Old 11th November 2008, 11:26   #1
greenhorn's Avatar
Thanked: 1,519 Times
Default Securing speaker grilles
The grilles of my rear 6x9's keep working themselves loose all the time, and its such a pain putting them back it, i wonder how they got loose in the first place.
I think superglue would be the easy way out , but i need to clean the cone and interiors now and then, so not sure i want to do that
how do you guys deal with it ?
Old 11th November 2008, 11:37   #2
ASHISHPALLOD's Avatar
Thanked: 286 Times
I am facing same problem.
what is the solution?
ASHISHPALLOD is offline   Reply With Quote
Old 11th November 2008, 15:35   #3
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
Are you sure you're fitting it right in the first place?
It's a snap on and should stay
However, if your clip is damaged, use feviquick. It'll come out easily when you want it to. Just give it a yank.
Tejas@perioimpl is offline   Reply With Quote
Old 11th November 2008, 15:42   #4
greenhorn's Avatar
there are no clips as such. the grille is a bit oversized and the friction keeps it there
a pic of my 6x9's
Old 11th November 2008, 15:47   #5
LOL, I have the exact same problem on my JBL rears and never expected to see a thread on this. Superglue seems only solution
DDGuy is offline   Reply With Quote
Old 11th November 2008, 15:59   #6
Bass&Trouble's Avatar
Thanked: 71 Times
Some speakers come with a rubber compound to attach the grills. This should be used.
This "loosening" phenomenon especially happens if the speaker mounting holes are not drilled dead perfect and upon screwing, cause the plastic trim ring to deform a bit.
Super Glue is a bad idea. If you ever want to remove the grill, to remove the speaker or so, expect a tough time.
Old 11th November 2008, 16:13   #7
greenhorn's Avatar
I recall getting some , but i think my local installer flicked it.
How are you supposed to use it ?
Old 11th November 2008, 16:28   #8
mansidea's Avatar
JBL is a real pain. The Grill of my front components came off & i replaced it with the grill of Hertz. Now the rear coaxials (6X9) & it is not as easy as the components.
Why cant JBL come out with a good design which lasts or something with screws or locks?
mansidea is offline   Reply With Quote
Old 11th November 2008, 16:39   #9
greenhorn's Avatar
The JBL grilles looked better designed. guess not
Old 11th November 2008, 17:13   #10
Thanked: 71 Times
Make small blobs and put it on the edge of the speaker grill (the downturned ends), and put the grill in. Make the blobs large enough and on both sides of the edge so that they can cling to the plastic of the trim ring sufficiently. After some baking in the car, they'll be firm enough to make the grilles stay put.
Old 11th November 2008, 19:26   #11
adityamunshi's Avatar
Is it possible to remove the grill once it is fixed like this ?
I uses little pieces of 2-sided foam tape on 4 sides of the grill as suggested by LBM.
adityamunshi is offline   Reply With Quote
Old 12th November 2008, 10:41   #12
navin's Avatar
Thanked: 4,286 Times
Originally Posted by adityamunshi View Post
Is it possible to remove the grill once it is fixed like this ?.
yes just lift and peal with a screwdriver
The obsession with chrome mesh grilles! sidindica Modifications & Accessories 81 5th April 2016 22:23
Car Stereo Speaker Projects Illustrated milindbajekal In-Car Entertainment 59 27th March 2006 16:28
Belden Speaker Cable k_ajay Shifting gears 0 9th September 2005 13:48
Component speaker in Hyderabd vivek.singh.73 In-Car Entertainment 11 25th August 2005 10:42
Speaker question mohit In-Car Entertainment 13 24th May 2005 19:43
