Old 10th October 2008, 21:57   #46
faithless_1984's Avatar
Thanked: 218 Times
Congrats KP.
Am sure the setup sounds great.
OT
Music heaven a touch away!
SK456's Santro.
Hey Zak so your in Delhi eh.....lemme guess ,auditions going on in full swing for your next upgrade ?
faithless_1984 is offline   Reply With Quote
Old 10th October 2008, 22:16   #47
DjNik's Avatar
Hey Kp a brilliant setup there
Very happy to see an eclipse
Enjoy!
DjNik is offline   Reply With Quote
Old 10th October 2008, 23:18   #48
Magma's Avatar
i run the titanium GZ in a 0.95 cu ft box.
box was built couple days ago to the specifications i wanted due to space constraints.
Ajy tuned it , maybe he can provide inputs on how it sounded to him.
(my inputs are useless - im deaf i was listening to components one of which was wired out of phase till ajay corrected it the other day.i didnt even know)
Magma is offline   Reply With Quote
Old 10th October 2008, 23:33   #49
kpzen's Avatar
Thanked: 1,655 Times
Originally Posted by Vivek.Martin View Post
Nice to see some different installs than the usual Pioneer, JBL combos.
Good setups are possible even with limited budgets.
Thanks Vivek!
Originally Posted by shrivz View Post
kp, what is the bridged outupt of the JVC amp?
The sub needs to be powered well.
Amp specs
bridgeable 4-channel amplifier produces a maximum power output of 580W, with 55W per channel into 4ohms, at less than 1.0% total harmonic distortion. Power Amplifier Max. Power Output of 580W 55W x 4 channel output into 4 ohms (20Hz - 20kHz at less than 1% THD) 4, 3, or 2 channel operation MOS-FET Power supply for optimum transient response Built-In variable crossover network 2 - Ohm stable operation for flexible configuration Class-AB Circuit Full protection against overload, over temperature, short circuit and DC offset
Originally Posted by m4ugr8 View Post
It depends how it is mounted, i am sure the installer tried to force the HU from the front thats why it is an inch outside.
No, the installer didn't force the HU from front.
The center wooden console was removed to fix the HU.
Infact i remember seeing a thread by Gunbir, where he has given a pictorial discription as to how to install a HU in a getz so that it gets a flush mounted look.
Thanks for the pic.
I had gone through Gunbir's thread and also seen Naman's ICE before getting the ICE installed.
Originally Posted by speedzak View Post
@KP. Are you listening? Time to shout down his ears! Nay?
Yeah will be done soon. Thinking of DIY.
Originally Posted by low_bass_makker View Post
Yaar Izzat par aarahe hai !!!!
Oh ho! Itni tension mat liya karo. Chalo lemme introduce u to LBM Singh Jr
Old 11th October 2008, 01:49   #50
Thanked: 17 Times
No babba! No.
It's not for an upgrade. Something new is coming up.
Old 23rd October 2008, 21:24   #51
kpzen's Avatar
Default FM channel issue!!
In my Eclipse HU i'm not able to set 95.0 FM channel.
The 95.0 frequency is missing, while searching it directly jumps from 94.9 to 95.1.
Is there anything i can do ? or is it set as per US/Canada standards...?
Old 23rd October 2008, 21:27   #52
abhinav.gupta88's Avatar
Thanked: 310 Times
Yes
its that thing only
there must be an option of area 2 or similar
Select that.
It will help. ( Atleast it did in my alpine where in i wasnt able to some stations due to the 0.2 jump)
@ KPGETZ : Thanks for the audition dude.
Sounded really pretty. Congrats and the HU really is good with those Illusions
Old 23rd October 2008, 21:29   #53
Vid6639's Avatar
Thanked: 21,341 Times
Yeah there's a setting you can change to vary the steps. Change the steps to 0.5 or something. I don't know where that setting is for the Eclipse.
Old 23rd October 2008, 21:46   #54
gunbir's Avatar
Thanked: 25 Times
KP, did you try what's in the manual...
Old 23rd October 2008, 22:02   #55
CaliforniaKnight's Avatar
Thanked: 46 Times
Congrats Kp on the ECLIPSE HU. expect my questions on the same later.
CaliforniaKnight is offline   Reply With Quote
Old 23rd October 2008, 22:07   #56
kpzen's Avatar
Gunbir!
Thats exactly what i did but for some reason it doesn't show any band locations for selection.:(
Thanks CK
Old 29th October 2008, 10:55   #57
kpzen's Avatar
Thanks Gunbir/ZaK! I tried again using the instructions given in the manual, same as u had posted.
Selected the band location as AUS and now i can see 95.0 FM.
Old 29th October 2008, 13:48   #58
gunbir's Avatar
Thanked: 25 Times
Yay! Problem solved! Have a Happy Diwali!
Old 29th October 2008, 14:01   #59
esteem_lover's Avatar
Thanked: 451 Times
Congrats on the new ICE, kp. Why didn't you consider any speakers for the rear, I think they are important.
Yeah, those Illusions give pretty good bang for the buck.
Old 30th October 2008, 12:11   #60
kpzen's Avatar
Thanks John
- Mostly there would be 2 people in the car, so i wanted a front sound stage.
- In my experience, installing speakers in the rear has always caused rattling of tray.
- Didn't have the budget to install one more set of compos
- Now i don't feel the need of adding another set of speakers. Illusions rockkk.
Best Global Brands and Best Automotive Brands vasudeva The International Automotive Scene 4 9th October 2015 09:21
Premium brands going down the value-for-money road, & VFM brands becoming overpriced! GTO The Indian Car Scene 66 19th February 2011 12:24
Lets check how many car brands you know Jebs The International Automotive Scene 10 25th May 2010 09:40
great forum, great people and great cars... tadukuttan Introduce yourself 8 19th June 2006 10:52
