Old 24th May 2009, 21:43   #181
dude !! its looking so sexy :P !!!!! which amps are you using ?
congrats on the setup .!
VOiLA is offline   Reply With Quote
Old 24th May 2009, 22:32   #182
jkdas's Avatar
Thanked: 1,437 Times
Pix atlast but come on some better ones please! Congrats Sathee!
Sniff, another ID thing and Infinity. (HR please give me a raise!)
Old 25th May 2009, 10:53   #183
sathee46's Avatar
@JK Thanks man, The install has got some finishing touches to be done. I would post more pictures when it's done.
@Voila - Thanks, The amps are from Harman Kardon.
Originally Posted by sathee46 View Post
Once again I need help from you guys. I read the Gain setting simplified thread, I could understand things which is given for the 4-channel amplifiers a bit. But i'm totally blank on the mono's tuning options. My installer has tuned the amplifier himself keeping the gains low. I like the music, but I have a feeling that it is not balanced. The 4-channel is actually taking over the mono. Also there is a change in the way the 4-channel sounds. There are lot of options in both the amplifiers which i'm not able to understand. I can understand setting the gain part but it would be really helpful if someone can explain me in a simple way what the others do (Especialy the Sub-sonic part) or atleast tell me which would be the best.
I'm giving the pictures of the tuning options present in the Amps. I can understand what they do from the amplifier manul, but I do not know which would be the best setting. My question may be noob, but i could use some help here. I do not want to go to my installer for getting it to sound the way I like it, He does tune it the way i want but that is only if i explain him what i want, that i'm not able to tell him. I would love to know how to tune my equipment.
The 4-channel
Attachment 139469
The Mono (The part marked DBO in the below picture is marked as Sub-sonic in my amplifier)
Attachment 139470
Please gurus help me with my above query.
sathee46 is offline   Reply With Quote
Old 25th May 2009, 12:29   #184
navin's Avatar
Thanked: 4,351 Times
[quote=sathee46;1318604Please gurus help me with my above query.[/QUOTE]
Largely tuning a mono amp is not much different from tunring a 4 ch. amp.
On the 4 ch. amp you would be setting gain and HPF freq,
On the Mono amp you would set the gain and LPF freq.
From the pics you posted I noticed that
a. the gain on the 4 ch. amp are at max
b. the gain on the sub amp is at minumum
c. the LPF freq on the sub amp is also at minimum (32hz).
this would mean that only information below 32Hz is being played by your sub.
you should raise the LPF freq of the sub amp to about 60-80Hz (between 9 o'clock and 12 o'clock).
you should then reduce the gain on the 4 ch amp to about 2 o'clock and raise the gain on the sub amp to taste (12 o clock might be a good starting point).
Old 25th May 2009, 12:37   #185
nitrous's Avatar
Thanked: 285 Times
I would suggest setting the LPF/HPF at the HU.
32Hz LPF?
Please don't let the installer do the tuning. He only knows tooning.
Old 25th May 2009, 12:52   #186
sathee46's Avatar
Thanks a lot for the reply Navin, the pictures i have posted are of the brand new amp before install. This more like the way i can understand, I will try the settings as advised tonight. What shall I do about the subsonic part, any easy advice on that too? i will give you a better pic of the mono. (Even the 4-channel has a subsonic filter)
32Hz LPF?
i'm getting a multimeter to try some tuning as given in the gain settings simplified thread. Hope I dont end up tooning.
Edit :
* When tuning what setting should be there in the Bass control remote?
* Should I make any changes to the phase setting, i've kept it at 0 now.
Old 25th May 2009, 13:08   #187
hydrashok's Avatar
...I would love to know how to tune my equipment....
The 4-channel
Attachment 139469
Attachment 139470
To start with, try the following settings:
4-Channel Amp, both Front & Rear channels
Sub Sonic: Minimum setting (10HZ). If there is a way (a switch somewhere else on the amp) to turn this off, turn this off.
Freq: Set it so the arrow points at the 12o'clock position -- More on this later
LP/FLAT/HP switch: Set this to HP
Gain: Set it at 50% (12 o'clock)
LEFT/STEREO/RIGHT switch: STEREO
FRT/REAR/SUB switch: Set the Front channel to "FRT" & Rear channel to "REAR".
Mono Amp
Phase: 0
Sub-sonic: Minimum setting. If there is a way (a switch somewhere else on the amp) to turn this off, turn this off.
Freq: 80Hz (Max. position).
HU
- Switch all boots (bass, loudness, expander etc etc) to off.
- Switch the EQs off or set them to FLAT.
- If there is a DEFEAT option, turn that on.
- Set Subwoofer Level control to about 60-65%.
- If there are Crossover settings,
- In the Front Channel, set HPF to ON, and Frequency to 80Hz
- In the Rear Channel, set HPF to ON, and Frequency to 80Hz
- In the Subwoofer Channel, set LPF to ON, and Frequency to 80Hz
- Pop in your favourite CD and select your favourite song. Play it.
- Increase the volume to about 50% of the maximum.
The sound should sound pretty good now.
- Now go to the amp and adjust the GAINs of all channels (up or down) so that this volume level (of the HU) is your "medium-volume" or normal listening level.
- Next, sit in the driver's seat and adjust the gains of the rear channel so you can just barely hear the rear speaker playing.
- Slowly increase the volume till it is maximum, or till some of the the drivers start distorting.
- If the volume goes to the max without the drivers distorting, you can either leave it as it is (if you will never listen to music at this high a volume). If you are likely to listen to it even louder, increase the gains of all channels (in the same proportion as before) slowly till one of them distort. Dial back the gains till the distortion goes away.
- If the sub distorts, dial back the gains, and then check with the Subwoofer Level (in the HU) at MAX. Adjust the gains so distortion goes away.
- Go back to the normal listening level in the HU (and 60-65% Subwoofer Level) and see if all the drivers are balanced (rear's can be just barely heard, sub does not overpower the other speakers etc.).
If all is ok, you are about done. If all is not ok, adjust gains in the amps so all is ok. You can dial the sub to the level you like it at (from the HU).
You can fine tune the crossover attenuation levels in the HU (if you have that facility) to further adjust how the setup sounds.
Try how the overall tuning sounds like with 3-4 CDs till you get a level of tuning you like
BTW, the Subwoofer Level in the HU is to be treated the same way as external sub control modules. I personally don't like using the external modules as well as the HU Subwoofer Level control.
This is how I like doing the tuning. Try it and see if it suits you. I'm sure some of the gurus will also post instructions to help.
Old 25th May 2009, 13:38   #188
sathee46's Avatar
Thanks a lot Hydra, thats someting a person of my sort can understand easily. The instructions given by you and Navin is really helpfull. I'm taking a print out of this whole page. I will tune the amplifier tonight or tomorrow and will get back here with what I got.
Old 26th May 2009, 20:02   #189
abhinav.gupta88's Avatar
Thanked: 310 Times
Rocking.
The amps are truely lovely.
Do post some day light pics also.
Old 26th May 2009, 20:38   #190
sathee46's Avatar
Thanks AG, First I myself should find some time to look at my amps during day time. There a few things yet to be done like getting a replacment rubber mat for the boot, tuning and so on. I would post some nice pics when I'm done 100%. I'm thinking to bunk office for doing these.
Old 26th May 2009, 20:55   #191
Thanked: 310 Times
haha. Ice has it's effects. How about some review on the whole setup too. And the components. Are the highs warm or bright when compared to other compos.
Old 26th May 2009, 21:46   #192
sathee46's Avatar
Yeah it sure has. I've not changed my compos bro, it's just the mono and the sub which is new to the setup. I would give a detailed report on the whole setup once i sort out the tuning issues and listen to the setup for a while.
Old 27th May 2009, 00:32   #193
Thanked: 310 Times
i meant the review with the current setup. With the sub amp and tuning.
Old 27th May 2009, 01:22   #194
frankmehta's Avatar
Thanked: 2,366 Times
oh ya, sathee. you also need to request the mods to change your thread title. HK surely deserves a mention there :-)
Old 27th May 2009, 09:25   #195
sathee46's Avatar
Sure thing mate, a good review when i'm done
Hmmm, I was wondering how to do that myself .
Mods could you change the title to something like "My Fiesta 1.6S + Harman Kardon + Infinity Kappa + Image Dynamics"
Advice Needed for Drawing Room Stereo: Harman/Kardon and Infinity vs. Bose manveet Gadgets, Computers & Software 137 28th October 2017 07:01
Harman Kardon Drive Play Display z klasse In-Car Entertainment 4 9th June 2010 13:08
Harman Kardon CA470 or ? slayer87 In-Car Entertainment 17 18th May 2010 12:12
vRs(q) Monster : Eclipse | Illusion Audio | Harman Kardon | Stereo Integrity abhinav.gupta88 In-Car Entertainment 691 11th October 2009 04:02
Drive+Play from harman Kardon, problem voice calls a4_attitude In-Car Entertainment 2 13th September 2008 15:25
