Old 15th September 2008, 19:56   #16
Thanked: 7 Times
it is a dvc sub , i wanted to know that whether its a spl or a sq sub, anyway what about the real problem of mine guys, is it my hardware which is at fault or what, please advise
thanks
makanaka is offline   Reply With Quote
Old 15th September 2008, 20:40   #17
Magma's Avatar
Originally Posted by gunbir View Post
How did you manage to run a 2ohm load on the bridged output on that amp???
your answer may lie in what the above person says
your amp is a 4 channel amp. 2 channels bridged together are running the DVC sub correct.?
when the sub is wired in parallel ,the 2 coils -(4 ohm and 4ohm) present a 2 ohm load correct?
now your amp in bridged mode may not be stable at 2 ohms ( much like many 4 channel amps ) and hence you may be having this problem
do as navinji has suggested. wire the sub in series.
alternatively use all 4 channels for the sub
Alternatively get a mono
Alternatively get a 4ohm SVC sub
Alterantively wait for more guru advice because im learning too so i may be wrong
Magma is offline   Reply With Quote
Some Good Low Bass Songs I've heard! headers In-Car Entertainment 16 20th March 2008 15:17
Could someone identify a few songs for me? Sheruken Shifting gears 5 28th July 2004 18:58
Phoebe's Songs! Pferdestärke Shifting gears 9 8th June 2004 21:44
top 5 driving songs souled Shifting gears 2 18th May 2004 14:10
