Old 30th September 2008, 17:27   #16
nc1bad's Avatar
Thanked: 15 Times
Default hi
yep same seating arrangements for 3.0 and 2.2.
Its the one without the fan (for the processor). There is a fan , but its not for the cpu, its for the motherboard bios chip.I am still trying to get Mother Board Reader software configured to read data of the mb, once i get it done shall post some readings, btw it uses only 3-5 watts power, so heating is not an issue.
Originally Posted by jobinjv View Post
Dude, Can the same place be used on the new safari's too?
nc1bad is offline   Reply With Quote
Old 30th September 2008, 17:49   #17
jobinjv's Avatar
Try speedfan. They have a small program that shows the CPU and HD temp and some etc etc stuff.
jobinjv is offline   Reply With Quote
Old 30th September 2008, 17:50   #18
esteem_lover's Avatar
Thanked: 451 Times
Terrific job nc1bad. Would be useful if you could put up the prices for each component & the total cost of the set up.
Old 30th September 2008, 18:11   #19
The_Warrior's Avatar
I guess he has already done that in the 1st post...
The_Warrior is offline   Reply With Quote
Old 30th September 2008, 19:39   #20
nc1bad's Avatar
Thanked: 15 Times
Default speed fan
hi, the reason i am trying to get Motherboard reader to work is basically theres a plugin for the same in CF2. Using MBR i can directly read data from CF
Old 30th September 2008, 20:10   #21
jobinjv's Avatar
Oh ok. And is it for sure the OBD Scanner will work on the Safari.
Do you have more pics like how the power line is done and other stuff, the screen on the dash. BTW which screen is it.
Old 30th September 2008, 22:21   #22
noidaboy's Avatar
Thanked: 260 Times
Congrats man,how the practical usage and does it justify the money,i have my eyes on one of these from a long time.
noidaboy is offline   Reply With Quote
Old 1st October 2008, 12:36   #23
nc1bad's Avatar
Thanked: 15 Times
not sure about OBD scanner, some engine parameters may not show, will know only after i pick up one. Regarding installation pics everything was super concealed by my fitter, as u can see in the pics, he dismantled almost the entire dashboard for the wiring, so dont have more pics on the same. I am using a 7" touchscreen VGA , has to be VGA because on clarity issues.
Praticality for me is basically email on the go (need to move around controlling 5 centers) , GPS ,entertainment system and OBD. Centrafuse reads out (female voice, kinda like James Bond's car he he ) the email received, then u can reply,forward, do whatever u want with it. As said in almost all car-pc posts ,practicality is endless. But you do need to ensure that u are building a proper pc. Taking parts that are not suitable for car environment because they are the cheaper option will only cause more head aches.
You can spend 6000k or 40,000k for ICE, but then ultimatly its up to you to decide whether or not its worth it.
Old 2nd October 2008, 13:28   #24
Thanked: 41 Times
kooooll.. i like your project. welcome to the carputer world. let me know if you face any problem in making the serial remote receiver for carpc. i have one and is working perfectly with my pioneer steering remote.
monty9991 is offline   Reply With Quote
Old 2nd October 2008, 16:39   #25
nc1bad's Avatar
Thanked: 15 Times
Default thanks
hey thanks, needed to know something regarding IR, i am planning to use winlrc via girder , wanted to know if i can directly configure girder to accept IR commands.
Old 2nd October 2008, 20:06   #26
nc1bad's Avatar
Thanked: 15 Times
Default screen shots
hi guys attached some screen shots/pics showing media screen, phone, email , navigation and trip computer
Added list of to do things:
1) Main : A reset switch for the pc, after all its windows!!
Old 3rd October 2008, 20:47   #27
smokin's Avatar
Thanked: 13 Times
great man !!!
which gps receiver you are using ?
and how u embed the maps in the interface
smokin is offline   Reply With Quote
Old 3rd October 2008, 22:02   #28
Thanked: 41 Times
i am using igorPlug as plugin for girder to accept the commands thru Girder. and works like a charm.
Old 3rd October 2008, 22:29   #29
jkdas's Avatar
Thanked: 1,436 Times
hi guys good morning, have posted more pics showing the cpu install , the keyboard cum trackball unit i took from a reliance kiosk and also a pic of the dash board showing why it is not feasible to install the screen where the HU is located :
(@ speedzak) dont think gpu can be added to this unit, as it uses a ITX motherboard and i am running it on a 100 watt smps.
Anyways the processor is Intel Atom ( dual core) with 1 gb DDR2 PC 667 ram, it plays games like GTA SA without any problems.
Next list of addons are :
1. Custom made IR to serial port receiver , so that i can use the pioneer remote control to change songs etc
2. OBD II scanner device.
3. Head rest displays , or just one additional display for rear passengers
Have tried out Atom with 1GB on XP lap(HP Leap and Asus), its fast! Didnt believe it was dual core ( even though it showed up on properties)
Where did the keyboard go? Neat install! The CPU is hidden.
Old 10th October 2008, 13:13   #30
nc1bad's Avatar
Thanked: 15 Times
Default DIY IR Reciever
hi guys , after a lazy start on a sunday morning , i completed the entire process of getting my IR installed,it worked fine for 3 days , then suddenly went dead , dont know whether its a hardware or software problem, should check on it this sunday and update!
Tata Safari Dicor LX 4 X 2 or Safari Dicor EX 4 x 2 Digitalmafia SUVs, MUVs & 4x4s 55 1st June 2009 17:31
When Safari lovers TD a Scorpio mHawk! EDIT:Its a Safari tsk1979 Test-Drives & Initial Ownership Reports 281 6th May 2009 10:46
New Safari or Used Safari-Help EDIT: Booked New LX now gops SUVs, MUVs & 4x4s 92 7th April 2009 20:25
What to choose safari petrol or Safari diesel 2.2L 007 Bond SUVs, MUVs & 4x4s 22 31st August 2007 21:56
Safari TCIC LX or Safari DICOR LX arindam SUVs, MUVs & 4x4s 19 10th January 2007 17:42
