Old 12th October 2008, 22:19   #1
Thanked: 89 Times
Default GTO 937 or 938
hey guys, just got my car fitted with gto 937, was told later on by a friend that gto 938 has released as well, so called up my installer(neighbour), he said there's barely a difference, but if u want i ll change it. please tell me, should i stick to the 937 or is the 938 a better buy? please
sukrit7 is offline   Reply With Quote
Old 12th October 2008, 23:34   #2
greenhorn's Avatar
Thanked: 1,518 Times
whats the price difference he's quoting ?
Old 12th October 2008, 23:49   #3
abhinav.gupta88's Avatar
Thanked: 310 Times
AFAIK
The 938 is more bright as compared to the 937. ( or you can say it has more treble)
Guru's correct me if i'm wrong.
Old 12th October 2008, 23:59   #4
greenhorn's Avatar
at default settings , I guess they may be brighter, but the treble attenuation goes to -6 db in the 938 ( as opposed to -3 db in the 937), so you can still tone it down more than the old one
Old 13th October 2008, 00:04   #5
Magma's Avatar
is the new series applicable across the entire range.
im looking to buy 5.25 inch GTO coaxials this week for rear fill
i thought of GTO 527. is that availble or is it now GTO 528?
Also can someone help me with retail price of the GTO527 and GT5 507. also please suggest if it would make a noticable difference whether i choose latter or former for rear fill
Magma is offline   Reply With Quote
Old 13th October 2008, 00:20   #6
Thanked: 310 Times
So that gives added flexibility.
BTW i too took the 938 over the 937 . ( in my case the 937 were not available )
Old 13th October 2008, 00:22   #7
Sam Kapasi's Avatar
Thanked: 1,473 Times
Originally Posted by abhinav.gupta88 View Post
AFAIK
Oh you're quite wrong abhinav.
Old 13th October 2008, 02:02   #8
blueraven316's Avatar
938 is not brighter than the 937, I think it's almost the same as the 937, the 608C component is much better than the 607C WRT treble.
blueraven316 is offline   Reply With Quote
Old 13th October 2008, 07:58   #9
panky12345's Avatar
Thanked: 150 Times
I thought it's applicable only for 608. AFAIK, its only 0 or +3db for 6 X 9s
Old 13th October 2008, 10:44   #10
Thanked: 89 Times
wow, fast stuff
according to my sources, the 937 is outdated, 938 is the replacement sort of.
he's charging me the same fr both units,according to hm they're absolutely same. so what d u guys say?
if the 938 is brighter thn i suppose the'sober' 937 would b better cause i already have a set of tweeters, + stock baleno speakers(front) and back is jbl. do let me no. thanku
Old 13th October 2008, 11:12   #11
rudrah's Avatar
Thanked: 29 Times
How about the JBL 947 Limited ed. over the 937?? as a novice customer, difference i could see in the watts where 947 is 400watts n 937..300watts! How effective would that be overall for a person who likes to listen to rock, trance and instrumental?
rudrah is offline   Reply With Quote
Old 13th October 2008, 11:43   #12
Sam Kapasi's Avatar
Allow me to answer this. The GTO937 and GTO938 are tonally very different.
You are correct Panky, the coaxials only have a 3db control, BUT>>>>
The GTO937 had a tweeter switch allowing for 0db and +3db at the tweeter. Normal and brighter.
On the other hand the GTO938 has a tweeter switch for 0db and -3db. Normal and softer.
I hope that makes it a little easier to understand.
Old 13th October 2008, 11:46   #13
Sam Kapasi's Avatar
Again let me explain.
The GTO 7 series were very forward sounding, bright, open and very attacking in nature. With feedback taken from various countries, JBL decided to change the tone of the 8 series, choosing to give them a warmer sound.
However there are many (ESPECIALLY in India) who love the bright forward sound and likr to play their rock and rap loud and clear. For this, the 947 limited was built.
The 947ltd. carries the same tonal quality as the famous GTO937, but has a more powerful build and voice coil. As the name explains, this is not a regular edition speaker, but a limited edition speaker that will be available for a few more months.
Old 13th October 2008, 12:39   #14
k10
I got GTO 527 at Rs. 2.5k a pair. This is the retail price in Pune.
k10 is offline   Reply With Quote
Old 13th October 2008, 13:11   #15
rudrah's Avatar
Thanked: 29 Times
Thanks Sam!
I was waiting to hear from you!
JBL GTO 938 - Crackling sound electricheart In-Car Entertainment 5 23rd August 2012 16:18
Replacing blown 2Ω mids in a component system with 4Ω mids glidealong In-Car Entertainment 17 17th May 2012 14:25
JBL GTO 937 Jarring problem willy In-Car Entertainment 13 2nd August 2010 11:37
JBL GTO 947 or 938? ricky_1605 In-Car Entertainment 7 26th May 2009 09:36
Getting rid of planks in palio to mount jbl gto 937 vickyre In-Car Entertainment 4 25th October 2007 21:05
