Old 2nd December 2008, 22:05   #1
Sowmya's Avatar
Thanked: 16 Times
Default Suggestion to choose SUB-Woofer
Hi everyone,
I have a ford fusion. It has following setup...
  • JVC AW 706
  • Pioneer Speaker
  • JBL GTO 607C
  • Paramount Display (Head Rest)
  • Sony XM-504Z Amp
I want to put a Sub. Please can you advice. I need a minimal one. Can somebody tell me what kind of Sub I will be looking for.
thanks
Sowmya is offline   Reply With Quote
Old 2nd December 2008, 22:49   #2
ramie2400's Avatar
Thanked: 58 Times
Pioneer 307
Ground Zero MK2
JBL GT5-1205
Kicker Ez125
Hertz ES300
You can choose anyone of the subs in the price range of 2600 - 5600/- all are good and complete VFM
Old 3rd December 2008, 09:15   #3
Sowmya's Avatar
Thanked: 16 Times
What kind of Sub-woofer should I look for like...
1. Size
2. Output (wats)
3. 2/4/8 Ohms
Please can you suggest...
Old 3rd December 2008, 10:10   #4
Ajaybiz's Avatar
Thanked: 159 Times
Guru's even i am seaching for good subwoofer to get in sealed box and it should be DVC 4+4 ohms to make it total load of 2 ohms and should be in the range of 250-300 W RMS, 10 or 12" and its going to driven by JBL GTO 301.1.Suggestions please.
Ajaybiz is offline   Reply With Quote
Old 3rd December 2008, 10:37   #5
dinu2506's Avatar
Thanked: 351 Times
1. Size
2. Output (wats)
3. 2/4/8 Ohms
1. Size can be either 10" or 12"
2. I assume you are planning to use 2 channels bridged of your current Sony amp. I don't think it will push out anything more than 100W RMS. So you need to go for a low power rating sub.
3. You can go for a 2 ohm sub to extract max from the amp, but the price will be higher. 4 ohm is also fine and lot of choices in your price range.
Personally I suggest getting a sub like JBL GT5-12 and get another 2 channel amp to drive this (if you do not want to spend on a monoblock). Let the current amp power your front and rear speakers.
dinu2506 is offline   Reply With Quote
Old 3rd December 2008, 10:39   #6
ramie2400's Avatar
Thanked: 58 Times
Then i would suggest you can go in for Pioneer 307 DVC "Sasta Sunder Tikao" full VFM install it in a sealed box.It will cost you within 3k and Rs.500-800/- for a sealed box.
Old 3rd December 2008, 11:04   #7
Ajaybiz's Avatar
Thanked: 159 Times
No mate dont want to put Pio was looking for Infinity 1052 or 1252 or ID(costly but have to buy if nothing comes in next 2 month), do you have any info about infinity DVC's availability?
Old 3rd December 2008, 11:13   #8
ramie2400's Avatar
Thanked: 58 Times
If you want something real real good go in for the Ground Zero 12XD-AL,i think newer model with 2+2ohms will be available in a couple of days.
Edit:You can see that in my avatar
Old 3rd December 2008, 23:30   #9
Sowmya's Avatar
Thanked: 16 Times
Hi dinu,
I am poor on this calculation. Actually it had a Sub and I have removed it. The connection still exist. I think I just need to buy a SUB with Box and give the input. As I see it has two wires comes out from the AMP and forming single wire. And end of that it had the Plug (Male)
--Thanks
Old 3rd December 2008, 23:36   #10
NOTORIOUS's Avatar
Thanked: 89 Times
take help of somebody before attaching sub , because if by any chance it goes wrong then you will be hear to choose a amp also
NOTORIOUS is offline   Reply With Quote
Old 4th December 2008, 01:39   #11
frankmehta's Avatar
Thanked: 2,358 Times
kindly ignore. and mods please delete
Old 4th December 2008, 01:46   #12
frankmehta's Avatar
my choices marked in bold
Originally Posted by ramie2400 View Post
Pioneer 307
Ground Zero MK2
JBL GT5-1205
Kicker Ez125
Hertz ES300
The xm504z puts out a decent 120w of rms power in bridged mode.
why not get a pioneer or jbl dvc sub if you use a monobloc????
ramie, id suggest a good 4ohm svc sub. running a dvc sub from an xm504z is not recommended. just think of something that doesnt have too high a power rating. a jbl gt512 is a good idea for your budget considering its a vfm proposition and has a power handling of 275w rms. not bad. it pairs decently with a sony 504z. i just sold my sony 504. trust me, its quite underrated on tbhp. its a good performer and drives low end subs quite well for its power output
Old 4th December 2008, 08:09   #13
dinu2506's Avatar
Thanked: 351 Times
Hi dinu,
--Thanks
I suggest you take it to a professional installer and check out. Better not to try yourself and damage the amp. I can suggest EVO or Auto Fusion
Old 4th December 2008, 10:20   #14
navin's Avatar
Thanked: 4,346 Times
1. Size
2. Output (wats)
3. 2/4/8 Ohms...
Size: depends a bit on the size of box you are willing to tolerate. Usually bigger woofers need bigger boxes.
Output: dont worry too much about that. A good brand will suffice. Wattage specs are not so important as Mms, BL, Voice coil height, Air gap, etc..
I would stick to a 4 ohm sub if you intend to use a 2 channel amp in bridged mode. Pushing an amp to it's limits can also mean that the amp might have a shorter life and/or the amp does not operate with maximum control (as it would do if driven within it's optimal range).
Old 4th December 2008, 23:38   #15
Sowmya's Avatar
Thanked: 16 Times
I can finalize that I need to go for a 4 Omhs. SVC not DVC. I dont wanna put any thing Extra ICE setting Except the Sub.
Wanted: 2nd Hand sub-woofer and amplifier saurabhkum Shifting gears 0 5th August 2007 21:43
Portable Sub-woofer qqplus In-Car Entertainment 33 10th July 2007 15:55
Sub-woofer controller? katalyst In-Car Entertainment 15 26th February 2007 20:12
For Sale:JBL active sub-woofer angelfire Shifting gears 1 13th November 2006 14:03
Fitting a sub-woofer ajmat In-Car Entertainment 27 3rd June 2005 11:04
