Old 21st October 2008, 23:20   #1
nitin_bailey's Avatar
Default Want to ICE WagonR
Hi All. this being my first mail..after going through a lot of Gyan provided by the Gurus.
Well me being not that much of a techie. all the threads has gotten me slightly confused. I own a Wagon R and want to ICE it up. After going through various forums. i have come down to the conclusion that there are two options to choose from : Infinity (9623i) & JBL GTO937. pls let me know the pros and cons for both if anyone of you are using or compared it
I also have Hyundai I10 and have JBL GTO937 installed in rear and GTO 427 in front doors. Though the sound is great ( or punchy shall i say) i really feel Infinity could do better (I prefer sound quality, crispiness, music range over loudness, but also not to miss on the base punch though).
Now coming back to my WagonR. also, what set of speakers would you suggest for front ( keeping in mind -Infinity or JBL as rear)
I have a Pioneer head unit to attach it with. Also pls guide me, do i need to to use a separate amp. if i want to add a sub woofer.(am asking this as in the manual it says that I cud do so. or atleast that was my interpretation.)
Looking forward to a resolution mates.
Nitin
Note from the Team-BHP Support : Please take the time to use proper punctuation as per Team-BHP rules. Avoid...typing...like...this. Thanks.
nitin_bailey is offline   Reply With Quote
Old 22nd October 2008, 11:05   #2
navin's Avatar
Thanked: 4,351 Times
Now coming back to my WagonR... also, what set of speakers would you suggest for front ( keeping in mind -Infinity or JBL as rear)
1. The 937 has been repaced by the 938 and for those who like it brighter the 947.
2. JBL speakers are voiced a bit brighter than Infinty so listen to both and see which you prefer.
3. If you got just 4 speakers you could use an amp if you find yourself pushing the volume control past it's halfway mark.
4. If you want a sub you need an amp to drive the sub. The common/economical way to do this is get a 4 ch amp and use 2 ch. to drive the front speakers and bridge the other 2 ch. to drive the sub. Let the HU drive the rear speakers.
Old 22nd October 2008, 11:36   #3
Thanked: 17 Times
No matter what kind of rear speakers you buy, get a good pair of component speakers for the front. That will give you a better soundstage, imaging and a very satisfying overall music listening experience.
I would also suggest you to listen to Infinity and JBL before you zero in on your decision.
Old 22nd October 2008, 11:46   #4
abhinav.gupta88's Avatar
Thanked: 310 Times
jbl gto 608c components if you want a bright sound and illusion electras if you want a laid back sound
For the rear jbl 938 are pretty good.
Any plans for amp and sub?
Old 22nd October 2008, 14:42   #5
Thanks for your advice.. pls suggest good component speakers as well..
Thanks in advance.
Old 22nd October 2008, 16:48   #6
ritayan's Avatar
Thanked: 29 Times
Hi Nitin
Welcome to the forum, It is important to put a budget to what you want. Also a little input to your music taste helps suggesting correctly. And what you will get end of the day will be listen to your ears. Have a few demos and decide. also compos in a wagonR is dicy as there are a very fiew options in its stock location.
ritayan is offline   Reply With Quote
Old 22nd October 2008, 17:36   #7
Thanked: 17 Times
If he wants to stick to stock location, then it's better he buy some good 4" coaxials.
Old 22nd October 2008, 17:50   #8
panky12345's Avatar
Thanked: 151 Times
or Illusion 4" components EL4.1
Old 22nd October 2008, 19:48   #9
rohan_fonseca's Avatar
Why not 4" compos over the coaxials? Any specific reason for that?
rohan_fonseca is offline   Reply With Quote
Old 23rd October 2008, 14:40   #10
Please suggest me good co-axials or comps
Last edited by Technocrat : 23rd October 2008 at 14:45. Reason: Please post in full english, instead of pls write please, thanks
Old 23rd October 2008, 14:52   #11
Technocrat's Avatar
Thanked: 2,599 Times
You have lots of options in 4 inch coaxials but just two companies make 4 inch comps Kicker & Illusion.
We have few guys who have illusion 4 inch comps including myself. I am very happy with the sound as I previously had Sony 4 inch coaxial speakers
Old 23rd October 2008, 20:49   #12
Thanked: 310 Times
I have heard both illusion and kicker and i feel that illusion are far better than kicker
Illusions cost 2990 bucks.
Old 23rd October 2008, 21:09   #13
Thanked: 17 Times
Thumbs up Hint!
Frankly, I found some 4" coaxials to be better than 4" compos. For example, the Alpine Type E 4" coaxials sounded far better than the Kicker 4" compos which were almost twice the former's price.
But the Illusion 4" compos for +/- 3k sounds like a good option.
Old 23rd October 2008, 23:25   #14
greenhorn's Avatar
Thanked: 1,542 Times
whether you need 4" comps or coax depends on the dash location. if it is a bit far away and aiming away from your ears, then you *may* need comps, on the other hand , in cars like the spark, I've not felt the need for components. Usually comps are used when you use the locations in the doors , so that you your ears get the treble , and not your feet. With a dash install, its not as severe
Old 24th October 2008, 00:33   #15
In case of 4" coaxials would he be able to amp them?
Maruti WagonR over Hyundai Eon? EDIT : Bought WagonR with ABS / Airbags BoneCollector Hatchbacks 35 22nd May 2015 11:49
Only a WagonR can replace a WagonR ! From F10D to K10B.. DCEite Test-Drives & Initial Ownership Reports 27 19th April 2014 23:02
Do we want the Contessa Back? Can HM bring it like we want it? devarshi84 The Indian Car Scene 43 1st September 2011 17:44
WagonR or Swift?(calling swift and wagonR owners) rajshenoy Hatchbacks 43 29th March 2007 09:54
