Old 3rd December 2008, 23:51   #1
gigy's Avatar
Thanked: 41 Times
Default Subwoofer size for free air mount in Baleno
Hi all,
What is the maximum size of subwoofer that can be mounted in baleno on rear tray. i have a 12'' woofer in box now. need to move it on top to make boot space. there are two rods of boot door passing midway that area, hence the doubt. Also i find the width looking less.
Will the car need a rear strut bar after cutting off all the metal?
i am not getting much exchange value for this 12'' rockford, so want to keep it.
Old 4th December 2008, 01:29   #2
frankmehta's Avatar
Thanked: 2,334 Times
the 12" rockford that you are talking about, which model is it?
is it meant for free air use? is yes, and if mounted on the shelf, then be prepared to listen to a much boomier sound than what you have right now. bass notes will be 'held' for longer and it will translate to a fatiguing experience while you drive.
if not a free air sub, then your output will reduce considerably, compared to the output that you get with the enclosure.
my 2 cents, do not mount your subwoofer on the parcel shelf. theres too may modifications to make. its not even worth making a large cutout in the body.look for a small enclosure, a sealed one perhaps, or else get it made according to the specs of the subwoofer model. place in the corner of the boot and forget it.
mounting anything other than a free air sub on the parcel shelf will result in a less satisfying experience.
Old 4th December 2008, 16:42   #3
gigy's Avatar
Thanked: 41 Times
whom should i contact in mumbai for a custom build subwoofer box out of fiberglass, which can be fixed on one side of boot and for damping using niosekill. please give me contact details. prefer someone between bandra to andheri
Old 4th December 2008, 17:22   #4
navin's Avatar
Thanked: 4,286 Times
Bass&Trouble represents Noisekill you can PM him for that.
Old 4th December 2008, 17:42   #5
noidaboy's Avatar
Thanked: 260 Times
Is Noise kill even a brand?? The main supplier told us there is no brand called "noise kill" its called audio damp. Since there is no marking on the product any body calls it what ever they like and claim to represent it at times
noidaboy is offline   Reply With Quote
Old 4th December 2008, 20:08   #6
frankmehta's Avatar
bass&trouble doesnt REPRESENT noise kill. they use the noise kill brand too good effect though. who is the MAIN supplier you talk about?? fyi noise kill is very effective. in fact its comparable to dynamat.
Old 4th December 2008, 21:11   #7
panky12345's Avatar
Thanked: 150 Times
.. Same as Fonomat if I'm not too wrong!
Old 4th December 2008, 22:50   #8
DjNik's Avatar
You can PM ramie he will be happy to help you out.
DjNik is offline   Reply With Quote
Old 5th December 2008, 11:36   #9
navin's Avatar
I'm sorry, I thought they did. Maybe B&T can clear this.
Old 5th December 2008, 12:35   #10
Thanked: 294 Times
Panky Ji it is there....from Audison.
But it is black in colour and costs around Rs 1200 when I bought it for 5 sheets of 9 inches x 9 inches. Which comes close to 315 for per sq feet.
Old 17th December 2008, 19:48   #11
gigy's Avatar
Thanked: 41 Times
I am missing my subwoofer in car but decided not to cut the tray and put it in free air mount. want to fix it in a fiberglass mount on a side but i was quoted anywhere between 5 to 7k for it. i dont have a powerful subwoofer to spend so much on it so want to diy it. can anyone tell me where i can source fiberglass in Mumbai and what glue to use with it?
Old 17th December 2008, 21:51   #12
greenhorn's Avatar
Thanked: 1,519 Times
gigy, how about SWWS
greenhorn is online now   Reply With Quote
Old 18th December 2008, 12:20   #13
Thanked: 294 Times
I would stay away from it.
Old 19th December 2008, 21:58   #14
gigy's Avatar
Thanked: 41 Times
i had tried that kind of setup but it didnt sound good. had to increase volume substantially to hear bass, else had to remove the spare wheel. decided on first danping the boot fully and then fix it on one side after i source fiberglass.
This car (also) climbed Mount Washington & Mount Mansfield, VT amitoj Travelogues 30 12th October 2013 01:35
Suggestion for free air subwoofer in 8". Prass In-Car Entertainment 3 29th June 2011 15:12
Active Subwoofer vs Free Air/Enclosed Subwoofer Epic In-Car Entertainment 2 2nd December 2009 10:59
Subwoofer...Free AIr or enClosed angelfire In-Car Entertainment 12 20th March 2006 14:52
