Old 24th October 2008, 10:47   #61
abhinav.gupta88's Avatar
Thanked: 310 Times
Elegant ( the one in Lajpat Nagar) quoted my friend 8000 for damping ( in honda city)
But the prices of the speakers et all were acceptable and quite at par with many shops.
But the installation / damping and wiring charges were too high
Old 24th October 2008, 11:34   #62
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by gunbir View Post
Originally Posted by abhinav.gupta88 View Post
Thanks Gunbir jee
Any such system or maybe usability in India ?
Not so far Abhinav. There have been rumors but I am not aware of any usable information that suggests XM availability in India anytime soon.
Theoretically, XM is the same as WorldSpace (derived technology, same platform). Has anyone tried whether the XM section receives WS signal? The UI might be different, but the radio section is expected to be the same.
Old 24th October 2008, 11:37   #63
Thanked: 310 Times
How can it be recieved. Do we need to install some recievers or something?
Old 24th October 2008, 11:43   #64
Thanked: 294 Times
Thanks Gunbir jee
@ LBM , SAM - What are the specs of the 2200.1?
BTW OT : My college - friend Sudeep has started his install at Driven and was pretty pleased with the way things were going
JBL amp is 2200 rms at 1-4 ohms.
Originally Posted by Gill View Post
abhinav,
waiting for pics of power cable and inline fuse holder!
No pics were taken while installation was done. It is a Finolex 50 mmsq (0awg) wire. Right now there is no fuse but will be added later on.
Old 24th October 2008, 11:53   #65
Thanked: 21 Times
So the entire run of 0ga cable from battery to the amps isn't fuse protected? And I assume like 99% of all installs, this cable is running under the carpet. I'm sorry but this is unacceptable by any standards. If the cable heats up / insulation melts in any spot, it will short to ground. And then you will have this:
I hope you saved enough money on the fuseholder / fuse to buy a LOT of fire extinguishers.
Disclaimer: Heck what do I know, I'm just a marketing guy!
Last edited by Technocrat : 24th October 2008 at 13:26. Reason: Posting externally hosted images is not allowed
gunbir is offline   Reply With Quote Received Infraction
Old 24th October 2008, 11:57   #66
panky12345's Avatar
Thanked: 150 Times
Does it really makes a difference? The reason I'm asking is mine doesn't has one!
Old 24th October 2008, 12:22   #67
Gill's Avatar
Thanked: 12 Times
Thanks for the info LBM!
Do plug in the fuse at the earliest.
Gill is offline   Reply With Quote
Old 24th October 2008, 13:02   #68
Thanked: 294 Times
Will be doing tomm...he is coming for the same. Along with other tweaks and small little things.
Old 24th October 2008, 13:13   #69
Gill's Avatar
Thanked: 12 Times
Do post the pics to!
Old 24th October 2008, 13:27   #70
ramie2400's Avatar
Thanked: 58 Times
Well said Gunman sir,Proper fuse block/distribution block are a must gear for any hi-end installation,all these small components are darn darn expensive if bought in good quality and proper Ampere specs.
I take care if anything goes wrong the Power cables to the Amp/Accessories is cut-off before it reaches inside the cabin area.
ICE installs gets expensive only when installation is done in details with all the possible plug n play wire harness/crimps/Horn clips/Brass clips/splitters/connectors are installed.
Infact sometimes the installations + Labour comes nearly half the price of the entire ICE,but its an advantage that you wont have any power draining issues,no excessive load on Headlight/Wipers no tripping/clipping of amplifiers.And nothing will go wrong with the complete ICE equipments for years.
Ramie
Old 24th October 2008, 13:46   #71
DerAlte's Avatar
To qualify for the "XM Ready" tag, the receiver / decoder is supposed to be built-in, along with the User Interface for channel selection and the Channel information display abilities - . One needs to only add the antenna (like the WS antenna box, but much smaller).
Old 24th October 2008, 13:59   #72
Thanked: 21 Times
Well that's the difference between a good installer and a bad one. Safety First!
Old 24th October 2008, 15:42   #73
ramie2400's Avatar
Thanked: 58 Times
Absolutely true,I second that.Not even the extra lighting/show-off accessories are sometimes fuse protected
Just my 2cents.
Panky Paaji it makes alot difference,sometimes the amplifier main-board fries without even damaging the Fuse(s) over it my personal experience.
Old 24th October 2008, 16:07   #74
panky12345's Avatar
Thanked: 150 Times
Ohh! Thanks so much ramie! It wasn't your 2 cents, rather a very useful info that I was unaware of. Thanks again!
Old 24th October 2008, 16:24   #75
Bass&Trouble's Avatar
Thanked: 71 Times
Engine compartment fuse is an absolute must. One shouldnt have a car audio system without that little piece of equipment.
Advice Needed for Drawing Room Stereo: Harman/Kardon and Infinity vs. Bose manveet Gadgets, Computers & Software 137 28th October 2017 07:01
Fiesta 1.6 S(Q) V2.0™ - Harman/Kardon | Illusion Audio | Boston Accoustics | Alpine sathee46 In-Car Entertainment 239 1st June 2010 16:01
Harman Kardon CA470 or ? slayer87 In-Car Entertainment 17 18th May 2010 12:12
Frankmehta’s eS(Q)teem®: Eclipse| Illusion Audio| DLS| Genesis| Monster|Hermit frankmehta In-Car Entertainment 888 11th September 2009 12:19
Drive+Play from harman Kardon, problem voice calls a4_attitude In-Car Entertainment 2 13th September 2008 15:25
