Old 2nd December 2008, 22:45   #1
lionheart133's Avatar
Default Scratching Noise
My ICE knowledge is really poor so you would have to bear with my amateurish question
I have a front component(JBL) and rear coaxial (JBL) for my car.
It makes a scratching sound when a bass note is played.
Last time i took up the complaint with my ICE guy, he changed some settings in the HU and everything was back to normal.
Please do advice
Lnhrt
lionheart133 is offline   Reply With Quote
Old 3rd December 2008, 13:43   #2
XetaGLGRocks's Avatar
Thanked: 36 Times
Originally Posted by lionheart133 View Post
Please do advice
Lnhrt
What HU do you have? Are the speakers being driven by the HU directly, or do you have an amplifier?
As you are saying that the installer tweaked the Hu to get rid of the scratching noise, one possible cause of that noise might be due to high bass setting on your HU. If you bass setting is very high on the HU, then at higher volumes the sound may crack.
However, please post the details of your complete setup and then people may be able to help you out.
XetaGLGRocks is offline   Reply With Quote
Old 3rd December 2008, 14:02   #3
DerAlte's Avatar
Thanked: 2,879 Times
Right said, Xeta! Quite likely the speakers were being driven to 'cracking' sound due to their inability to handle low frequencies effectively at that power level.
It is also possible that the HU internal amp is the culprit - in the previous setting the amp was clipping, which can translate to 'scratching' noise if the speakers reproduce it faithfully.
Pillion seat scratching the rear fender mehuljain2k Motorbikes 1 6th March 2014 10:23
Scratching the itch - Grey Toyota Fortuner tvrspeed12 Test-Drives & Initial Ownership Reports 25 2nd January 2014 13:13
Trident Hyundai Service Center "scratching" my i10! coolfyre Indian Car Dealerships 17 19th September 2011 14:52
Scratching and vibrating noise from SKODA OCTAVIA 1.9 Ambient shineshine Technical Stuff 0 24th June 2007 16:34
