Old 29th October 2008, 05:02   #1
DRAGONLORD's Avatar
Default Help, need advice on Ice upgrade !
Hi guys, lookikng for advice before going ahead and short-listing some speakers and amp for my ice upgrade. I listen to mainly Hip hop and trance.
Currently have Infinity Ref1240se sub and 1600a amp in my esteem with a decent Pio HU (with basic cables) and need some advice on the following:
1) Should I stick with Infinity and go for the Kappa series and another Infinity Amp for optimum performance?
2) After going thru the site I have decided against Soundstream and JL Audio. Now considering Boston or Hertz, any other suggestions to match my current Infinity setup ?
3) Recommended cables ?
Awaiting your valuable advice,
Cheers !
DRAGONLORD is offline   Reply With Quote
Old 29th October 2008, 10:41   #2
Thanked: 17 Times
What speakers do you have now?
Are you planning to purchase a mono amp?
Are you planning to upgrade the sub too?
What's the budget limit?
Old 29th October 2008, 14:48   #3
DRAGONLORD's Avatar
Why would I need a mono amp for the speakers ?? Have the Infinity 1600a for my Infinity sub, need an amp to drive the speakers. Heard that the best VFM option is to have a 2 channel for components up front and run the rear thru the HU.
(Currently have a full Pio front and rear speaker setup that came with the car, they are old and need to be upgraded to match my amp and sub.)
Do you guys agree ? Or would it be better to pick up a 4 channel for both the front and rear speakers ?
Budget is not really a prob but prefer to have VFM, spend wisely and save money for a paint job.
Old 29th October 2008, 14:59   #4
redfire's Avatar
If you are satisfied with sub and its amp, leave that. As you said, the baudget/VFM option is to go for good set of comps for front, driven with a 2 ch amp and drive the rear co-axs by HU. Look for 6-6.5" comps from JBL/Illusion/Bull audio/Hertz etc and a 2 ch amp (again JBL, Blau, Kenwood etc). Spend some for good RCA cables, speaker wire, power and installation also.
redfire is offline   Reply With Quote
Old 29th October 2008, 15:34   #5
Thanked: 13 Times
Originally Posted by DRAGONLORD View Post
Would it be better to pick up a 4 channel for both the front and rear speakers ?
Yep go for a 4ch. If you look at prices the stretch for a 4-channel is well worth it since it gives you options in the future as well as resale value.
Priority should be for front components.
You have asked about getting another infinity amp, they are more SQ oriented than the other stuff in the market. Try to audition if you can.
So expect something like this :
Front Comps : JBL/illusion = 6k
Amp : Infinity 475a (12.5k) or JBL 1004/604 or Kenwood 8401 (6-9k)
Wiring/Install : 3k
Any upgrade would show remarkable improvement over your current speaker setup so try to audition multiple and varied setups before you finalize.
Old 29th October 2008, 15:55   #6
adityamunshi's Avatar
Is the JBL 1004 available for 9 K?
adityamunshi is offline   Reply With Quote
Old 29th October 2008, 16:30   #7
Thanked: 17 Times
I would suggest you to pick up a 4channel amp. Use it to power all your speakers and switch off the internal power IC of the HU.
You can choose from a JBL or a Kenwood or a Blau. Kenwood 8401 is a good bang for the buck!
For speakers, I'd recommend Rainbow SLX series of components and coaxials. I run a similar setup, that is Infinity sub + rainbow compos. I love the sound.
Old 29th October 2008, 16:32   #8
DRAGONLORD's Avatar
Guys, any opinion on Hertz and Boston amps and speakers ? Also on Infinity Kappa vs Ref speakers ? Are Kappa speakers available in the market now ?
Any idea on the costings of the above ?
Old 1st November 2008, 00:37   #9
beanstalk_230's Avatar
I've heard something quite close to that - grey market, delhi
beanstalk_230 is offline   Reply With Quote
Old 1st November 2008, 00:48   #10
noidaboy's Avatar
Thanked: 260 Times
whats the budget like?
noidaboy is offline   Reply With Quote
Old 12th November 2008, 11:26   #11
DRAGONLORD's Avatar
Around 20-30k budget
Old 12th November 2008, 14:21   #12
Magma's Avatar
@speedzak
how much are the Rainbow SLX series compos?
Magma is offline   Reply With Quote
Old 12th November 2008, 14:34   #13
BAKIYA_2K12's Avatar
last week i got it for 7900 grey
BAKIYA_2K12 is offline   Reply With Quote
Old 12th November 2008, 16:45   #14
ilovefls's Avatar
I would suggest to pick up a Kenwood 8401. Its a 4ch amp and you can run the front comps and the rear speakers off that. Get Bull Audio comps for the front if you're not trying to stretch your budget or if you want something even better get the rainbow comps. For the rear you can get Hertz co-axials. The Kenwood plus the Bull plus the Hertz should cost you about 15k plus another 3k for wiring and install.
ilovefls is offline   Reply With Quote
Old 13th November 2008, 00:57   #15
superbhikari's Avatar
Thanked: 146 Times
Default Wiring?
Which would be the best wiring for the speakers and the sub - 4ch and mono, under 1- 1.5k available in Delhi?
superbhikari is offline   Reply With Quote
Need ICE Upgrade advice for Ford Fiesta. ZeRo© In-Car Entertainment 15 21st June 2014 21:21
Honda Civic - ICE upgrade advice dinu2506 In-Car Entertainment 65 18th February 2014 06:44
Toyota Fortuner ICE Upgrade - Need advice and suggestions!! TheStig In-Car Entertainment 8 13th August 2010 07:02
Swift Need ICE Upgrade - Help Needed Speed-Gladiator In-Car Entertainment 28 14th February 2010 16:12
Need Advice: Esteem ICE upgrade+new installs Flintstones In-Car Entertainment 9 26th February 2008 21:01
