Old 30th December 2008, 12:00   #31
Thanked: 294 Times
Originally Posted by Sowmya View Post
By the way I also found one more woofer Ultimate T1-120 - 600W. They was qoating 1600. Any Idea on this woofer. Its a Canadian make.
Stay away from this ultimate it will decimate your car. Go for something better.
Old 30th December 2008, 12:12   #32
arpandiv's Avatar
Thanked: 27 Times
Originally Posted by chiragh_bir View Post
Why not GZ MK2.. amazing sub goes real low as well !
+1 but the sony would not be able to exploit the sub . I think the Sub is 350W RMS.
arpandiv is offline   Reply With Quote
Old 30th December 2008, 12:34   #33
mav2000's Avatar
Thanked: 123 Times
How much is the GZ available for? I was thinking of a sub upgrade too.
mav2000 is offline   Reply With Quote
Old 30th December 2008, 12:37   #34
arpandiv's Avatar
Thanked: 27 Times
when i was hunting around last week, the price was 5490/- (MRP with B&W)
Old 31st December 2008, 00:57   #35
Sowmya's Avatar
Thanked: 16 Times
Thanks for all advice. Now the thumb rule for choosing a SUB for my AMP is.
1. 200 RMS
2. 1000 Watts
3. 4 Ohms
4. SVC
Thanks...
Sowmya is offline   Reply With Quote
Old 31st December 2008, 01:39   #36
abhibh's Avatar
Thanked: 34 Times
1. 200 RMS
2. 1000 Watts
3. 4 Ohms
4. SVC
Thanks...
JBL CS1204 (250W RMS) / CS 1205 (275W RMS)
Old 18th January 2009, 21:28   #37
Sowmya's Avatar
Thanked: 16 Times
This week end I searched JBL CS-1024 in many places in Bangalore. Almost there is no availability. Grey market they are asking 3000/- :(
Came across another few SUB under 250 RMS. Can you suggest ?
Pioneer TS-W301R
Nominal Power: 150W
Max Music Power: 800W
Nominal Impedance: 4 ohm
Kenwood KFC-W1012
Peak Power 800W
Rated Power 200W
Thanks.
Old 18th January 2009, 22:38   #38
Thanked: 158 Times
Hi, I'm looking forward to upgrade my ICE. The current setup is-
1. Blaupunkt HU
2. Sony xplode 4 channel amp
3. Sony comps
4. Blaupunkt bass tube GT 12S
The options available to me are-
1. Upgrade the comps to something better, retain the sony amp to drive the speakers and add a monobloc to drive the woofer
2. Chuck the sony amp and get a good 4 channel amp. Add another sub. Use 2 channels to drive the front speakers and 2 channels to power the 2 subs.
3. Replace the existing comps, amp and bass tube with a better 4 channel amp, comps and 2 subs.
The reason for upgrade? I am not happy with the way it sounds. Not enough punch or clarity.
I have a budget of 20,000 Rs. for the upgrade. If required I could stretch it by a few thousand bucks. What would you guys suggest I do? Can you recommend the best options available to me keeping in mind my existing setup and my budget of 20,000 bucks? I am looking for an SPL setup. Please provide the costs for individual items.
Astleviz is offline   Reply With Quote
Old 18th January 2009, 22:42   #39
arpandiv's Avatar
Thanked: 27 Times
First, sell the stuff and see how much you can rake in.
Then go for front compos,amp,sub in that order.
Old 18th January 2009, 22:48   #40
Thanked: 158 Times
I don't want to sell anything, whatever I replace will go into a friend's car which does not have any ICE yet. So I want to retain what I can/should and then upgrade the rest.
Old 18th January 2009, 22:57   #41
arpandiv's Avatar
Thanked: 27 Times
Fronts compos - 6K
Amp - 6.5K
Sub + box 6.5K
installation 1K
Front compos JBL GT-5, GTO 608, Bull audio, GZ iridium, Morel etc
Amp - JBL GT5 A604, Kenwood 8401(left over stock? ) blau 4ch
Sub- JBL CS series , GZ MK2(my vote). Polk Db series.
use RCA,wiring from existing setup.
Old 18th January 2009, 23:09   #42
Thanked: 158 Times
Ok, so GZ MK2 it is. Which comps and amp out of the ones you have suggested would you recommend for an SPL setup?
Old 18th January 2009, 23:22   #43
arpandiv's Avatar
Thanked: 27 Times
disclaimer:
my advise is based on my limited listening experience. I suggest you audition everything before buying.
IF i were you i would choose GZ iridium/ morel tempo series /JBL gto 608 components. (however since morels may not be available that easily your choice may be between GZ and JBL, you cant go wrong with either)
for the amp i would go for the JBL GT5-A604. please check pricing at 2-3 dealers, some discount on MRP is possible.
sub i would suggest fitting in a sealed enclosure.
Old 18th January 2009, 23:45   #44
Sowmya's Avatar
Thanked: 16 Times
Pioneer TS-W301R
Nominal Power: 150W
Kenwood KFC-W1012
Peak Power 800W
Rated Power 200W
Thanks.
Please advice some one for this... Can i Go any one of the above sub ?
I have Sony XM-504Z Amps.
Wanted: 2nd Hand sub-woofer and amplifier saurabhkum Shifting gears 0 5th August 2007 21:43
Portable Sub-woofer qqplus In-Car Entertainment 33 10th July 2007 15:55
Sub-woofer controller? katalyst In-Car Entertainment 15 26th February 2007 20:12
For Sale:JBL active sub-woofer angelfire Shifting gears 1 13th November 2006 14:03
Fitting a sub-woofer ajmat In-Car Entertainment 27 3rd June 2005 11:04
