's Avatar
Thanked: 151 Times
Default Suppressed sound
Since the last few days, I have been facing a strange problem with my ICE.
The volume seems quite suppressed at the level of 15-20 (which is what I used to listen at normally, when windows are rolled up). Only after I jack up to 25-30 does it become 'normal'. Previously, at a level of 25-30 I would go momentarily deaf to road noises etc.
Weirdly, everything is the same in my system. Amp gains or for that matter, none of the settings on the amp or the HU have been tweaked. Software (MP3s playing off the USB) are the same.
The only incidence that I remember was when frankmehta was testing out the Pioneer steering remote control on my system and the ATT (attenuation) button got pressed accidentally and the sound was suppressed for a moment. Of course we reversed the change right there and then.
Now what can the issue be? There is no ATT function in Pioneer 5050 menu so I am pretty sure I could not have pressed it by mistake. Car has not gone for service so no chance of tweaks from that end as well.
P.S. Does Illusion Electra 6.1 XOs have a setting like JBL compos have?
nishantgandhi is offline   Reply With Quote
Old 26th December 2008, 17:05   #18
abhinav.gupta88's Avatar
Thanked: 310 Times
No they dont have the -6 / 0 db option on the crossovers/
Old 26th December 2008, 22:01   #19
nitrous's Avatar
Thanked: 285 Times
Check the value of your SLA
Yes,they do. 3 settings actually.
Old 26th December 2008, 22:26   #20
frankmehta's Avatar
Thanked: 2,334 Times
-6, 0 and +6!
they have 3 settings. mine is set on -6.
nishant, as far as your problem is concerned, im sure its SLA. the source volume must be at 0. try increasing it, and you'll know the difference!
Old 26th December 2008, 22:53   #21
Thanked: 310 Times
where can i find it.
I have the illusion electras . want to try the difference.
Old 26th December 2008, 22:58   #22
frankmehta's Avatar
open the crossover ka dhakkan and locate with a torch.
ajay did it for me, but he did it for sure! so it exists!
Old 26th December 2008, 23:17   #23
Thanked: 310 Times
@ Low_bass_makker. Coming after my exams.
@ Frank Mehta : Thanks buddy
Old 27th December 2008, 11:25   #24
Thanked: 294 Times
Yes they have. That is I think is +3db , 0 , -3db
Old 27th December 2008, 13:04   #25
gigy's Avatar
Thanked: 41 Times
Can you show a picture of that subwoofer connector disconnected? the top RCA cable bend radius looks lesser than minimum.
Old 27th December 2008, 18:23   #26
Bass&Trouble's Avatar
Thanked: 71 Times
You guys need to read the manual. It's a jumper setting on the board. The topmost (default) is 0dB. Middle position is -3dB, and lowest is +3dB. Use -3dB if the tweeters are ending up closer to the listening position than the midwoofers.
Old 12th February 2009, 13:30   #27
Thanked: 151 Times
I changed the SLA to +4 for USB and CD. yes, it does make hell of a difference. However, I fine the sound 'muffled' at lower volumes i.e ~level 3-4. Has that got to do with cross over settings? Or is it my 'veham'?
Ajay, is there a factory default setting for the XOs? AFAIK, Pankaj bhai installer's did not tweak any setting while installing the compos, neither did Zohir, while installing the sub.
OT - I need your help for in getting the sub enclosure re-designed and also to correct the alternator whine! When can I appear at your Hermit House?
Old 12th February 2009, 15:48   #28
Thanked: 71 Times
Default setting is 0 dB. Sometime next week should be fine.
Old 23rd May 2009, 01:57   #29
frankmehta's Avatar
minor update:
nishant has a 'test enclosure' for the gz mk2 subwoofer in his getz. shallow and long enclosure.
the boot looks nice with it now.
Old 23rd May 2009, 07:55   #30
akshay4587's Avatar
Thanked: 1,686 Times
As mentioned in this thread earler,why is it incorrect to install HU from the front of center console?
i swapped 3 HU's in last few months and all of them were mounted from the front,due to which there was no need to open the central console
Winters are here : Getz CRDi getz some iCe! aZa In-Car Entertainment 68 22nd December 2010 00:23
The future of Hyundai Getz? EDIT : Bye Bye Getz (page 2) sathya_j2084 The Indian Car Scene 32 25th June 2010 10:19
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
Getz prime 1.3 is overpriced than previous getz ( old one )? hrishig The Indian Car Scene 3 30th April 2007 10:29
Getz New Launch + Getz vs Swift.. scorp 1 Hatchbacks 18 23rd August 2006 11:34
