Old 14th December 2008, 00:56   #61
noidaboy's Avatar
Thanked: 260 Times
Wow ! Another upgrade !
Another upgrade done as well,he has gone nuts,Update the thread boy!
noidaboy is offline   Reply With Quote
Old 14th December 2008, 00:58   #62
frankmehta's Avatar
Thanked: 2,334 Times
no i doubt the seats can be folded now, what with the unequal length of both the amps and the distribution block in between.
but honestly, i am quite impressed with this install. very neat, and really good set of components used. the 2 amps look beautiful and the 2 subs too must be really KICKING in the boot. its a loss of the boot, but a great setup. just had a question to everyone who has more than one woofer in the boot.
does having 2 woofers and using them to their potential, even in a sealed box warrant an SQ setup? however good the amps driving them, or the drivers themselves, but can it ever warrant sq?? i only think of SPL when more than one woofer comes to mind. the 2nd arguement will be, that if they are both tuned for SQ(ie using them NOT to their max potential, with half the amount of power supplied from an amp) then what is the need for 2 subs????? wont their sine waves, or interference with each others frequencies cause a slightly boomy sound??
wont having JUST one sub in a tight sealed box provide enough bass? im not talking about ENOUGH in LBM talk, just enough to accompany, and not overpower the other components?
very confusing question, and very valid too, i think!
Old 14th December 2008, 01:02   #63
sam_786's Avatar
Thanked: 23 Times
More Pics. Now of the DAMPING done and the Wiring used in my setup.
Wiring is all Connection audison.
Damping in the Doors done using Noise Kill
In the boot area using Dynamat Extreme
sam_786 is offline   Reply With Quote
Old 14th December 2008, 01:21   #64
noidaboy's Avatar
Thanked: 260 Times
Its a game of tuning.Sealed box's have tighter kick,and better blending power.Ported are more preferred for boomy setups or loud spl setups (genrally)
Some competetion winning SQ setups have 3 subs and more than 500-600w rms.Having a power full setup does not mean it should be glass shattering or hell loud.It depends on the taste and how the user wants it to be.
Old 14th December 2008, 01:32   #65
frankmehta's Avatar
but my question to all is:
can SQ be achieved better in a 2 sub or 3 sub setup?
i dont think the human ears can take 2 or 3 rumbling subs in a boot and interpret them as SQ! it HAS to border on SPL! get my question?
Old 14th December 2008, 01:46   #66
noidaboy's Avatar
Thanked: 260 Times
You didnt get my ans.Yes it can because you have more surface area,if you have more subs.Having 2-3 subs does not mean they will be loud.They can be nice and gentle as well,depends on the way they are tuned.2-3 subs dont always need to rumble they can be controlled as well for SQ,they can play nice and tight rather than bass and loud
The setup in the pic IS a SQ setup.
Old 14th December 2008, 01:49   #67
m4ugr8's Avatar
Thanked: 123 Times
Yup, I have heard this and its PURE SQ.
m4ugr8 is offline   Reply With Quote
Old 14th December 2008, 02:09   #68
frankmehta's Avatar
dayyyyumn! who's car IS this??? lol.. i get your answer, but then does one need more than one well tuned sub for good sq? how much better can it get?
Old 14th December 2008, 02:51   #69
noidaboy's Avatar
Thanked: 260 Times
Another thing,Each side of the chameleon in the front stage is getting over 300w in sam's car.So for one sub to match that front stage, it would have to work very hard...hence you need two so they work less for same output, and at lesser distortion as more air is moved with lesser excursion so better SQ as the woofer's will not be on its peak to perform.Lesser stress on the Sub's and compo's if they have good balance of power.
Old 14th December 2008, 03:14   #70
abhibh's Avatar
Thanked: 34 Times
Congrats on the setup Sam.
I am sure it sounds great and just the way u want it. What is the retails of those components ?
In the below pic IMHO it would be better if all those wires are not visible.
http://www.team-bhp.com/forum/attach...p-img_1446.jpg
Another one
This guy upgrades faster than i can even process what i should upgrade.
EDITED:
Whats the nominal power handling of the CXS compos ? And rated power of both the amps ?
Old 14th December 2008, 08:58   #71
panky12345's Avatar
Thanked: 150 Times
Originally Posted by sam_786 View Post
Box had damping done inside it as well
How does this help?? Some people asked earlier as well.
Old 14th December 2008, 10:50   #72
sam_786's Avatar
Thanked: 23 Times
Another one
EDITED:
The Pic you have attached is not the final install. The wires were hidden afterwards.
Last edited by Rehaan : 14th December 2008 at 17:31. Reason: Blank post deleted & pics post restored. Please use the REPORT POST button to contact the mods and not the forum.
Old 14th December 2008, 11:03   #73
Gill's Avatar
Thanked: 12 Times
I have a small doubt regarding the port poistion or location,Does it effects the performance of the sub,if no then it's fine,
if yes, then in the above posted pics,isn't the flow interrupted as the boot wall is too close to the ported box.
Gill is offline   Reply With Quote
Old 14th December 2008, 11:05   #74
sam_786's Avatar
Thanked: 23 Times
Technical question, I think it helps in some back wave reduction. Gunbir/Jasdeep can answer this better, As far as I know the end result was Tighter and clear bass. And i think it helps in the strength of the box as well.
A box which houses two subs capable of doing 151+ dB needs to be strong
For a Setup with 2 or 3 subs, You first of all need a VERY VERY good front stage. When I had Bull/Rainbow Components, The SUB use to over power the Vocals every time and the result use to be that to listen to some music i had to take the Sub level to -6. But after the ID Compos, The front stage was playing very nice and LOUD. Then my two subs performed the blending function perfectly.
Even in the CRV, It has a very good front stage using Lotus Compos, so it needs the bass from the 3 subs to complete the spectrum of sound. If it has 1 sub, obviously the Vocals will over power the Bass.
Last edited by Zappo : 11th March 2009 at 23:57. Reason: Back to back posts merged.
Old 14th December 2008, 11:55   #75
noidaboy's Avatar
Thanked: 260 Times
Another one
Haha you said it,He is one of those who wants what he wants and wants it NOW!
EDITED:
The company rating for CXS is 125w
The 700.1 is rated as
175w X 2 @4ohm's
325w X 2 @2ohm's
650w X 1 @1ohm
The 1200.1 is rated as
400w X 1@4ohm's
800w X 1@2ohm's
1200w X 1@1ohm
Winters are here : Getz CRDi getz some iCe! aZa In-Car Entertainment 68 22nd December 2010 00:23
Recommendations for Getz ICE setup k_ajay In-Car Entertainment 3 19th November 2008 16:03
Need help for Friends getz 1.1 ICE setup in Pune hrishig In-Car Entertainment 3 28th January 2008 16:23
Getz prime 1.3 is overpriced than previous getz ( old one )? hrishig The Indian Car Scene 3 30th April 2007 10:29
Getz New Launch + Getz vs Swift.. scorp 1 Hatchbacks 18 23rd August 2006 11:34
