Old 6th December 2008, 17:08   #16
abhibh's Avatar
Thanked: 34 Times
Originally Posted by Sowmya View Post
I can finalize that I need to go for a 4 Omhs. SVC not DVC. I dont wanna put any thing Extra ICE setting Except the Sub.
I would suggest the following if you want to go for 4 OHM SVC
1. Hertz ES300
2. JBL CS1204 or CS 1205
Old 6th December 2008, 23:57   #17
Sowmya's Avatar
Thanked: 16 Times
1. Hertz ES300
What might be the Cost ?
Sowmya is offline   Reply With Quote
Old 7th December 2008, 00:03   #18
frankmehta's Avatar
Thanked: 2,334 Times
i think the es300 is around 4k and the jbl is around 2.4k w/o b&w
Old 7th December 2008, 00:06   #19
Sowmya's Avatar
Thanked: 16 Times
What is that B&W ? how much will be the box ?
Old 7th December 2008, 00:43   #20
frankmehta's Avatar
b&w for the jbl is around 4k i think. not sure. and dont know the hertz prices. best person to contact is ramie2400
Old 7th December 2008, 09:17   #21
dinu2506's Avatar
Thanked: 351 Times
B&W - Bill and Warranty
Box will be Rs 1000 to 1500 for a sealed one.
dinu2506 is offline   Reply With Quote
Old 21st December 2008, 00:39   #22
Sowmya's Avatar
Thanked: 16 Times
Today I had been to JC Road to find the Woofer. But there in most of the shop available Woofer is JBL CS1204 or CS 1205 is between 2100-2500. No Hertz...
By the way I also found one more woofer Ultimate T1-120 - 600W. They was qoating 1600. Any Idea on this woofer. Its a Canadian make.
Old 21st December 2008, 08:39   #23
panky12345's Avatar
Thanked: 150 Times
Ultimate headache! Stay away..
Canadian make? No ways at all.
Old 21st December 2008, 23:59   #24
Sowmya's Avatar
Thanked: 16 Times
Any one else has any comment ?
One more question is there any Subs from PHILIPS ?
Old 30th December 2008, 00:02   #25
Sowmya's Avatar
Thanked: 16 Times
I went for SUB hunting this week again... But again confused. One shop told me that My Sony amp may not be able to handle High Out put so I need to put a smaller one,
Another shop was telling me that no prob it can handle any sub.
Real Confused. Please can you tell me ?
1. What is RMS ? What should be the resriction ?
2. What should be the Restriction for MY Sony XM-504Z Amp
3. Any Idea on Philips SUB.
Thanks.
Old 30th December 2008, 00:44   #26
abhinav.gupta88's Avatar
Thanked: 310 Times
Ummm. The sub should be rated in the range of 100 w rms either side for it to run on full potential.
I'd suggest get the amp changed too.
would help you a lot.
Old 30th December 2008, 01:15   #27
Sowmya's Avatar
Thanked: 16 Times
If I join both the Output then can I put 200W RMS ? At Present I dont wanna invest more on my car. And a avg music system/quality will fulfill my requirement as I Dont like loud music.
Old 30th December 2008, 09:52   #28
arpandiv's Avatar
Thanked: 27 Times
Hertz and JBL subs are both good.
However i would prefer the JBL CS1204(go for the one which has 1000/1100 watts printed on it. not the GT-5 one i.e 1200W) , your sony amp can easily power it. Stay away from Philips,ultimate etc.
arpandiv is offline   Reply With Quote
Old 30th December 2008, 10:26   #29
greenhorn's Avatar
Thanked: 1,519 Times
philips sub looks cheap. amit_mechengg had one of those for a while i believe
Old 30th December 2008, 11:16   #30
chiragh_bir's Avatar
Thanked: 70 Times
Why not GZ MK2.. amazing sub goes real low as well !
chiragh_bir is offline   Reply With Quote
Wanted: 2nd Hand sub-woofer and amplifier saurabhkum Shifting gears 0 5th August 2007 21:43
Portable Sub-woofer qqplus In-Car Entertainment 33 10th July 2007 15:55
Sub-woofer controller? katalyst In-Car Entertainment 15 26th February 2007 20:12
For Sale:JBL active sub-woofer angelfire Shifting gears 1 13th November 2006 14:03
Fitting a sub-woofer ajmat In-Car Entertainment 27 3rd June 2005 11:04
