Old 24th September 2008, 11:43   #1
Exclamation Pioneer 4050 HU subdrive
I have pioneer DEH-4050UB Head Unit.
Can any one tell me how to configure rear output to SUB mode?
The manual says that one can directly drive sub and can operate in 2.1 mode with load 4-8Ohms X 2 and 2Ohms X 1. My menu does not shows the SUB option to select between SUB/FULL!!!!!
Is there any setting in which some option to enable to get this setting done?
I wish to configure my rear output to sub mode and just front in full frequency mode.
gauravsinha is offline   Reply With Quote
Old 24th September 2008, 13:15   #2
greenhorn's Avatar
Thanked: 1,519 Times
Driving a sub off the HU is not very practical. More info here
http://www.team-bhp.com/forum/ask-gu...ier-works.html
greenhorn is online now   Reply With Quote
Old 24th September 2008, 14:07   #3
Glass's Avatar
Thanked: 12 Times
Put off the HU first. Then press the big round button for 5 seconds. the top most level menu appears from where you can choose Sub/Full.
And do let me know if it drives the sub okay... I have a 4050 as well
Glass is offline   Reply With Quote
Old 24th September 2008, 14:18   #4
Bass&Trouble's Avatar
Thanked: 71 Times
Which 2 ohm sub do you have that you plan to run with this?
Old 30th September 2008, 12:29   #5
Great it works,
I just have GT0937 fitted in box in rear which I had configured as sub and front is GT402 both JBL speakers. I had switched on HPF setting at 100Hz so that my front speakers takes the full control of vocals and highs. Sub i just keep at either 65 or 80Hz.
Its great!!!!
I have already purched a amp but I do think wether I need it. I am getting enough bass as well as overall sound.
Old 30th September 2008, 20:28   #6
Glass's Avatar
Thanked: 12 Times
Hmm... does this setting increase the overall bass or merely cut out the mids and highs coming from the rear speakers?
I was experimenting with this a while back but couldn't conclude this added bass - I thought it merely cut out a part of the overall spectrum from the rear. I will check it again to see if the overall SQ is better through this.
Mine are JBLs too - front comps and rear ovals.
Welcome my new (b)ride, CAN 1526 (nee APF 4050)! Stanher Post-War 263 6th April 2015 15:25
Which Pioneer HU 4050\5050\6050 ? ddd08 In-Car Entertainment 187 22nd September 2011 22:02
Pioneer DVH-4050 Divx File Play ganesh_bbr In-Car Entertainment 0 12th July 2009 18:14
Better SQ replacement for my Pio 4050 under 10k jaibir In-Car Entertainment 12 7th June 2009 12:33
For Sale: Pioneer FH-P 6200 2 Din and Pioneer EQ 6500 Equalizer . sam_78 Shifting gears 4 28th April 2007 12:16
