Old 30th October 2008, 08:51   #1
Thanked: 36 Times
Default Want a Sub, will this work?
Hi Guys,
My ICE setup at present consists of Illusion 6.1 components in front and Illusion 6.2 co-axials in rear. These are now driven by a JBL GT5-A604 Amplifier.
I now feel like having a sub woofer and want to go for Polk MM 2104 which is a 10" sub. This because I feel it has good reviews and being 10" sub will take up less space in my Palio and I don't need too much bass.
Now my questions are-
1. Can I use the existing Amp to drive this sub as well? Because this sub is rated 300w rms and is 4ohms, whereas if I drive this in bridged mode from my Amp it will be supplying just 120w which is very low.
2. If I need a new Amp, will a JBL GT5 A3001 do the job well?
3. The recommended enclosure for this sub?
PS: How does the GZRW 10XS-AL compare against this Polk?
zaks is offline   Reply With Quote
Old 30th October 2008, 09:05   #2
adityamunshi's Avatar
Its 160W x 2 at 4 ohms. Should work but better try it before buying if possible.
adityamunshi is offline   Reply With Quote
Old 30th October 2008, 09:45   #3
Thanked: 36 Times
If I am not wrong it is 120w in bridged mode @4ohms load and the sub is 4ohms SVC.
Old 30th October 2008, 11:44   #4
Thanked: 36 Times
Bump, bump, guys your suggestions please ..
Old 30th October 2008, 11:56   #5
greenhorn's Avatar
Thanked: 1,544 Times
SRShrikant had some sort of channel seperator installed in his car.
Check out the description of the same in his garage.
Tata Indica - V2 Turbo 007 DLG - SRShrikanth's Photo Gallery - Team-BHP
Old 30th October 2008, 12:14   #6
Check the Owner's manual on jbl site. http://manuals.harman.com/JBL/CAR/Ow...4OM19Mar08.pdf
It says 160W
Old 2nd November 2008, 09:30   #7
kURETI's Avatar
You can use if you have a tight budet and you also dont like too much BASS
Monoblock for an sub is better
Polk momo series 10inch is better and I guess a sealed box is better [FONT=Univers-CondensedLight][SIZE=1]
MMC2104 .66cu ft.[/SIZE][/FONT][FONT=Univers-CondensedLight][SIZE=1]3 [/SIZE][/FONT][FONT=Univers-CondensedLight][SIZE=1](18.7L) [/SIZE][/FONT]
[FONT=Univers-CondensedLight][SIZE=1]check this for more details http://www.polkaudio.com/downloads/m...ubs_Manual.pdf
[/SIZE][/FONT]
kURETI is offline   Reply With Quote
Old 2nd November 2008, 13:33   #8
Thanked: 36 Times
That's what I was thinking as well. Any idea about the price of this Sub?
Tata comments on British Work Ethics ! But what of Work-Life balance ? mooza The International Automotive Scene 69 27th March 2013 00:47
Want to work in the Auto Industry! e46 Shifting gears 6 25th June 2011 10:36
Which one: Dual 8" sub V/s Single 10" sub? Invinsible In-Car Entertainment 53 28th May 2009 13:33
ground zero Sub vs image dynamics Sub rohanGT In-Car Entertainment 105 29th March 2009 05:01
Do you want to work for BSMotoring? GTO Shifting gears 0 16th December 2004 09:38
