Old 24th September 2008, 12:18   #16
esteem_lover's Avatar
Thanked: 451 Times
Audition JBL, Illusions, etc that are in the range & select the one that sounds right for you. Contact your bombay BHP ians with regard to the right place to go for the install.
Old 30th September 2008, 13:46   #17
Hi!
I do have the same speakers GTO937. Its good one.
I am also using poineer Head Unit.
You have a option in your head unit to configure the rear output to the sub or full range output.
for this you switch OFF the set and press the multi control buttom i.e. your volume controll and hold it for a while. you will inter in intitial setup menu. Scroll and go to SW control anm make it to sub mode.
switch off and again switch on. go to high pass filter option and place the high pass to 100Hz so that you can use general front speaker and bass will not be effacting the front speakers.
Use JBL front speakers that are really good at reasonable price.
Now feel the sound of you set just sounding like sub connected with amp.
No more money you need to pay but its really sounds great.
I have purhased the amp but thinking not to use after I had configured in this mode as I am getting great sound from the head unit itself. Amp will also draw power which I do not want to wast untill unless it is required.
pioneer head units with direct subdrive is just great
Originally Posted by KSM-Vtec View Post
Hi Guys,
The following is my current configuration -
Car : OHC Vtec 2001
HU : Pio6850 - DEH-P6850MP
Speakers : JBL GTO937 - JBL Car & Marine Audio
I want to add an amp, speakers/components for the front(something that fits into my door panels without having to cut the grill) and also a woofer.
Just to explain what i need -
1.Loudness but surly not at the cost of clarity(Both in the speakers and woofer)
2.Something which i dont have to worry about for at least 2yrs to come.
3.For now my budget is 10k. I know it may not be good enough.
help me in deciding on the combination which will work at the optimum level allong with my current setup.
gauravsinha is offline   Reply With Quote
Old 3rd October 2008, 16:30   #18
Sam Kapasi's Avatar
Thanked: 1,473 Times
Wow Gaurav, even I got confused there, lol.
Kaushik, buy a good amplifier and components. The sub can wait for the next paycheck.
Old 3rd October 2008, 16:39   #19
KSM-Vtec's Avatar
Thanked: 440 Times
Hi Sam,
thanx for the quick responce, which comps, amps and sub do you suggest?
need something that goes best with the GTO937 and the Pio6850.
And yes i have increased the budget to 15k. Is that ok?
Will i need 2 amps or 1 is ok for the comps, sub and 937's?
KSM-Vtec is offline   Reply With Quote
Old 3rd October 2008, 17:03   #20
Sam Kapasi's Avatar
Hi Sam,
Ideally you would need a 4channel amplifier and a singlemono amplifier. But ideally you would have more money to burn on your ICE. lol.
So for now, you buy a 4 channel amplifier between 8 and 10K. There are a few good brands available for that price. And get a component set for about 5K. Assuming you get an amp for 8500 and components for 5000, you will have 1500 left over.
Buy a bottle of Indian Champagne (I suggest Sula Brut -900/-), take it home and out it in the freezer for 3 hours. Then pack it up in newspaper (acts like a thermal jacket), put petrol(500/-), buy some flowers (100/-), rob two champagne glasses from your ghar (free), pick up your girl(free), go for a drive(free) and drink the champagne before it gets warm.
And THAT is in-car-entertainment.
Old 3rd October 2008, 17:17   #21
KSM-Vtec's Avatar
Thanked: 440 Times
Well that sounds great but i would like to try and get the entire system for approx 15k and then ill go for the drive like you said.
So what say?
Old 3rd October 2008, 17:26   #22
Sam Kapasi's Avatar
So what say?
Entire means what? You cannot get 2 amps, a set of components and a sub for 15K.
It is better you raise your budget to 16, 17K, buy a subwoofer, a 4 channel amplifier and some components then and save up for a monoblock.
Old 3rd October 2008, 17:35   #23
mobike008's Avatar
Thanked: 8,319 Times
Buddy, if you have a budget of 15K, build up slowly and do it in 2 stages
Stage 1
4-Channel AMP : 7K
Component Speakers for front stage : 5.5K
Wiring : 1.5K
Total : 14K
Stage 2 ( Whenever you have money in near future)
Subwoofer : 7-8K
Monoblock Amp : 10K
Total : 18K
After the stage 2, the " entire system" will be completed.
Old 3rd October 2008, 17:39   #24
KSM-Vtec's Avatar
Thanked: 440 Times
dose is make sence to get a 2 ch amp for the sub, a 4 ch amp for the comps and rear spks?
Will the monoamp be way better than the 2ch amp?
How about puttin on the following?
JBL 604 amp
JBL 2 Ch amp
JBL GT5 - 1000watts
JBL C608 - comps
Old 3rd October 2008, 17:55   #25
Thanked: 451 Times
way, wayyyy better. Just get a 4 channel now & get the mono amp whenever you have the dough.
Old 23rd February 2009, 12:00   #26
KSM-Vtec's Avatar
Thanked: 440 Times
OK guys finally i have taken the plunge...got the upgrade done yesterday.
So now my setup looks like this..
1. HU - Pioneer 6850
2. Amp - JBL GT5-A604 (Just added)
3. Rear - JBL GTO-937
4. Front - JBL GT5-S265C (Just added)
5. Subw - JBL GT5-S12 (Just added)
Thanks to Sam for his inputs from GOA
So what say guys..How does it look?
Want to work on the fine tuning now...any inputs???
Old 23rd February 2009, 21:16   #27
reveal_da_zeal's Avatar
Looks like JBLified and pio is there to control them all hehe. well the additions made are well thought upon. Keep it up.
reveal_da_zeal is offline   Reply With Quote
Old 23rd February 2009, 22:49   #28
frankmehta's Avatar
Thanked: 2,334 Times
great, congratulations! is the gt5 s12 in a ported enclosure or is it in a sealed dabba?
i guess its time for you to show us your stuff, and there's no better way to do that than to open a new show-off thread in the appropriate section.
who did the install? what wiring? what RCAs?
Old 24th February 2009, 10:11   #29
KSM-Vtec's Avatar
Thanked: 440 Times
Ya the sub is in a sealed dabba. Install was done by prakash motors at khar (jbl auth dealer).
Need Help on Pioneer Spk, HU & JBL SWTube anthonydcruz In-Car Entertainment 14 11th August 2008 16:18
Wagon R - replace blaunpunkt speakers with JBL GTO937 udit78 In-Car Entertainment 34 21st June 2008 11:42
Replace GTO937 with Infinity 6953i? Pioneer Yellow cone TSE6996 johy In-Car Entertainment 4 3rd January 2008 16:21
For Sale - JBL 2ch Amp and JBL 12" Basstube karthik247 Shifting gears 5 3rd December 2007 17:44
