Old 20th October 2008, 20:56   #1
Default CD stuck in Pioneer 6950- Gurus pls help
I am having trouble with my car audio system:
1. Your car: Swift
2. My current setup : HU - Pioneer 6950, JBL component speakers in the front and composite in the rear( apologies I dont remember the model numbers)
3. Description of the problem: _CD is stuck in the HU, ejecting at times and most often not???
Suvrajit is offline   Reply With Quote
Old 20th October 2008, 21:52   #2
navin's Avatar
Thanked: 4,282 Times
I'd take the HU to a Pio service station this is not something you should do yourself.
Old 21st October 2008, 14:10   #3
Thanks Naveen, will do that pronto!
Old 23rd October 2008, 06:35   #4
kuttapan's Avatar
Thanked: 12 Times
Try to reset the HU before you do that. You will lose your personal settings, but definitely worth a try.
The reset button is a small one on the faceplate(check ur manual).
kuttapan is offline   Reply With Quote
Old 23rd October 2008, 08:57   #5
Sam Kapasi's Avatar
Thanked: 1,473 Times
Since it ejects sometimes, I doubt that a reset will solve your problem. You have one of these 3 issues.
  • A simple electrical problem - the microswitch you use to eject the CD may be faulty. Press it hard to see if it ejects.
  • A complex electrical problem - There may be a problem with the syscon, microP or the PCB that relays the eject command. Alternatively your eject motor may be faulty and/or intermittent.
  • A mechanical problem - There may be a fault in your CDM (CD Mechanism) ranging from misaligned gears, faulty rubber rings or moving parts may need greasing.
In all cases, I would take Navins advice and visit a professional to get it rectified.
Urgent: A friend stuck at Dwarka. Pls help if u can. matrix_ren Shifting gears 5 10th October 2009 22:42
Difference between Poineer 6850 & 6950 HU saurabhkum In-Car Entertainment 16 27th May 2009 18:12
Budget ICE for Blushing Red i10-Gurus pls help MontyKING In-Car Entertainment 4 9th January 2009 18:02
Connect N73 Music Edition to Pioneer 6950 using Aux IN coolsats In-Car Entertainment 8 1st May 2008 17:44
Pioneer 6950 CD Eject problem adityamunshi In-Car Entertainment 11 10th March 2008 12:14
