Old 19th September 2008, 14:01   #16
Thanked: 294 Times
Originally Posted by amit_sound View Post
Amp is still a very grey area with me....i would really love an amp churning out 10rms at 12 v.
And good point made by LBM, about changing the front windscreen of the car and agree that accent may not be a daily driver any more....but i am ready for that.
It will be very hard to find so stop doing it. If money is no issue then go for separate alternator setup with 16-18 volts line. Higher the voltage the amperage will reduce. So it the way to go.
I would advice to go for a smaller and cheaper car to sacrifice.
And in all in all I agree that you have no budget limit but still there must be a figure that you have considered.
Old 19th September 2008, 14:07   #17
amit_sound's Avatar
hmm....consider 5-6 lacs approx for the setup.
amit_sound is offline   Reply With Quote
Old 22nd September 2008, 16:22   #18
amit_sound's Avatar
Following needs to be done to provide the amp with 14.4 volts contantly
1) High output alternator
2) Better battery
3) Better cables
Any thing more to add?
Old 22nd September 2008, 16:55   #19
Bass&Trouble's Avatar
Thanked: 71 Times
If you're really looking to go nuts, find someone who has the know how to retrofit and aftermarket alternator. I am sure one of Auto gurus would know someone up to the task. You wont get an alternator that will deliver 1000A etc, but atleast a performance alternator will top up a bank of batteries sooner.
Like LBM mentioned, get a hatch for the job, ideally. Or some other single compartment vehicle.
Get the wall right behind first row seating. If you can, do dual 18s ported.
You have to look at some serious reinforcement. I wouldnt call it damping. That's too tame.
Also try running amps at 16-18V. Nowadays there are a lot of amps designed to work at these voltages and give significantly higher output.
Old 22nd September 2008, 17:01   #20
Thanked: 294 Times
Forgot to add last time. You will be needing 2 volts or 4 volts battery connected in series to get 16-18 volts. Normal 12 volt high performance battery will not be sufficient.
2) Better battery
3) Better cables
Normal high out put will not be enough for the job, A 16- 18 volts will be required, For cables you can save a little money here by using Finolex !!!!
Old 22nd September 2008, 17:39   #21
Thanked: 71 Times
Arre aap kahan ameer aadmi ko Finolex i.e. desi item mein ghaseet rahe ho?
Old 22nd September 2008, 17:41   #22
Thanked: 294 Times
I thought he will save a little more for the other stuff. Waise Finolex make sizes more than 125 mmsq. More than one require.
Old 22nd September 2008, 23:19   #23
amit_sound's Avatar
hmm...you probably saying this as i mentioned that i have no constraints to budget..right?
Now here comes a little logic...
"Khulla budget" is a term two type of people can make
1) Ameer aadmi as you said
2) Financially broke dudes!!!
I purely fall in the second category, as i am going through a very very tough phase of carrier.....so now u know, why i dont have any budget constraints. Moreover discussing SPL relaxes me
Jab koi budget hi nahi hai, toh tension ki kya baat hai!! Haan per umeedey buland hai
So would really not mind increasing budget...
Old 22nd September 2008, 23:28   #24
amit_sound's Avatar
Was also thinking of DD9518 (18")....above DD9515 (15")
But DD says, 9518 with composite requires 8-10 c/f per woofer!! i means, 16-20 c/f for two woofer!! Looks like a tough space management for accent, even with rear seats removed.
Better option, remove the driver seat also and make it a "haath-gadi"
Feels like 9515 with composite cone OR 9518 regular should fit
Old 23rd September 2008, 10:45   #25
Thanked: 294 Times
If open for options then why not check the other ones...
Like Fi BTL 18 inches it will require 5-8 cuft per sub. So a 10 - 15 cuft in a car is easy. You can try GZ also they will require 4-6 cuft for playing good. Kicker SOLO X can be considered but it again requires a 10 cuft box.
Old 23rd September 2008, 13:14   #26
navin's Avatar
Thanked: 4,282 Times
Like LBM mentioned, get a hatch for the job.
better still a nothc back like the Octavia.
Old 23rd September 2008, 16:26   #27
amit_sound's Avatar
What would be the retail of your GZ in India?
Old 23rd September 2008, 16:56   #28
Thanked: 294 Times
Which one ? any specific model ? And Ajay Bhai would be the best guy to give the quote.
Old 23rd September 2008, 19:35   #29
amit_sound's Avatar
I am asking how much did you pay for your plutonium GZ sub?
Old 23rd September 2008, 19:40   #30
Thanked: 294 Times
I got it for 120k + discounts.
You can get one also....enough for your job
:: Ground Zero :: Subwoofer / GZNW 15SPL
Buggati Veyron will go on sale next year.. _Crazi4Speed_ The International Automotive Scene 25 21st November 2005 22:34
Some little news about the next gen nissan GTR _Crazi4Speed_ The International Automotive Scene 0 21st September 2004 01:31
Next Gen Ford Focus. v12 The International Automotive Scene 6 9th June 2004 16:55
Mercedes-Benz Next Gen A-Class! S350L-E240 The International Automotive Scene 1 29th May 2004 19:42
How can someone b this good in creating the next S _Crazi4Speed_ The International Automotive Scene 8 3rd March 2004 13:54
