Closed Thread
Old 12th May 2009, 18:12   #706
Invinsible's Avatar
Thanked: 60 Times
Originally Posted by frankmehta View Post
thanks abhishek. i kind of had this in mind, but now i am making a new larger enclosure altogether. so might not need it. unless it has a large influence on the quality
any 'side effects' of adding polyfill??
Don't think it would have any side effect. Generally I would suggest you to add 1- 1'1/2" poly fill all around on the inside wall of the enclosure even though your enclosure is large size. This may reduce the resonance inside the enclosure which may be smooth'en out the the sound waves, may result in little deeper sound, if not help in fooling the sub of larger enclosure.
Invinsible is offline
Old 12th May 2009, 18:15   #707
frankmehta's Avatar
Thanked: 2,334 Times
what about a DAMPED enclosure? how different is a damped enclosure from that of one with polyfill?
frankmehta is offline
Old 12th May 2009, 18:28   #708
karankapoor's Avatar
use dynaxorb and apply it in side the enclosure on the wall behind the magnet and damping material on the other walls.
like this
karankapoor is offline
Old 12th May 2009, 18:30   #709
Invinsible's Avatar
Thanked: 60 Times
Damped Enclosure works the same as a polyfill would. But, over the years it's been the polyfill that is proven to give better result as a the sound waves travels through them, hit's the wall of the enclosure, travels back and pushes the waves to move your sub. damping inside the enclosure may be cut the resonance too but, don't think it would give the same result as a polyfill would.
Damping is best for doors, booth, and other areas where putting a polyfill is practically not possible.
Over the years I have always used polyfill in my sub enclosures whether going ported or sealed. Not many may notice the difference, but I feel somewhere at high output it does make a difference. The use of filler will help minimize midbass resonances. Even the sub acts in some what controlled manner.
You may try it if you like it keep it or you can always remove it and it's a cheaper option.
Old 12th May 2009, 19:10   #710
frankmehta's Avatar
aight. thank you so much KK and Abhishek. this was something I was thinking of since a long time. How much does dynaxorb cost??
Another question that is plaguing me since a long time: Tweeter position.
I have read somewhere that having tweeters off axis increases their 'shine' (which i have been experiencing since quite a long time, and the least tweeter attenuation the x-overs allow is a -1.8 setting which is blunts the tweets too much: a -.5 would be perfect!)
Mine are off axis, as you can see in the photo.
Using the same photo, can you'll please tell me what my OPTIMUM tweeter position should be?
On Axis, but where? On the door pads?
Or further away from me like the i10 shown below? Note how far away from the listener, they have been placed! and they are angled in opposite directions. IE the drivers side tweeter is facing the passenger, and vice versa. Suggestions
PS:in the 4th photo from the top, the adhesive marks point to where the earlier TS-20s(emosional atyaachaar) were installed. is that a good position for on axis?????
also, will changing the tweeter position to on axis, 'raise' the soundstage slightly higher up? I dont mind that actually. I sometimes feel the midbass sounds better when I duck my head a few inches. Am i an idiot or is there some logic in all this reasoning?
Frankmehta’s eS(Q)teem®: Eclipse| Illusion Audio| DLS| Genesis| Monster|Hermit-frank-esteem-3.jpg
Frankmehta’s eS(Q)teem®: Eclipse| Illusion Audio| DLS| Genesis| Monster|Hermit-frank-esteem-1.jpg
Frankmehta’s eS(Q)teem®: Eclipse| Illusion Audio| DLS| Genesis| Monster|Hermit-dscn2942-desktop-resolution.jpg
Frankmehta’s eS(Q)teem®: Eclipse| Illusion Audio| DLS| Genesis| Monster|Hermit-dscn3001-desktop-resolution.jpg
Old 12th May 2009, 19:41   #711
abhinav.gupta88's Avatar
Thanked: 310 Times
How about something like this?
http://www.team-bhp.com/forum/sound-off-show-off/30684-illusionised-swift-part-2-a.html
abhinav.gupta88 is offline
Old 12th May 2009, 19:44   #712
frankmehta's Avatar
inna vadda photo? abhinav this photo looks like 'actual size' photos that come in mobile phone ads! lol
edit it na!
Old 12th May 2009, 19:47   #713
Thanked: 310 Times
Editing done
http://www.team-bhp.com/forum/iipcache/99434.jpg
Maybe some more adjusting on the TA function is needed.
Just maybe.
Old 12th May 2009, 19:59   #714
frankmehta's Avatar
wont getting the tweeters so close to me increase their shine? i mean, in your case, dont the tweeters sound too bright?
Old 12th May 2009, 20:10   #715
Thanked: 310 Times
The tuning and cross over settings on the passive crossover have been done to make them sound normal ( According to me, normal) Maybe bright / laid back for others.
If they are fired at each other, i think they would sound better.
Old 12th May 2009, 21:55   #716
Invinsible's Avatar
Thanked: 60 Times
As far as my knowledge goes off axis response is when the speakers or tweeters are not directly facing towards the driver. On axis is when the speaker / tweeters are facing the driver directly. The best would be to mount them on Apiller facing eachother or on dashboard facing parellel with front screen. That way the sound from the tweeter would travel high up near rear view mirror or rather in center.
It also depends on the design of the speaker whether they are capable enough to give the off axis response. You can always try this position during the installation and see if it works to bring the right imaging if not than you would have to try the on axis way where it comes facing towards the front seats. In this case best i think would be to put in the deep corner of the front windscreen.
See what works the best for them.
Old 12th May 2009, 22:17   #717
Gill's Avatar
Thanked: 12 Times
@Frank, which set of tweeters are you using?The tweeter in first pic looks bigger.
Correct me If I am not wrong, doesn't look like luccent tweeter.
Gill is offline
Old 12th May 2009, 23:15   #718
frankmehta's Avatar
hi gill. in fact, i am using the tweeters in the 1 st pic.
i didnt have too many pics of the luccent tweeter, hence in the next few pics, to show the location i used old pics taken with my electra tweeter.
OF course, the 1st pic IS the Luccent tweeter! :-)
Old 12th May 2009, 23:51   #719
Gill's Avatar
Thanked: 12 Times
Thanks for clarification, I just checked Amey's thread before seeing these pics,I got confused.
The size looked different! that's why I asked!
@How about placing tweeter closer to midbass? I am keeping an eye,on what members say here!
Gill is offline
Old 13th May 2009, 10:44   #720
frankmehta's Avatar
tweeter close to the midbass would be technically lowering the soundstage right?
how much does time alignment help in RAISING the soundstage in an Passive setup? I know its way too easy in an Active setup, but we are not going active here.
Trying various positions with the tweeter is fine, but i have time alignment, and that makes a lot of things simpler. the MAIN problem is the base location. the slightly directional changes can be made later, but I want the tweeter to be on axis this time.
Suggestions suggestions suggestions!
Guys, the install is moving periliously close. I need my queries sorted out please.
Closed Thread
Indica V2 DLS -Indica V2 DLS - Electricals falling apart - 57,000 km update cyberwhizs Long-Term Ownership Reviews 5 25th April 2013 13:04
Indica DLS / DLS TURBO / DICOR?.....What BUY? musicmanaman Hatchbacks 20 8th May 2010 19:05
vRs(q)® Monster : Eclipse | Illusion Audio | Harman Kardon | Stereo Integrity abhinav.gupta88 In-Car Entertainment 691 11th October 2009 04:02
Frankmehta reviews his ICE: Part 1: Rockford Fosgate 325.2 MONO+Illusion Luccent Sub frankmehta In-Car Entertainment 23 21st February 2009 20:29
Indica NA DLS vs Turbo DLS vs Turbo DLG greenhorn Hatchbacks 10 5th May 2007 17:20
