Old 12th July 2011, 16:18   #31
navin's Avatar
Thanked: 4,282 Times
Default Re: JBL GTO 75.4 Amp capacitor info
Saurab, Check your speaker wiring in case there is some short.
Old 13th July 2011, 09:57   #32
Thanked: 106 Times
Have checked that and the wiring is perfect.
saurabhkum is offline   Reply With Quote
Old 13th July 2011, 10:06   #33
navin's Avatar
ok then disconnect the speakers from the amp end and see if the amp trips.
Old 13th July 2011, 10:28   #34
Thanked: 106 Times
Have tried disconnecting all speakers still amp trips. The problem occured when the system was not used for around 15 days. Humidity might be one reason for creating this trouble. I tried reducing the humidity level by switch the ac on but problem is not getting solved.
Old 13th July 2011, 10:35   #35
panky12345's Avatar
Thanked: 149 Times
Originally Posted by saurabhkum View Post
Need help in getting my JBL 75.4 checked , the sound sometimes goes away and Amp lims into protect mode then again come back after some times. What could be the problem ? Also if any decent place where can I get the same checked.
Open the amp, use hairdryer for a couple of minutes.. allow it to cool. Repack, Install and enjoy!
JBL GTO Vs JBL GT5 Amps. rider60 In-Car Entertainment 9 30th May 2011 13:35
For Sale - JBL 2ch Amp and JBL 12" Basstube karthik247 Shifting gears 5 3rd December 2007 17:44
Need Help With Car Audio Capacitor passion4cars In-Car Entertainment 10 4th July 2006 10:40
how to decide capacitor?? amit_sound In-Car Entertainment 2 28th June 2006 12:24
is capacitor worth an investement amit_sound In-Car Entertainment 58 5th April 2006 10:26
