Old 17th May 2009, 13:28   #151
chiragh_bir's Avatar
Thanked: 70 Times
Originally Posted by m4ugr8 View Post
Yup, Even I want to know this, Can we Run Individual Power cables for each AMP from the battery, rather Than One Big cable and then splitting it using distribution blocks??
same thing i asked frankmehta , he says can be done !!
chiragh_bir is offline   Reply With Quote
Old 17th May 2009, 13:33   #152
sathee46's Avatar
Originally Posted by Sam Kapasi View Post
Take my advice and run separate 4 gauge wires to each amplifier (CA 470 and CA 1500). This is experience talking.
If you want to do it, run a single 2 gauge wire, a distribution block and then split it to both amplifiers.
I would recommend car audio cable, but if you end up using Polycab 25 sqmm (which is 4 AWG) the mono amplifier should work fine. Use the same wire to chassis for grounding too. Its a decent compromise.
I have tried to source the wiring kits here in chennai, it's a bit hard getting them here. There are a few available but they are awfully expensive, The same Kicker Kit which Manan has used costs 16K - 18K here. I'm trying my best to get some good qulaity wire, if not i'm going ahead with the install taking the above advice into considration.
sathee46 is offline   Reply With Quote
Old 17th May 2009, 17:13   #153
abhinav.gupta88's Avatar
Thanked: 310 Times
Take Ground Zero Wiring kit if you want.
0 Guage- 7990
2 gauge- 6490
4 Guage- 4990
8 Gauge- 2990
Old 17th May 2009, 17:37   #154
nitrous's Avatar
Thanked: 285 Times
Originally Posted by AG
4 Guage- 4990
Good Idea!
You need damping also, no?
Old 17th May 2009, 17:44   #155
Thanked: 310 Times
VFM and Branded. Away from all the debates
Old 17th May 2009, 17:56   #156
karankapoor's Avatar
I will say buy kicker 0 gauge wiring kit if it is expensive in chennei you can source it from delhi or can contact the importer for the same preeti trading company they are based in mumbai and are the importers for kicker products in India.
Going for 4 gauge will almost cost you the same, 4990 x 2 = 9980/= and kicker will cost you 12.8k this kit contains 2d.blocks/remote wire/2x5 feet 4 gauge wire from d.blocks till the amps/connectors/fuse holder/300A fuse.
karankapoor is offline   Reply With Quote
Old 17th May 2009, 18:24   #157
DocG's Avatar
Guys wait a min, those in the know will slide past the actual question which I asked...
I know that one can run two separate power kits to both amps. However my question was not targeted at the possibility of such an install, but the pros and cons of
1) Single power wire using distribution block to power 2 amps
VS
2) Two separate wire kits for each amp.
Sam hinted that the 2nd option was better for some reason. I would like to know more about that. [Details please]
Thanks,
DocG
DocG is offline   Reply With Quote
Old 17th May 2009, 18:38   #158
sathee46's Avatar
0 Guage- 7990
2 gauge- 6490
4 Guage- 4990
8 Gauge- 2990
Originally Posted by nitrous View Post
Good Idea!
Yes I need more damping, Is the 0 & 2 gauge wiring kits for dual amplifiers?
How do i get in touch with them? cant find them on google.
Edit : I did not see DocG's post, Even i wanted to know about this (Would certainly help me decide).
Old 17th May 2009, 18:52   #159
Thanked: 310 Times
I guess its a single amplifier kit.
You can contact LBM/Bass&Trouble/Smokin via PM for the same.
Old 17th May 2009, 22:31   #160
that kicker 0 gauge which i mentioned is a dual amp wiring kit, and the amps kits which abhinav mentioned are for 1 amp but you can buy extra cables/distribution blocks for hooking up the second amplifier, gz kits contains one rca/main wire/ground wire/fuse+holder/speaker wire.
here is the link for kicker importers Welcome to Preeti Trading Corpn.
Old 17th May 2009, 22:44   #161
DocG's Avatar
Branded wiring I would suggest would be
1) Kicker
2) Streetwire
3) Stinger
4) Monster
I don't have any experience with GZ wiring but from what I've seen (internationally), Kicker makes the best wiring kits. See if you can source any of these in Chennai, else one of us BHPians can help you out by sourcing it in our city and send it to you.
Cheers,
DocG
[Someone please answer the query above, I think that it would go a long way in helping others decide upon wiring]
Old 18th May 2009, 13:43   #162
sathee46's Avatar
Thanks for the link KK!!, I contacted them and I got a reply from the company's CEO with all the needed details. I'll check it out today or tomorrow lot of work at the office.
For the RCA's, Can i go ahead with Scoche?? (They do duty on the CA470)
Old 18th May 2009, 14:01   #163
YA you can go with scosche if you already have one with you, if buying a new set will say buy some good rca cable like audison/monster/stinger. you can get stinger cables from PTC (preeti trading) itself they also do stinger in india.
edit: correction it is PTC (preeti trading corp. )
Old 18th May 2009, 14:13   #164
sathee46's Avatar
Ok i will try to find a good RCA, were is this otc?
Old 18th May 2009, 16:37   #165
sathee46's Avatar
Default Another twist :confused:
I the process of getting a good branded amp wiring kit I enquired many people about this. I almost decided on getting the kicker. But now I've come to know that a Scoche kit E3200 is available here.
e2 E3200 by Scosche 4 Gauge Amplifier Wiring Kits Amplifier Installation Car Accessories and Installation Car Audio and Video - Sonic Electronix
I did a comparison and I feel the Scoche kit is much more VFM, I like the accessories (Battery terminals, D.Block, etc) in this kit. it also comes with a 4 channel RCA, I aint sure about the quality of this though. The price diffrence between the scoche & kicker is not much. Agian i have to ask you guys which one to decide.
Here is kicker's link Kicker PKD1 0-2 Gauge Amplifier Wiring Kits Amplifier Installation Car Accessories and Installation Car Audio and Video - Sonic Electronix
Advice Needed for Drawing Room Stereo: Harman/Kardon and Infinity vs. Bose manveet Gadgets, Computers & Software 137 28th October 2017 07:01
Harman Kardon Drive Play Display z klasse In-Car Entertainment 4 9th June 2010 13:08
Harman Kardon CA470 or ? slayer87 In-Car Entertainment 17 18th May 2010 12:12
vRs(q) Monster : Eclipse | Illusion Audio | Harman Kardon | Stereo Integrity abhinav.gupta88 In-Car Entertainment 691 11th October 2009 04:02
Drive+Play from harman Kardon, problem voice calls a4_attitude In-Car Entertainment 2 13th September 2008 15:25
