Old 14th October 2008, 16:37   #1
manaa45's Avatar
Thanked: 12 Times
Default Problem with Radio Tuning
hi Gurus
i have installed Pioneer Hu in my i10 and right from the day it has been installed, i am not able to keep the radio frequency settings. it comes to default everytime i switch off my car. i have to search it all over again everytime.
is it a problem with the installation or wiring ?
can you pls help.
i am not able to find this particular problem anywhere and if mods find, can you pls add this post out there please.
thanks
Mansi
manaa45 is offline   Reply With Quote
Old 14th October 2008, 16:40   #2
cyclops's Avatar
Thanked: 9 Times
while the tuner source is selected, press the function menu and select BSM.
it'll scan for the most strong frequencies and store them in the memory.
Originally Posted by manaa45 View Post
hi Gurus
can you pls help.
thanks
Mansi
cyclops is offline   Reply With Quote
Old 14th October 2008, 17:11   #3
manaa45's Avatar
Thanked: 12 Times
i have done all of that and even tried the manual settings. but it just disappears every next time i start the car.
i mean the channels do not remain stored in the memory.
Old 14th October 2008, 17:19   #4
Technocrat's Avatar
Thanked: 2,589 Times
Manaa does your time setting too gets reset everytime you switch on your car?
Old 14th October 2008, 17:19   #5
cyclops's Avatar
Thanked: 9 Times
does your other settings also get reset everytime you turn off the ignition? like the custom equalizer settings and clock?
Old 14th October 2008, 17:23   #6
abhinav.gupta88's Avatar
Thanked: 310 Times
Lemme explain what has happened.
Happened with my octavia too.(Alpine)
Your main wiring (used to power) has been connected to the storage/memory wiring and vice - versa ( i hope the names are correct)
Go to the dealer. Tell him this.
I'm sure he will interchange two wires and everything will be back to normal
Old 14th October 2008, 23:08   #7
nura's Avatar
It does seem that the 12V constant power & the 12V switched power wires have been wrongly connected. However, this is less likely to happen if a custom wiring harness is used, as the wires are colour coded. You need to check if your installer has skimped on the harness & cut into your car's wiring. Ouch!
nura is offline   Reply With Quote
Old 15th October 2008, 20:21   #8
Thanked: 310 Times
Thats what happened with mine.
Because i was not able to get my radio stations after the keys would have come out of the car and re-inserted.
I would recommend you to go your installer and get this thing corrected.
Tuning Box versus Remaps (Diesel tuning) Ravveendrra Modifications & Accessories 154 29th April 2018 22:45
The Amateur Radio (Ham Radio) thread bejoy Shifting gears 102 11th October 2017 10:43
Radio Auto Launched! Radio TUK TUK RW9763 Street Experiences 2 24th November 2010 15:17
The Dawn of Turbo Diesel Tuning in INDIA - Pete's Tuning Box turboindia Modifications & Accessories 108 17th April 2006 12:33
