Old 3rd October 2008, 20:25   #91
Magma's Avatar
Originally Posted by adityamunshi View Post
LBMji, what part of the front door is rattling ?
Do GZ sub lagaye huay hai!
his whole door is probably rattling!
INDICA hai SKODA nahi
Magma is offline   Reply With Quote
Old 3rd October 2008, 20:33   #92
Sam Kapasi's Avatar
Thanked: 1,473 Times
I know what is rattling, it is all the whiskey ke bottles in Panky's car-o-bar.
Old 4th October 2008, 01:53   #93
iraghava's Avatar
Thanked: 156 Times
Add to that the glasses kept in the front doors (aahhhh!!, Now I know why the front doors rattle!) and the ice bucket under the seat!
Old 4th October 2008, 02:05   #94
Thanked: 17 Times
Panky sirji is in the world of stirred and shaken at the moment.
His drinks get stirred and doors get the shakes! Milk shakes.
Old 5th October 2008, 22:49   #95
panky12345's Avatar
Thanked: 150 Times
come on guys.. be serious sometimes :-) :-)
I need some really pro - fess - ional advise!! PPLLEEAAASEEE!!
Old 5th October 2008, 23:08   #96
abhinav.gupta88's Avatar
Thanked: 310 Times
Thanks Panky for the audition.
I guess more damping is required in the car
I just hope mine doesnt rattle
Old 7th December 2008, 18:38   #97
panky12345's Avatar
Thanked: 150 Times
Update: My JBL 607Cs have been totalled :-( Thanks to my JBL 75.4 and a phull blast session after a couple of drinks!.. changing front comps soon. Any good suggestions? (except illusion EL 6.1)
Old 7th December 2008, 18:56   #98
greenhorn's Avatar
Thanked: 1,519 Times
panky ji, the problem with the front door rattling is because the speakers are mounted on the indigo door panels rather than the door panels like most cars. what i did when i got mine installed was to insert a ring of foam tape( navin ji recommended rubber as well) between the speaker grille and the door panel to minimize transmission of vibrations. Check out the details of my install here
https://www.team-bhp.com/forum/ask-g...ler-tvm-4.html
Earlier, the door panels started rattling at volume level 12 on my HU. after , it goes till 16, and the mids and bass improved(another reason for the improvement was the improved seal - the ring covered all the slots which were leaking air ).
for any further improvement, a bit of fibreglass/damping or both on the plastic panels to improve the stiffness and reduce the vibration of the stock door panels is required. Alternately, you can try setting the HPF for the front comps higher - less bass produced by the comps means less rattling from the front
sucessors for the 607C's ?
judging by your preferences and your requirements, how about a P6563 ?
its a perfect fit. the indigo has stock locations to put in a 3 way
Old 7th December 2008, 19:31   #99
panky12345's Avatar
Thanked: 150 Times
Thanks yaar.... outta budget greatly!!
Old 9th December 2008, 01:07   #100
superbhikari's Avatar
Thanked: 146 Times
Why not illusion EL 6.1? Any particular reason? Just asking since would be upgrading the compo in the near future.
superbhikari is online now   Reply With Quote
Old 9th December 2008, 11:26   #101
navin's Avatar
Thanked: 4,286 Times
A gasket does help reduce the transimission of midbass reverbration but I suspect panky's problems might arise from a multiple of issues.
1. the door panel of the car is not stiff enough
2. some loose odds and ends might be resonating when music contaning their resonacne frequency is played
3. Please also look at all parts outside the car. On one instance for example it was found that e nut on my rear bumper was vibrating. Due the odd acoustic chamber a car's interiors are the sound felt like it came from the front dash.
Tata cars are notorious for having loose switches, screws, etc.. so one really has to comb his/her way though the car with a sharp eye and ears and resolve one problem at a time. My Contessa was such a problem car. It took quite a while to "fix" it.
Old 9th December 2008, 13:29   #102
noidaboy's Avatar
Thanked: 260 Times
Tuning helps you see.This could had been avoided
Why the exception for illusion?
noidaboy is offline   Reply With Quote
Old 9th December 2008, 15:09   #103
Thanked: 294 Times
How ???? I cannot see the point here. Have you heard the concerned car or just assuming things...
Old 9th December 2008, 15:09   #104
NOTORIOUS's Avatar
Thanked: 89 Times
try rainbow slx , they are Rs 9xxx. i have finalized them for my swift after a audition by gunbir ji cheers:
NOTORIOUS is offline   Reply With Quote
Old 9th December 2008, 15:34   #105
greenhorn's Avatar
If i were you, I'd set the LPF to the sub and HPF to the comps a few notches higher. lesser bass to the comps = less door panel rattling and less power delivered
Major ICE Upgrade in my Palio (EDIT: Car upgraded.) hydrashok In-Car Entertainment 352 13th April 2008 22:47
Upgraded Maruti Baleno up for review among roster agencies askicode The Indian Car Scene 29 3rd March 2007 08:37
upgraded version version of unicorn or pulsar150 dtsi sujit007 Motorbikes 6 5th January 2007 09:34
Vernacular - 2043 Vernas in five days, upgraded to 5000/month now adarsh76 The Indian Car Scene 113 14th November 2006 00:02
Inquiry about Baleno Upgraded Tyre pressure Puffdamgcdragon Tyre & Alloy wheel Section 14 16th January 2006 19:41
