Closed Thread
Old 1st May 2009, 13:41   #601
frankmehta's Avatar
Thanked: 2,334 Times
oh k. so i think the genesis is almost finalized. unless someone comes up with a very convincing reason why i should get a BRAND NEW jbl gto7001 with a bill and warranty over PAYING MORE to get a used Genesis Profile SUB which has been used for a year. LOL
frankmehta is offline
Old 1st May 2009, 14:07   #602
frankmehta's Avatar
what's the fuse rating of the Genny? does it matter much? rated power of genny's is always much lesser than the typical power @ 14.4V. the typical power is shown in the genesis series III homepage of genesis-ice.com, but the typical power of the profile sub is not shown anywhere.
for example:
the series III monoblock does 750*1 @ 2 ohms, even though its rated by Genesis to do 500*1 @ 2 ohms.
any page where there are reviews of genesis amplifiers? detailed reviews?
Old 1st May 2009, 14:25   #603
karankapoor's Avatar
only series III has that typical power ratings, for more information on profile amp Profile - Pure Energy
search talkaudio.co.uk for reviews.
karankapoor is offline
Old 1st May 2009, 14:34   #604
frankmehta's Avatar
Which is higher end? The Profile or the Series 3?
Old 1st May 2009, 14:36   #605
ImmortalZ's Avatar
Thanked: 312 Times
Series III. They are typically grossly under-rated by Genesis.
ImmortalZ is offline
Old 1st May 2009, 14:43   #606
entry level: profile
next level : profile ultra same amp with double the power.
then comes the series III
Old 1st May 2009, 18:06   #607
frankmehta's Avatar
I shall post the pictures that come in tonight
My mind is totally set on the genesis right now.
Old 1st May 2009, 20:26   #608
ImmortalZ's Avatar
Thanked: 312 Times
"Extremely limited budget" my bottom.
A new S3 mono is like 1.2L. If you define that as an extremely limited budget...
Old 1st May 2009, 20:59   #609
nitrous's Avatar
Thanked: 285 Times
Let me help you out, Frank.
Infinity KAPPA ONE (kappaone) Mono Subwoofer Amps Car Amplifiers Car Audio and Video - Sonic Electronix
nitrous is offline
Old 1st May 2009, 21:29   #610
i think there is a confusion, frank is not going for the SIII mono block.
read some earlier post.
Old 1st May 2009, 21:31   #611
hydrashok's Avatar
Good choice, Frank! Don't go by just the "rated" power on the Genny. The "rated" power here will be what the amp will put out in normal, non-stress conditions without breaking a sweat. When the music pushes it to work, it will deliver the extra power needed.
As KK said, you'll find a lot of reviews of Genesis amps on Talkaudio.co.uk. Gordon of Genesis (more like Genesis of Gordon, heh heh) is a member there (his username is 'Gordon' itself) and you can probably PM him for specific info.
And good call on the ummm... other plan.
hydrashok is offline
Old 1st May 2009, 21:59   #612
abhinav.gupta88's Avatar
Thanked: 310 Times
That will be 800w to his 300w*2 subs.
I dont think Doc would take this.
Even though it wont harm the subs i guess.
abhinav.gupta88 is offline
Old 1st May 2009, 22:21   #613
frankmehta's Avatar
i wouldnt need an s3 to power my luccent subs :-)
maybe an upgrade to dynaudio subwoofers might do justice to the s3. and yea, an esteem wont do justice to both these. so i shall book a bentley instead
thanks nitrous. but the landed cost of this amp would be about $450 WITHOUT duty, so this would be a very expensive affair. id rather do a genesis profile ultra sub at that price!
immortalz was joking kk!
thank you anupji! i know for a fact that the Genny will be more than a match for the luccent subs. more than 300W for an SQ application is not even desired. i will be more than happy to have the subs disappear when called for, and come to life when the music demands it. as i like to say, the way the music is made! and what better way to start off, than the classy luccent subs being given clean class G power from the Genesis!
thanks for the talk audio link, KK and Anupji. I just realized i am a member there. had registered to do some research about the DLS that is going into the car.
the DLS and the Genny might turn out to be a surprise combination, and quite a few in UK do this mix and match. DLS for the fronts, and Genesis for the subs: this is a tried and trusted combination. So happy to know that!
yes, true. as i said before, 300W (for me) to each sub is more than enough for my SQ application. in fact i might not even be using half the power at a given time!
i dont think even 500W to the luccents wont harm there. they are known to hang in there in the toughest of situations.
imagine, the luccent fronts have been fed 220W of power for long periods without them breaking into a sweat! (even though they are rated ! just 100W)
Old 1st May 2009, 22:43   #614
nitrous's Avatar
Thanked: 285 Times
But you have someone at New Jersey to bring it down, dont you?
nitrous is offline
Old 1st May 2009, 22:52   #615
frankmehta's Avatar
no longer. he is stocked with a LOT of non car audio stuff to bring back, also! lol.. i know where you got that from :-P
Closed Thread
Indica V2 DLS -Indica V2 DLS - Electricals falling apart - 57,000 km update cyberwhizs Long-Term Ownership Reviews 5 25th April 2013 13:04
Indica DLS / DLS TURBO / DICOR?.....What BUY? musicmanaman Hatchbacks 20 8th May 2010 19:05
vRs(q)® Monster : Eclipse | Illusion Audio | Harman Kardon | Stereo Integrity abhinav.gupta88 In-Car Entertainment 691 11th October 2009 04:02
Frankmehta reviews his ICE: Part 1: Rockford Fosgate 325.2 MONO+Illusion Luccent Sub frankmehta In-Car Entertainment 23 21st February 2009 20:29
Indica NA DLS vs Turbo DLS vs Turbo DLG greenhorn Hatchbacks 10 5th May 2007 17:20
