Old 12th October 2008, 18:53   #16
abhinav.gupta88's Avatar
Thanked: 310 Times
Originally Posted by ethanhunt123 View Post
I plan to get the monoblock and then add another Polk 10" sub in the boot.
My budget for the monoblock is around 300-350$ though probably i can push it a little bit more if i get some really good amp for that money.
Thanks for the advice
Try getting hands on one of the following
Model No. Price ( according to www.caraudiosecurity.com )
  • JBL : GTO-14001e - 200$
  • JBL : GTO-7001e - 150$
  • JBL : 601.1 - 140$
P.S. ( I have no connections with the website mentioned in the post)
Old 12th October 2008, 19:15   #17
PatienceWins's Avatar
Thanked: 285 Times
Originally Posted by theEnd View Post
PatienceWins, could you please provide some feedback regarding your setup, as I believe you're running an IDQ12V2 with an Eclipse XA1000? Can it be played loud without sounding strained?
Yes, I am using the same setup. I am using the amp at 2 ohms, 480W RMS. I am a SQ person and do not listen at more than 60% of the volume. I am using a 0.7 cu ft sealed box for tight bass and the sound quality is pretty good at full volume. The tuning was done by Anwar, Autofusion at full volume to ensure best SQ outcome from the setup - that is the way he does tuning. Given the cost involved, this is the best option for you. Between, I paid 21k for the same mono in India around 5 months back.
PatienceWins is offline   Reply With Quote
Old 12th October 2008, 22:40   #18
valhallen.282's Avatar
Thanked: 164 Times
@ethanhunt123 if you can Jay your games on that mtx you will be one happy man. fantastic performance for the money it is known to be an excellent power amp.
valhallen.282 is offline   Reply With Quote
Old 6th November 2009, 15:10   #19
Mi10's Avatar
Thanked: 1,459 Times
If you have'nt ordered it, you could think about the RFPrime500.1
Gives out 320WRMS x 1 @ 4 ohms and 500W RMS x 1 @ 2 Ohm.
Considering this is less than half your JLs/Alpines/Audisons (~160$) its worth a try. They have some good review too
Mi10 is offline   Reply With Quote
Old 6th November 2009, 15:30   #20
Thanked: 49 Times
I came across the following deals on Crutchfield -
MTX JackHammer JH600
You get 600 Rms at 2 ohms for 170$
Alpine MRP-M500 Mono subwoofer amplifier 500 watts RMS x 1 at 2 ohms at Crutchfield.com
500 rms at 2 ohms for 180$
I would suggest getting either of these.
OT: Has anyone ever tried picking up "Factory refurbished" amps from Crutchfield ?
CrackedHead is offline   Reply With Quote
Old 11th November 2009, 08:35   #21
Thanked: 310 Times
Guys, please check the date. Its 1 year ago that the thread starter wanted the suggestion.
Bridgestone Turanza - Very trust worthy! lohithrao Tyre & Alloy wheel Section 176 14th June 2018 09:27
Indigo Marina - Is it a worthy buy ? mithun Sedans 34 11th May 2010 20:43
A worthy replacement that's fast as well as safe TCX Sedans 35 8th September 2009 11:30
can Used ESTEEM worthy to buy..pl suggest shapath Sedans 9 20th August 2007 19:45
