Old 18th January 2009, 11:35   #46
razor4077's Avatar
Thanked: 258 Times
Another Illusionized car in Kolkata. Nice! I think I started a movement of sorts, eh Ajay?
razor4077 is offline   Reply With Quote
Old 18th January 2009, 17:25   #47
Bass&Trouble's Avatar
Thanked: 74 Times
Definitely. There is no doubt about that.
Old 18th January 2009, 17:45   #48
abhinav.gupta88's Avatar
Thanked: 310 Times
Its sunday.
Whats the status?
Old 18th January 2009, 17:59   #49
senindra's Avatar
Abhinav, status is that the installation is going on. Just called up my friend who has volunteered to document the whole process through photographs and according to him wiring is in process, front door damping was completed when I spoke. More I do not know. Once he is back home and I recieve the pictures will post it up.
Originally Posted by abhinav.gupta88 View Post
Its sunday.
Whats the status?
senindra is offline   Reply With Quote
Old 18th January 2009, 22:08   #50
senindra's Avatar
Old 18th January 2009, 22:14   #51
senindra's Avatar
All pics from the installlation.
Its OVER!
Old 18th January 2009, 22:21   #52
DjNik's Avatar
Setup looks good bit pics,better pics if possible.
Have the crossovers been mounted inside the door?If they have been try and get them changed as it is'nt the best position.
Indivudal prices
Enjoy!
DjNik is offline   Reply With Quote
Old 18th January 2009, 22:27   #53
senindra's Avatar
DJ will take better pics when I am in India (Tuesday night). Yes the cross over as I see from the pic has been mounted inside the door, arpandiv another member on tbhp just pointed that out aswell .
Ill post the prices when I am in India.
Indivudal prices
Enjoy!
Old 19th January 2009, 00:51   #54
senindra's Avatar
Indivudal prices
Here you go, earlier than promised :
Pioneer 6050 UB - 9350
[FONT='Verdana','sans-serif']Illusion EL 6.1 - Rs.6990
Illusion E693 - Rs.5250[/FONT]
JBL GTO1004 - 10000
[FONT='Verdana','sans-serif']25 sq feet damping material – 25 x 150 = Rs. 3750/-
Ichiban rca cable 2 – 890 x 2 = Rs. 1780/-
Ichiban Fuse box 1pc, with one sec spare fuse – Rs. 450/-
Illusion Reference Speaker Cable 22 ft pack – RSC 16.50 3 – 1050 x 3 = Rs. 3150/-[/FONT]
Power Wire - 1300
Instalation - 1500
Total as of now : 43520
Old 19th January 2009, 11:58   #55
XetaGLGRocks's Avatar
Thanked: 36 Times
The crossovers need to be inside the car. Otherwise problems from rain water seepage is a potential threat.
Hopefully Sujon did a good job otherwise. I did not get a chance to drop by. Extremely sorry for that. Sujon called me and said that one of the Illusion front woofers were emitting a cracking sound at high gains. Please do run a check on that.
XetaGLGRocks is offline   Reply With Quote
Old 19th January 2009, 12:03   #56
Thanked: 74 Times
Do check that the HPF is enabled on the speaker channels and set to about 80Hz. That could be the reason for this. Also check that bass boost if present, is set to off for the concerned channels.
Old 19th January 2009, 13:14   #57
senindra's Avatar
My friend who went was quite satisfied with the work. Impressed with the attention to details he said. However, I will see it tomorrow so can tell you then. Dont need to be sorry! I will drop by your office and visit you and Razor sometime on Wednesday.
Will check this tomorrow night and update you on this B&T.
Old 19th January 2009, 15:26   #58
shuvc's Avatar
Thanked: 287 Times
B&T, is it ok to run the EL6.1 woofers with 63Hz HPF? I often do it with the MBQ. Haven't faced any issues at high volume levels.
Old 20th January 2009, 11:43   #59
razor4077's Avatar
Thanked: 258 Times
Install looks neat, equipment is great But I too would suggest moving the x-overs away from inside the door panel to maybe under the dash. Was there a reason why it was fitted this way? Haven't seen it done before.
Will see & hear it in person tomorrow hopefully.
Congrats, and do post some better pics!
Old 20th January 2009, 13:22   #60
Thanked: 74 Times
Its fine. They are often run full range in setups without subwoofers. But then what is the crossover frequency for your sub. If that plays upto 80Hz, the speakers and the sub are overlapping in the already notorious region where the car could cause a bass hump.
ICE ICE baby. Punto"ICE"fied Soccerfan In-Car Entertainment 45 10th March 2012 21:40
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
Lancer.ized got his Lancer.iCED Lancer.ized In-Car Entertainment 46 4th May 2009 12:14
"IMAGE" Autopsyche Lancer ICE Install Pics gunbir In-Car Entertainment 53 20th September 2006 01:06
"VEGA" Autopsyche Lancer ICE Install Pics gunbir In-Car Entertainment 18 1st May 2006 15:06
