Old 29th September 2008, 15:18   #1
Thanked: 17 Times
Default Humming Noise after amp install.
Hello gurus,
I installed a sony amp. i have no sub-woofer. connected the 4 spekers to the amp.
after install, when i start the engine a humming noise comes and when i accelerate to change the gears it becomes more. if i switch off the music system the noise stops.( this noise i hear if i play the music with 0 volume :-) )
i went and showed to the guy who installed the amp, he said some earthing problem, took some 300 buck for some JBL cables for the connection between the music system to amp. previously he was using a local adapter.( my HU(JVC)has only 2 channel but the amp is 4 channel, so i guess that cable converts 1 to 2 - adapter).
after this the noise has reduced but when i switch on my AC the noise still comes.
also that guy told if still the humming noise comes, the earthing in the HU circuit should be disabled(thats what i understood)
any idea ???
madhukar_n is offline   Reply With Quote
Old 29th September 2008, 16:18   #2
NOTORIOUS's Avatar
Thanked: 89 Times
the installer knows nothing. this is a earthing problem and it is better to go to a good installer
NOTORIOUS is offline   Reply With Quote
Old 29th September 2008, 16:26   #3
Thanked: 21 Times
Check if this CD is playing in your HU...
Old 29th September 2008, 16:30   #4
Awaiting Email Confirmation
Thats strange ? Why this CD ?
nitin.dangayach is offline   Reply With Quote
Old 29th September 2008, 16:30   #5
NOTORIOUS's Avatar
Thanked: 89 Times
good one sir ji
Old 29th September 2008, 16:54   #6
karankapoor's Avatar
that is funnny gunbir as i told you the other day you have a
great sense of humour
karankapoor is offline   Reply With Quote
Old 29th September 2008, 16:57   #7
Jaggu's Avatar
Thanked: 8,693 Times
Ok good humor but can someone knowledgeable please help him please, is he referring to alternator whine? If so how can it be rectified?
Old 29th September 2008, 16:57   #8
Oops I miss the subtle point :P I never thought Gunbir would crack such a witty joke.
Anyway, somebody help the fellow as well.
Old 29th September 2008, 17:01   #9
abhinav.gupta88's Avatar
Thanked: 310 Times
Same problem was with my Honda City
Some earthing problem
sorted pretty easily.
Old 29th September 2008, 17:01   #10
Thanked: 21 Times
Originally Posted by madhukar_n View Post
any idea ???
Madhukar, is it a Pioneer HU you are using? They are notorious for the pico fuse related ground noise issues. Search around, there is a thread (by clipto333 I think) where the solution has been discussed.
Sorry for the joke in your thread, I couldn't resist.
Old 29th September 2008, 17:11   #11
Thanked: 17 Times
i guess it was humming for kimi kathkar !!
anyway, the HU is a JVC.
so it is a earthing issue ?? nothing else right ?
i will ask him to rectify it and if does not solve will show to a better installer.
Old 29th September 2008, 17:17   #12
mohang_j's Avatar
Thanked: 18 Times
Is this thread http://www.team-bhp.com/forum/diy-do...alt-whine.html
Superb, good sense of humor.
mohang_j is offline   Reply With Quote
Old 29th September 2008, 17:23   #13
Thanked: 294 Times
It was posted by s0uljah here is the link of the same...
http://www.team-bhp.com/forum/413720-post5719.html
Old 29th September 2008, 19:20   #14
nishantgandhi's Avatar
Thanked: 151 Times
Awesome!
Why did you underestimate Gunbir's sense of humor?
On another note, I am also facing alternator whine. Got the Ground Zero RCAs checked, earthing checked and also reduced the gains on the amplifier. Nothing worked.
My installer suspected it the infamous Pioneer blown IC issue. However, we tried with an old Pio HU but the whine was still there. So could it really be Pio HU problem? If yes, then it has to be a great coincidence that the replacement old Pio HU also had a blown IC.
So what can the culprit be?
nishantgandhi is offline   Reply With Quote
Old 29th September 2008, 19:33   #15
Thanked: 21 Times
It is probably the Pio HU. Its not an IC but the pico fuse that blows. All you have to do is ground the outer metal of the RCA plug to the metal of your car. See the links in this thread. They have instructions and pics.
Do try some better interconnects too. The JBL cables you bought are fakes. They are no good.
How to reduce humming noise of freeflow Airfilter Sivia Technical Stuff 6 15th July 2009 07:47
Humming noise from rear left in '98 Cielo GLX after tyre change VSG12777 Technical Stuff 18 13th April 2009 10:31
1.2 nv gear humming noise from ac vents kapilsharma80 Technical Stuff 0 30th May 2008 11:46
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Help:Humming noise in pulsar chilled_fire Motorbikes 4 22nd March 2006 13:24
