Old 27th October 2008, 14:09   #1
shreyasma's Avatar
Default Fixing the USB port in the dash
Hello friends,
I no more have the DVD player and LCD as my last DIY.
This is not my own idea. I copied it from Satya (blueraven316)
Here's his thread
But i wanted it in a different place than the empty din slot below the music system.
So here goes the pictures.................................
shreyasma is offline   Reply With Quote
Old 27th October 2008, 14:34   #2
Technocrat's Avatar
Thanked: 2,589 Times
Wow this DIY looks Good Great work shreyasma
Old 27th October 2008, 14:51   #3
hellstar's Avatar
Thanked: 17 Times
wow thats a very very nice .. DIY
hellstar is offline   Reply With Quote
Old 27th October 2008, 15:17   #4
wanderernomad's Avatar
Thanked: 806 Times
Good one. Can you elaborate on the USB port used and the method to fix it securely in detail please?
wanderernomad is offline   Reply With Quote
Old 28th October 2008, 11:55   #5
shreyasma's Avatar
Thank you for the appreciation guys
I just used the female usb port provided with the HU.
the port was just pushed into the back of the plastic cover. but during testing found out that the port used to slip out of the plastic cover when the USB drive is inserted.
There was a very small gap in the plastic cover that made the port slip out. So this screw was fixed. When you firmly tighten the screw it holds the port in place. The covering of the port is soft plastic and the flat ended screw gets the grip to stay in place though there is no hole made to the port or the port covering.
I was actually lucky that the Plastic cover had the space to accommodate the USB port provided with the HU.
Was i understandable??
Old 28th October 2008, 12:38   #6
shreyasma's Avatar
If i was unlucky and had a plastic covering with nothing on the back, i would have done something like this.
Old 7th November 2008, 11:43   #7
Thanked: 41 Times
nice mod dude.. do u have contact number of satya ( blueraven) i need his landline number and cell .
thanks
monty9991 is offline   Reply With Quote
Old 7th November 2008, 12:04   #8
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
Due nice mod and very cleanly and professionally executed!
Way to go! cheers:
P.S. Is there a special name for the plastic usb cover that you used? where did you source it from? Computer peripherals store?
Tejas@perioimpl is offline   Reply With Quote
Old 11th November 2008, 12:42   #9
shreyasma's Avatar
thanks
I have messaged you his number
Way to go! cheers:
It was the normal USB port given with the HU :-)
DIY: Adding a USB port to the Ford Figo Mr.Boss In-Car Entertainment 39 30th November 2017 18:59
Hyundai dumps cigarette lighter socket for USB port in Korea JayPrashanth The International Automotive Scene 15 4th October 2013 16:09
Integrating USB Port and Aux-in jack in JVC car stereo!!! tajender In-Car Entertainment 1 25th December 2008 21:21
How to connect USB pen drive to AUX port? forbhaskarm In-Car Entertainment 4 15th December 2008 12:06
