Old 14th October 2008, 11:48   #16
absynthguzzler's Avatar
Thanked: 224 Times
Default further update
just adding photos of the Driver Mounting hole and leg braces being made at the wood turning shop .
absynthguzzler is offline   Reply With Quote
Old 14th October 2008, 13:27   #17
Thanked: 24 Times
Looks like good work. You are making full use of your extended trip to hyderabad.
Some how I fail to understand the entire process!!! May be tonight I have to see it in person to understand it.
kkr2k2 is offline   Reply With Quote
Old 15th October 2008, 15:45   #18
Thanked: 224 Times
Default Quick question
Just rummaged through left over hardware at home and found the following
36 Grit sand paper
120 Grit
180 Grit
320 Grit
Now which one do i use as a precursor to adding more FG sheets on completed and dried up ones on the enclosure. Just so that the bond between old and new is well set while applying resin??
MODS : It would be much appreciated if the Thread title is changed to "DIY Fiber Glass Enclosure - NHC "
Old 13th November 2008, 00:39   #19
rider60's Avatar
Thanked: 47 Times
well i just wanted to mention one thing here, the guys at checkered Flag are into fiber glass enclosures too now, when you guys have time do check it out, i think they now have the exclusivity of being one of say very few or rather the only car decors in Hyd making these custom enclosures here in Hyderabad.
well my apologies for hijacking this thread this way, but this info is worth its weight here i hope.
rider60 is offline   Reply With Quote
Old 18th November 2008, 15:10   #20
getsurya's Avatar
Thanked: 967 Times
Hi Absynth, After seeing your DIY in person, I guess it is a great idea. Let me also think on the same lines for my car!
getsurya is offline   Reply With Quote
Old 30th December 2008, 18:41   #21
gigy's Avatar
Thanked: 41 Times
Great job there buddy. Can you post all the pictures of work done. i am eager to try this before i go to professionals. can i contact you for fiberglass if i dont find it here?
Carbon Fibre Sheets / Self Adhesive Sheets / Stickers netchef Modifications & Accessories 150 1st November 2016 16:59
Caution - Retailer's Extended Warranty Voyager-1 Shifting gears 9 24th November 2010 11:11
Hyd-Goa-Hyd Trip: Gulp Terror!! for the Thrill btirthankar Travelogues 82 19th January 2010 21:26
Need advice on Hyd-Hampi-Bijapur-Hyd route vnabhi Route / Travel Queries 18 16th October 2009 23:02
Roadtrip through South India : Hyd - Blr - Wyn - Mys - Blr - Hyd devnull Travelogues 24 29th July 2009 16:08
