Old 10th October 2008, 08:23   #1
Thanked: 36 Times
Question Audio System not working after car servicing
I had given my car for servicing but after taking it back I find that my music system is not working. The HU comes on but the speakers don't work. So I checked the AMP and see that it is not getting on. The fuse and wiring seems to be ok, what could be the reason?
zaks is offline   Reply With Quote
Old 10th October 2008, 08:31   #2
Thanked: 17 Times
See if the remote switch wire from the HU to amp has lost it's connection somewhere.
Did you check the connection and fuse near the battery?
Old 10th October 2008, 13:25   #3
navin's Avatar
Thanked: 4,284 Times
you mean to say that the amp is not turning on? if so check the remote wire.
BTW this seems to be a common problem (service guys messing up ICE). Since I dont drive I ask my driver to take the car from the service station to my friendly neighbourhood ICEwalla for a clean bill of health.
Old 10th October 2008, 13:33   #4
DueLLeR's Avatar
Thanked: 61 Times
Hi Zaks,
You might want to check if the service guys have disconnected the power connection to the amp from the battery. They might have disconnected this while topping up the fluid levels for the battery.
Cheers!
DueLLeR
DueLLeR is offline   Reply With Quote
Old 10th October 2008, 13:59   #5
Thanked: 36 Times
Checked the battery connections and fuse, they're fine.
What's this and where should I look?
Originally Posted by DueLLeR View Post
Hi Zaks,
Cheers!
DueLLeR
No this is not the case.
They also cleaned the interiors and vacuumed the carpets, could this be due their doing some goof ups here?
Old 10th October 2008, 14:10   #6
Bass&Trouble's Avatar
Thanked: 71 Times
Do you have a multimeter? If so, I could guide accordingly.
Old 10th October 2008, 15:08   #7
Thanked: 36 Times
Ok, got one form IT .
Now please tell me all the steps as I have to go down 5 floors to parking
Old 10th October 2008, 15:12   #8
hemanthisgreat's Avatar
I suggest that instead of trying to DIY, you go to your installer tomorrow and get it done. It may hardly take time and he may not even charge you.
hemanthisgreat is offline   Reply With Quote
Old 10th October 2008, 15:24   #9
Thanked: 36 Times
Installer is far from my place and I suspect this to be a trivial problem unless they have pulled out some wires somewhere.
Old 10th October 2008, 15:41   #10
smokin's Avatar
Thanked: 13 Times
if you can see the amp wires connections then there will be three wires two of them would be of high capacity and the third one would be of mostly blue in color(hoping) check that wire is there on amp or not ,if yes then get a small piece of wire and connect that wire point to the positive terminal wire of your amp and check now that amp is working or not ...
If no then check the fuse and if yes then check wiring of the remote wire
hoping this will resolve your problem
PS. do turn off your keys before doing this and do not connect the wire to negative terminal
sorry again read your post :
This would be the issue of pre amp connectors being shot .. this would be the chance as amp is working but not the speakers...
DO you have any sub?
smokin is offline   Reply With Quote
Old 10th October 2008, 15:52   #11
Thanked: 36 Times
No I don't have sub, where to check for this pre-amp, near hu? BTW where is B&T who promised me some tehkikaat?
Old 10th October 2008, 16:45   #12
Thanked: 71 Times
Hi Zak! You mention that the amp is "not getting on", which I interpret as "not powering up", i.e. no LED glows. This can happen if:
1. You have blown a fuse in the power line, or power cable is open somewhere along the path
2. Remote turn on cable is disconnected or shorting somewhere. Latter not being very good for your head unit.
3. Ground connection has come loose.
Before anything else, check that the engine compartment fuse/ amp's onboard fuse(s) isn't blown, that the power cable is connected to the battery properly, and that the amp has all three wires connected to its 3 terminals, i.e. "Power", "Ground" and "Remote"
Follow these steps:
1. Keep the multimeter on the DC Voltage and in the range of "up to 20V"
2. With the system switched off, place the red probe on the "power" or "+" terminal on the amp, and the black one on the "ground" terminal. Check if you are getting a voltage in the range of 11-13. If you are, go to step # 6
3. If you are not getting any reading, move the black probe to some clean, unpainted part of the car chassis like an unpainted bolt or something. Check for voltage.
4. If you are getting a reading within 11-13 V now, it means that your earth has come loose. You have to check the earth wire.
5. If you did not get a reading in both cases, your power cable is faulty somewhere. Have an installer check it.
6. Switch on the head unit, at zero volume. Place the black probe on the amp's ground terminal. Place the red one on the terminal marked "remote". You should get a voltage reading, again something from 10-13V. If you are not getting this, there is a fault along the remote line.
If none of the above works, there's something up with the amp.
Old 11th October 2008, 08:53   #13
Thanked: 36 Times
I got the problem, following the steps above I found that the ground wire was open. Traced it and after some circus reconnected it back and everything is fine now. Thanks B&T and others for help in sorting this out.
I had been on a trip with bad roads perhaps this might have caused this problem.
Old 11th October 2008, 13:49   #14
Thanked: 71 Times
@ zaks - great to hear that its sorted out.
Use a nice ring terminal to securely fasten the ground cable to the chassis. Its not a good thing for the ground cable to be open like this. It could cause trouble if this happened when you were listening to music loud. Also ensure that such a thing does not happen with the power cable.
Remote locking system - Key fobs not working ukamath Technical Stuff 15 21st August 2017 23:15
Defogger not working / damaged after sun film fitting razor4077 Modifications & Accessories 56 21st May 2014 02:52
Punto music system (not stock) not switching off after switching off engine!! praz Technical Stuff 17 9th March 2011 09:55
Help! Baleno AC not working after car stalled in water. aaggoswami Technical Stuff 19 20th September 2009 22:56
BlueTooth Car Audio System + Security System venky6009 In-Car Entertainment 1 2nd November 2007 04:45
