Closed Thread
Old 8th February 2009, 21:33   #211
vikram18's Avatar
Thanked: 20 Times
Originally Posted by frankmehta View Post
CDT crossover lying unused??? what makes you think the 7100 has better processing than the actual crossover itself? im quite keen to know how its sounds with and without the crossover! vikram please let us know
The active setup is what I liked best. Ask the Hermit; I'm sure he agrees
vikram18 is offline
Old 8th February 2009, 21:50   #212
frankmehta's Avatar
Thanked: 2,334 Times
NICE! hermit must be busy with his usual activities right now. tomorrow morning when he goes to his office he will reply. till that time im still doing reading on active vs passive
frankmehta is offline
Old 8th February 2009, 21:54   #213
abhinav.gupta88's Avatar
Thanked: 310 Times
he's doing the install as always so i shall speak to him tomorrow. the sub is almost finalized!
**beware** its the most unexpected upgrade!!
no spl, no sqpl pure sq!
Waiting for this anxiously.
abhinav.gupta88 is offline
Old 8th February 2009, 22:48   #214
frankmehta's Avatar
Dhoom Car Audio
This is the one!!!!!!!
Old 8th February 2009, 23:03   #215
abhibh's Avatar
Thanked: 34 Times
Dhoom Car Audio
Congrats Frank. Nice choice of equipment there.
A little suggestion though. This might compliment your Lucies pretty well.
Lucent Tweeters
abhibh is offline
Old 8th February 2009, 23:06   #216
frankmehta's Avatar
nice, and ill use a Sumsang/Nakomirchi crossover with them!
Old 8th February 2009, 23:08   #217
navin's Avatar
Thanked: 4,286 Times
Originally Posted by abhinav.gupta88 View Post
How will the transfer function being linear help the decision to use the Alpine and biamp?
if the transfer fuction is a simple linear 2nd/3rd/4th order XO then you can use an electronic XO and not worry about things such as frequency/impedance response anomalies of the woofer or tweeter.
navin is offline
Old 8th February 2009, 23:28   #218
Thanked: 310 Times
So this should be checked on every HU have a XO in built to decide which XO to use?
EDIT :
Excellent choice Doc
Old 8th February 2009, 23:33   #219
frankmehta's Avatar
back to business! im still reading my eyes out on active vs passive, but to no avail
Old 9th February 2009, 10:59   #220
hydrashok's Avatar
@frank, if you have 4+1 channels of amplification, you can always try the active setup for a while. The only additional expense will be a bit extra money on speaker-wires. Since you don't have crossovers for the Luccent speakers with you anyway, maybe you can skip buying the Luccent XO, and spend that money on speaker wires.
OR, run the setup passive for a while and then later, try running it active. You will be able to postpone the upgrade-itch :P for a bit longer, as this will be a nice change in the setup. You'll also be able to judge for yourself which setup you like best.
hydrashok is offline
Old 9th February 2009, 11:05   #221
frankmehta's Avatar
im anyways getting the tweet and xo from hermit audio. i can try both.
i have only 4 channels of amplification, from the ground zero TA120Mk2 amp. the 5th and 6th channels are only for the sub.
hence when i go there, i will be able to decide. by the way, my front door pads are being fibre glassed as we speak, and damping is going to be done in places where there's no fibre. that will surely make a big difference, as there was minimal amount of damping on the doors earlier.
Old 9th February 2009, 11:13   #222
arpandiv's Avatar
Thanked: 27 Times
frankie we want pics of the work in progress.
arpandiv is offline
Old 9th February 2009, 11:20   #223
frankmehta's Avatar
ajay kamath is getting it done at his warehouse! can you please put up a couple of pics of the fibre glassing if possible b&t?
Old 9th February 2009, 11:37   #224
hydrashok's Avatar
@frank, you'll need a minimum of 4+1 channels to go active with the 9887 (in front + sub mode): 2 channels for the tweeters, 2 channels for the midbasses and one channel for the sub. In addition to the 4-ch amp, You have an RF mono with you, right?
Old 9th February 2009, 12:14   #225
Bass&Trouble's Avatar
Thanked: 71 Times
Yup. But that was also because you werent able to get the power you desired running to the speakers. So, bridging or going active were the only two options.
Frankie, dont do the active business. Its not like we can reduce the XO frequency greatly or get the Lucies to do anything extraordinary. It sounds just right with the supplied crossovers and theres a very very wide range of tweeter attenuation possible.
If you do want to do something fancy, we could bi-amp the set.
Bass&Trouble is offline
Closed Thread
Indica V2 DLS -Indica V2 DLS - Electricals falling apart - 57,000 km update cyberwhizs Long-Term Ownership Reviews 5 25th April 2013 13:04
Indica DLS / DLS TURBO / DICOR?.....What BUY? musicmanaman Hatchbacks 20 8th May 2010 19:05
vRs(q)® Monster : Eclipse | Illusion Audio | Harman Kardon | Stereo Integrity abhinav.gupta88 In-Car Entertainment 691 11th October 2009 04:02
Frankmehta reviews his ICE: Part 1: Rockford Fosgate 325.2 MONO+Illusion Luccent Sub frankmehta In-Car Entertainment 23 21st February 2009 20:29
Indica NA DLS vs Turbo DLS vs Turbo DLG greenhorn Hatchbacks 10 5th May 2007 17:20
